Meatwad Posted May 23, 2021 Report Share Posted May 23, 2021 I was gluing up several strips of wood into a cutting board this weekend and I got everything lined up, clamped up, cauled up, and glued up. While the board came out pretty good I did have a lot of glue cleanup to do where the clamps and cauls were holding the wood. Is there a good way to handle this? I've just been using a chisel and sanding but that doesn't always work out well. And I've got some new clamps I don't want to ruin with glue and rust. Quote Link to comment Share on other sites More sharing options...
curlyoak Posted May 23, 2021 Report Share Posted May 23, 2021 I'd rather have too much glue than not enough. Let it dry then belt sand. With a chisel be carful. If going against the grain you could pull up som wood. Titebond 3 sands easy. Quote Link to comment Share on other sites More sharing options...
Popular Post Coop Posted May 23, 2021 Popular Post Report Share Posted May 23, 2021 I like to clamp mine up with the clamps all on one side and clean the exposed side up. Then apply the clamps to the clean side, flip the piece over and remove the initial clamps and clean that side. 3 Quote Link to comment Share on other sites More sharing options...
Chet Posted May 23, 2021 Report Share Posted May 23, 2021 I am similar to Coop but I alternate clamps. Maybe 3 on one side and 2 on the other depending on the size of the panel or cutting board. I scrap of excess glue with a putty knife getting to it as soon as possible. After I get the bulk of it cleaned up I go back and remove one clamp at a time to get the final squeeze out cleaned up. 1 Quote Link to comment Share on other sites More sharing options...
curlyoak Posted May 23, 2021 Report Share Posted May 23, 2021 When I have glue in areas I cant sand, I let it dry for an hour or 2. flexible at this point. Then I carefully clean it ups with chisels and carving knives. When I wipe it when it is fresh I end up filling the wood and the finish shows it. 1 Quote Link to comment Share on other sites More sharing options...
Chestnut Posted May 23, 2021 Report Share Posted May 23, 2021 I just run cutting boards through the planer. Makes quick work out squeeze out. I use a chisel to get the big nibs to get it too sit flat first. But i also use just enough glue to get a tiny bit to squeeze out anything more is just wasted glue and more work. 1 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted May 23, 2021 Report Share Posted May 23, 2021 A paint scraper works pretty well for me, if I can't get the to glue before it dries. Quote Link to comment Share on other sites More sharing options...
Coop Posted May 23, 2021 Report Share Posted May 23, 2021 I don’t understand the dark area the chrome plated bar clamp leaves on the wood where it contacts the glue? 1 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted May 24, 2021 Report Share Posted May 24, 2021 @Coop, most steel / iron clamp bars will react with the moisture and acetate (the 'A' in PVA) in the glue to leave a stain, just like using steel wool & vinegar does. Pipe clamps using black pipe are terrible about it. I use door shims to hold the pipe off the work piece a little and avoid the staining. On high-tannin species like oak, the stain can go pretty deep. 1 Quote Link to comment Share on other sites More sharing options...
Coop Posted May 24, 2021 Report Share Posted May 24, 2021 Good to know Ross, thanks. I’ve used packing tape in the past but it’s a pita. I guess the door shims need to be removed pretty quickly before the glue sets? I have some HDPE that I will cut into thin strips to use in lieu of the shims that might work. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post wtnhighlander Posted May 24, 2021 Popular Post Report Share Posted May 24, 2021 Yeah, Ken. I take the shims out once the clamps are tight, and hold themselves in place. Those shims are one of the most used 'accessories' in my shop. Just this weekend, I was using some to make a toggle clamp hold tight. Much faster than adjusting the clamp. 4 Quote Link to comment Share on other sites More sharing options...
Chestnut Posted May 24, 2021 Report Share Posted May 24, 2021 I put painters tape on the bars of my clamps as well as my pipe clamps. It works well to protect both the work piece and the clamp from the glue. It may not work on all clamps so your mileage may vary. I have to change the tape every other year or there about. a 1 1 Quote Link to comment Share on other sites More sharing options...
Meatwad Posted May 24, 2021 Author Report Share Posted May 24, 2021 @Chestnut, that's what I have been doing but this time the tape came off and glued to my cutting board leaving an awful purple mess. Thankfully that became the bottom side but I think I'm going to have to combine all this advice. Seems like getting to the glue under the clamps after 30 minutes or so is my best bet. Quote Link to comment Share on other sites More sharing options...
Cliff Posted May 29, 2021 Report Share Posted May 29, 2021 On 5/23/2021 at 12:29 PM, Chestnut said: I just run cutting boards through the planer. I have issues with flatness doing that. Not significant, but enough that the feet I put on the cutting boards need shims to sit flat. Quote Link to comment Share on other sites More sharing options...
Chestnut Posted May 30, 2021 Report Share Posted May 30, 2021 19 hours ago, Cliff said: I have issues with flatness doing that. Not significant, but enough that the feet I put on the cutting boards need shims to sit flat. Interesting i have not had that problem. Though I will say i never put feet on my cutting boards, nor juice grooves, not sure if that makes a difference. I like the 2 sided nature, more time between needing to refresh them. Quote Link to comment Share on other sites More sharing options...
curlyoak Posted May 30, 2021 Report Share Posted May 30, 2021 19 hours ago, Cliff said: I have issues with flatness doing that A glob of dried glue will not help to make an accurate thickness. I'd rather sand it off but if I was going to plane it I would make sure the bottom was clean of glue. Quote Link to comment Share on other sites More sharing options...
