Random Tip #18 - See-through Guide for Small Repairs
Wow, I've been slacking.  No tip since June!?!
I imagine we've all been working on something where a bit of "handling damage" occurs in the worst spot.  I knocked this little corner off and of course it would be right where two parts butt up to each other in what should be a tight seam.
If you are lucky enough to find the wandering bit of material, use a length of clear scotch tape to pick it up.  Use a nice long piece, tape doesn't cost much and this gives you adequate "handles" to hang on to.
You can see through the tape so that you land the repair right on target.  You can see that I actually missed a bit in this demo shot.
The tape makes it easy to practice your landing.  Add a drop of CA, zero in and land the piece, use the tape to hold it still and in a few moments you have your nice crisp corner back.
I did touch up a little CA squeeze/stain with some very fine sandpaper.
I like the scoth tape idea.....simple and elegant.  Why didn't I think of that years ago?   Don't answer that!
I like that tape tip. A lot. Why have I never thought of this?
I use Dap Rapid Fuse , it's a CA type adhesive that's formulated for wood and gives 3 to 5 minutes time to adjust the joint, sliver or whatever assembly and get the clamp or tape tight.   I really like the long piece of tape pickup method ! I'm sure it will be useful sooner or later.
Great stealth add-on tip.  I had missed Rapid Fuse.  I'm gonna give that stuff a try.
Sets faster when it's hot. After 10 minutes I noticed a mistake & tried to knock apart a joint with 2 8mm dominoes. Had to beat the hell out of it and remake the part that got installed upside down. But 2-3 minutes in the summer and you can reposition & clamp, 3-5 minutes at 70 degrees or lower.
It lets me clamp up a sub assembly and 10-15 minutes later pull the clamps and finish putting a project together. I have assembled & finished some projects in the same day.
Great idea with the tape.  Seems it would also be a barrier to keep any squeeze out from bonding your finger to the project.
@gee-dub Does the tape itself adhere to any squeeze out?
@wdwerker do you use the DAP Rapid Fuse for regular joinery, in lieu of, say, Titebond?
I tend to use the Rapid Fuse whenever I need short clamp times so maybe parts of a project get it and everything else is TB2 or TB3. I use RapidFuse for the entire box assembly on the display shelves that I build by the hundreds. They get glue & 1" micro-pins , dry for an hour then run through the drum sander. Haven't had a glue joint fail yet.
Masking tape will but, clear scotch tape does not in my experience.
Good tip!  Tape can be a handy thing to have in the shop. I always thought Scotch came in bottles. ;)
It does but, then I can't find the tape!
