Oil Finish Rags
Used search but didn't find anything on this.
I was watching a video today by what I would consider to be a well renowned woodworker who showed how he kept rags used for oil finish in a jar and then reused them when applying the next coat. So I have a question, is this a safe practice? I had always heard that they should be laid out flat or draped over a trash can to dry before disposing of them. I am in the process of applying several coats of the same finish over several days and this would appeal to me if safe. I would never do this long term but for applying the same finish over several days it would reduce the number of hazardous rags to deal with. My non educated guess would be by sealing in a air tight canning jar there would be no air so thus no ignition but...what say you all?
I would have to think it is safe or the gentleman was a fool to mention it on a "for public" video.  I know it is nice to not have to deal with a bunch of rags in an extensive finish process.  But me, I personally might be more concerned about saving a rag in the jar and have just a little nib of finish get a little firm or crusty and you don't catch it when you lay down your next coat, it leaves a line through the finish and now you are scrambling for a new rag while the finish starts to set up.  I actually don't like to finish so I am always looking for ways to keep the mickey mouse to a minimum.  I have an extension ladder that leans against the side of the house.  Thats where I dry my rags, out in the fresh air.
I have used a small rag to apply an oil finish and I just submerged it in a bowl of oil then put a plate over it and reused it the next day. The rags I used to wipe off the excess went outside, hung flat on a metal railing to dry then tossed. I just wasn't going to take the chance.
Father-in-laws house caught fire from spontaneous combustion , strange set of causes but it still caught fire. It took them 4 months to get back into the house.
One summer I picked up a wadded up oil rag to put it out on the railing and it was hot as hell ! So lay a rag in use out flat. Wadding it up concentrates any heat created by the curing oil.
It's probably safe because there is very limited oxygen getting to the rag.  But would I do it?  Hell no.  The risk vs reward isn't there.
Rags are cheap, the practice has risks, one of these times the lid won't get put on or put on quite right, I'll pass.  I have a metal bucket with a lid that latches.  I fill it half full of water and toss the rags in as I go. When I'm done I lay them out flat to dry and then dispose of them.
Watch Rockler and Klingspor's for sales.  I'm still working my way through a 5lb bag I bought from Klingspor on sale for about $8 a couple of years ago.  At my consumption level of 2 or 3 large pieces per year, they're a bargain.
No air = no fire. Even if the rag could catch fire initially, it would burn out quick in a small sealed jar by using up the air inside. However, reusing oil rags seems like reusing dental floss. Just because technically it can be done, doesn't mean it should be.
Sent from my iPad using Tapatalk Pro
I use paper towels to apply CA glue to the blanks.  I toss them on the concrete floor to cool off.  I also have a metal soup can that I fill halfway with water and dunk them there.  Don't get into rags for finishing...yet.  You can purchase red painted containers for such items as paint rags, similar to what geedub mentioned.  Check with an industrial supply house.
4 hours ago, Dknapp34 said:
No air = no fire
Exactly.  The spontaneous combustion of oily rags is caused by oxidation.  If there's no oxygen, there's no risk.  Which is why your cans of BLO are not exploding. :)
That said, whoever "the guy" is, he has taken cheap to a whole new level if he's that worried about throwing away some rags.  I'd put it in the "not worth the time" category, but it's not dangerous as long as the jar is sealed and air-tight.
You may be right. I find that difficult to say without knowing how long between processes etc. If he is in oil on seperate components the next day, maybe not. If he is trying to keep them a week or more, likely yes.
Drop a match into a jar and close the lid...see what happens. :)
1 minute ago, C Shaffer said:
Just commenting on the cheap comment. Nothing more. :ph34r:
Ah, got it.  Too early for brain function properly.
Found you were right. Edited the quote to be less confusing.
If you buy a box of clean quality cotton rags they can get rather expensive. Lots of the discount boxes contain cut up clothing rejects. Seams, buttons, odd textures and mixed colors are not good for finish work. White & gray cotton rags thus bring a premium. Old cotton tee shirts are fine for hobby work but colors and printing reduce their usefulness for staining , oiling or finish wiping. So I can see being conservative if you have a limited supply but the risks of spontaneous combustion are quite real. Wiping varnish rags should also be treated like an oil rag.
Every once in a while my wife goes to the Goodwill "outlet" they have in the city.  Clothing is sold by the pound there.  Every time she goes I tell her to get me a huge pile of the oldest, least printed on t-shirts she can grab.  A giant pile costs a buck or two.
Thanks guys! I will continue disposing of them after each use just not worth any risk there might be in not doing so. I was never worried about the cost it was more the thought of having less used rags to deal with. My current project is 3 bar stools so I am creating a fair amount of contaminated rags each day so when I saw that I thought i would throw it out to the forum. Thanks again!
