I am in the market for an 8 inch jointer.  I would prefer helical cutter head and parallelogram tables .  I have had the Grizzly model on order for months and it now seems that they won't be available until April!!  I don't want to spend $3000 for another manufacturer so it looks like I may have to forgo the parallelogram beds.
Do you all think the standard beds are an issue.  I understand they are very difficult to adjust if out of parallel.  I am looking at the Powermatic and Jet models at the moment.  Please give me your opinions.  Another manufacturer?  I understand the Steelex is basically the same as Grizzly and it will be available in December.
Thanks.
I've got an 8". Delta clone with normal beds. It's a pain to adjust, about once or twice a year. Essentially, only when I move everything out of the shop to clean or rearrange.  If buying a new unit tomorrow, parallelogram beds would not be as important factor for me as it's ability to hold a setting and work reliably. Because of those, I wouldn't shop grizzly.
I have 50 year old wedge bed and have no issues. If the beds get out of wack (which requires either damage, extreme wear, or really bad quality out of the gate) than you need shims to get them square and can take a few days of adjusting to get it right. I have previously owned a grizzly wedge bed jointer with no issues.
The best alternative to grizzly is Shop Fox. It's made by grizzly, comes with a longer warranty and is sold by other outlets rather than just through grizzly themselves. Good luck!
If I had to give up a feature, I'd most likely give up the helical head in lieu of the parallelogram tables - you can add a helical head later if you want, but you can't add parallelogram tables. At least, this is my reasoning when I think about eventually upgrading to an 8" jointer.  Interested to see where this post goes.
Also....Part of my reasoning is that I have a helical head on my planer, so as long as I can get something flat in some way on the jointer, I mostly let the planer deal with any tough grain.
Thanks.
The PJ 882 is an outstanding jointer i have one. The strait blade model will be onsale over black friday weekend 10% off which puts it at just shy of 2k which is still considerable more than where your at. The Helical head for it from byrd is like $450 which means you could get the $3200 jointer for $2500 ish. leaving you the ability to save for the helical head to buy later.
just a thought. Jet would probably be an okay option. The problem is with $2500 is the 12" grizz seems to be a pretty decent jointer and isn't much more but offers 4" more capacity.
Last month I bought the Grizzly G0490 (straight knife) jointer, because they were out of stock on the helical head models.  At the time it was on sale for 935.  At the same time I bought the Byrd Shelix head through Grizzly.  The combined price came in very close to  their model with the Grizzly helical head.  I swapped heads as I set it up, and I really like the jointer.  The head swap was very easy.  I just checked the Grizzly site and they are now out of stock on the straight knife model.  Check Steelex, except for color, their jointers look to be identical to Grizzly  models and I think they have a better warranty.  I really like the parallelogram tables, and hh head, be patient and get what you want.
Thanks for the input.  The Shop Fox and Steelex are also out of stock until April!  I had thought about swapping out the Grizzly blades for the helical head but, as you said, that model is also out of stock.  I am leaning toward either a Jet or Powermatic with helical heads and wedge tables.  Woodworkers used them for decades.   Money isn't the biggest issue....I just don't want to spend a huge amount since I am a weekend warrior.
The only adjustments on a new jointer should be moving the fence and the depth of cut. If the tables are not ground coplaner from the factory send it back. You don't want to go down the road of aligning jointer tables.
And when you get a new jointer don't lift it from the end of the tables.
Good luck
Because shop fox is sold by other stores there may be folks who have it in stock right now. You should try calling around. A Google search showed several retailers listing it as in stock.
you can get the 8" PM straight knife wedgebed from amazon for like $1790 right now ...
Well that really sucks as I have the same one on order. You're talking about the G0490X right? The only 8" they do have in stock is the G0495X but that thing is nearly 800 pounds. Guess I need to look at the Powermatic 60HH. No parallelogram beds but I guess there are worse problems to have.
  • Who's Online   3 Members, 0 Anonymous, 33 Guests (See full list)
    26,008
    Bob44
    Bob44
