Liquor Cabinet for a Friend
gman, your attention to detail is inspiring. When I look at how you make sure everything is aligned perfectly, and the process to get there, it always makes me tell myself that there is no other way. And reminds me that there is nothing wrong with being a perfectionist (as I am always accused of).
Sometimes I ask myself if being so fussy is worth the effort. Then seeing how you do things, and the results, inspires me to keep doing my work as well as it can be done. No short cuts, and no hiding mistakes. Plan ahead, and do it right the first time, no matter how long it takes...or effort involved.
Thanks for this post. Simple joinery, but perfect results. (and a few tricks thrown in there as well) I sincerely hope your vision gets back to where it should be.
  • Replies 135
  • Views 5.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I rip off the excess for the inlays. I didn't purposefully make these this much oversize. It just happened to be the thickness of the blank. I put the cut offs in a drawer I have for random small
  • gee-dub
    gee-dub
    Just hop, skipping, jumping, and trying to get on the train here . . . I am always rattling on about test boards for finishes and wanted to show that I practice what I preach. The right
  • gee-dub
    gee-dub
    Been there, done that.  Mine lives out here now. I am indeed spoiled rotten but, in my defense it took me 20 years to get here
Posted Images
Right back at ya @roughsawn.  I always enjoy your posts and input.  We're all in this together.
I want some sort-of flashy figure for the back slats on the upper portion since they will be more or less on display. I should be able to get 12 slats out of this board and only need 5 or 6. This will let me pick my best pieces.
There is a skinny 1/16" arch (bridge) in this board. I will cut the length in half which will reduce that before jointing and planing. This will still give me about 24" long boards to work with while milling. I try to avoid milling small parts. I'd rather mill portions of larger blanks and then saw off the smaller parts. I'm gettin' old and can still count to eleven. I plan to keep it that way.
I mill the boards at double length. Then, after ripping to width, I set up the sled to cut to final length.
This is a little micro-adjust stop block that you have all seen in the past.
I need to decide on orientation and chalk-mark the blanks so I can keep them in order.
Ta-da!
I use a multi-beading bit that I picked up at a woodworking show back in the mid 2000s. It has been sharpened but the profile is non-specific. That is, it does not interface with another profile so if the sharpening alters the geometry slightly . . . no one cares.
I use the Grr-Ripper to run these thin boards across the feed path.
And I end up here.
I have used this profile for back slats in the past. It is interesting enough without being overpowering.
I will need to rabbet meeting edges to make the half-lap interface that compensates for seasonal movement. Lunch is calling my name.
I have probably shown this before but I have a plastic tube screwed to the side of the jointer. I keep random narrow strips that we all get while milling in there.
I use these to offset the teeter-totter effect that irregular lumber has. Once you get one good pass the rest is easy.
These will be the end panels of the top section of the cabinet.
I usually chisel the squeezeout off of my glue ups after 30 minutes or so. Sometimes I get interrupted and can't get back in time to catch the squeeze out at that perfect leathery consistency. When that happens I whip out this doo-jobber that I made from a piece of scrap and an auto body work file.
It lets me aggressivly take ff the squeeze out without getting the tear out you can get from a paint scraper.
Here's one of those side trips my mind seems to take lately. We live where the earth does the Watusi. Having been born to it we do things without even thinking about it. My vertical lumber rack has a chain retention system in the event that the planet decides to rock and roll.
Nothing fancy. Just a chain with some loops and an adjustable section here and there.
I need four "legs" for the upper cabinet section. I will pull them from these blanks recently cut from a big ole whompin' board.
This gives me these blanks.
I end up with four 1-1/4" square posts that will get cut to length.
Other than that it is just glue-up panel city around here.
This is bloody brilliant.
I'm definitely stealing this idea!!
Thanks Ron.  I just "teeter" the board, guesstimate the gap, and pick a piece of scrap half that dimension.  One pass is usually all it takes to get a good bearing surface so that I can continue milling.
Splitting the difference to take twist out is always one of the great challenges of effective jointing, at least to me.
This is such a simple solution, and a great use for small offcuts that would have ended up in the burn pile
Does the shim slide along with the workpiece and stay in place, or do you have to do anything to keep it there?  What happens when the shim gets to the cutter?
It is at the rear.  It is trapped by the downward pressure from your push pads and gets obliterated as it passes over the cutter head.  I have occasioanlly held it in place with a piece of tape but not usually.
Its sole purpose is to balance out any twist long enough to make a single pass to provide a reliable bearing surface.  If a board is really wonky you might have to do it again.  At that level of irregularity though I would try to use that material for smaller parts to remove the effect by breaking it down into shorter pieces prior to milling.
We've got a lot going on today so these pics are from yesterday. I mentioned elsewhere that I had caught a snow drift of things needing sharpening and finally decided to stop for a bit and take care of that; mostly card scrapers. I use this old sink liner and a baking sheet. I use diamond stones so I just need to sprinkle them with a little water to carry the slurry away.
Ya gotta love a good hook on a card scraper.
Anyway, about an hour later everybody is back on the bus.
Dad's dad was a woodworker, metal worker, jewelry maker, potter, leather worker and an oil painter. He was also a cham-peene dumpster diver. Ya gotta remember this is a man raising two kids during the depression. He would find things that had lead in them, drag 'em home, dig out the lead, melt it down and cast it into sand molds. He used them to hold down drafting paper, leather work, and all sorts of stuff.
My dad used them for decades and now I use them. They are great for holding down full sized drawings, curly abrasives, and other things that want to move when you don't want them to. This time they are holding some sandpaper for my drum sander.
I just use the worn out piece and lay it on top of the new piece as a template. Scribe it with a pencil and cut it with some WISS tin snips that are older than I am.
Use the handy-dandy shop made Jet TufTool.
And we're off.
My design consultant (LOML) took a look at the dyed poplar I was planning on using for the lower back frame and back slats and gave her opinion . . . "NO!". I will remake it out of maple which will give a lighter interior for folks reaching for their tequila or old fashion glasses. You've already seen me make that frame so I won't duplicate it. I did remember to use stopped dados on the upper and lower rails this time though ;)
I have this thing where I will subconsciously notice things and then at some later time it will randomly drop into my mental queue. This causes me to stop and wonder . . . Anyway, I apparently noticed the maintenance reminder sticker under the hood on my drum sander. I realized I missed it during the last run of machine maintenance.
I bought these little "clock oilers" off Amazon for not much money. The short ones are great for router bit bearings. The long ones are great for bushings like on the drum sander and the bearings, chain, and bushings on my router lift; you can reach way in without a lot of fuss.
You've seen me do this before. I use setup bars to set the depth on my wheel gauge. I wheel gauge the backslats since they get rabbets on most edges.
This little guy has been more useful that I suspected. I primarily got it to use on my 'Bench-on-Bench' and it works great there. I find myself reaching for it for other things as well.
I love this little Millers Falls plane for knocking corners off things or doing random edge profiles. I keep it ridiculously sharp and it does a nice job without really caring about grain direction . . . thanks dad.
I tape off the areas that will see glue later.
Then I give all the parts for the lower back a couple coats of shellac.
The color range of walnut is pretty drastic. Even though I have a lot I sometimes have to run to the yard to get a coloration that I just can't find in the racks. This time I found one (the one in front).
When I pull material from the racks I give it a looking over. I mark any tear out, checks, or gouges pretty obviously. I tend to get "in the zone" and I will mill parts only to realize I used a piece of sub-standard material; picture a "Peanuts" style cloud over my head when I realize I have done this . . . "rats".
I didn't realize my bench grinder would be almost in the way so often. Thank goodness I put wheels on my baby bandsaw.
The height adjustable table to the rescue once again. If one of these things breaks I am going to lock the shop, jump in the truck and go buy another one; on sale or not.
This blank should yield the upper carcass rails and stiles as well as the stiles for the lower carcass doors.
Jointed, planed and one edge jointed perpendicular.
Resawn to rough thickness. I will let these guys set overnight to make sure nothing is going to go wonky on me.
I know I said I wasn't going to belabor the remake of the lower back panel but here it is.
I will do the joinery on this tomorrow. Then I can continue with the glue up of the lower carcass. The nice thing about a project like this is it is way more involved than you thought, there is always something else to do while glue dries, and I am excited to get back to the shop tomorrow.
Oops!
When the bin gets too full the spoil just blows past.  It ends up snow drifting outside the DC shed.
I guess you could call this my spoil level indicator :rolleyes:.  There is a near constant breeze where we live and often a decent sort of wind.  Things that are not heavy enough (like the spoil that blows past the cyclone) just seem to magically go away in a few days.
Gotta laugh, not at your forgetfulness, but at how much dust & chips you produce.  Prodigious.
I'm sure I posted a random tip about this thin stock dog at some point in history. Basically you've got a spring controlled dog with a 1/4-20 thread tapped into it and a brass flat head bolt that can thread in and out to set heights.
The spring type doesn't matter; side wire, flat bar, I use a bullet catch.
When not in use this guy sets at the front left of my bench well below the surface.
As usual I over-mark my parts to keep things oriented. These are just rails and stiles but I like to book-match whenever I can.
I had to rebuild the back frame and panel. This puts me in an odd spot since I am now trying to interface to sub-assemblies that are already glued up. I mark a centerline on a half a dozen dominoes, Place tape on the already finished and pre-assembled back panel, and add the layout lines for the mortises.
A double square helps me make a consistent mark on the tape.
I then use that mark to strike a line to the edge.
Mill a bunch-o-mortises and presto.
Now I can get on with the glue up of the lower carcass. Seems like it took me extra long to get to this step.
Not all that exciting but, this thing has been nothing more than a bundle of parts and a vision in my head for the last 30 days.
It is finally starting to look like something
This is a board I had picked out a while ago for the adjustable shelf in the lower cabinet.
Another good use of bar gauges defining the actual width of the shelf cavity.
I break out the blanks that will be used for the shelf from the board.
I will do the usual milling operations.
Time for some glue.
I will let these set over night and gp back at it in the morning.
Cutting the glued up panels; upper top, lower top, shelf and interior bottom, to final size. Some will need profiles. All will need surface prep.
I'm feeling better about this all the time.
The large sled support sure comes in handy. If you have a large sled, do yourself a favor and make one of these if your tablesaw fence will support it.
Once upon a time, many years ago, I had an "incident". It involved me doing some handwork on a carcass. I got over-focused and didn't realize I was nudging the carcass off the work surface. This was a lower cabinet for a hutch and no small potatoes. I managed to react quickly (not my strong point as I age), drop the chisel deftly missing the rubber mat I was standing on and hitting the concrete (add additional time for restoring the edge) BUT, I caught the carcass and it didn't take a full-on header into the shop floor. I learned from this and started clamping a cleat to the back of the work surface . . . but nooo . . . Murphy is alive and well and I almost lost another one. Since then I have clamped what I am working on to the work surface. No dramatic, heart-stopping, failures since.
I rip some of this framing stock to final width as it has been resting plenty long. This piece has way more moving parts than I thought. There is always something else to do.
Anyway, the upper back frame will look about like this.
I mill the joinery for the back slats and the frame. I wheel gauge these things and generally get a good clean cut.
This is a pic with the parts all willy-nilly. I'm just trying to show all the different profiles that go into making this jigsaw puzzle interlock in the end.
Still rough and off the machines. No hand work yet but . . .
I have to run LOML to the dentist. How can I be so busy when I am supposed to be retired?
One of those phases where I feel like I am doing a lot but not much shows. I prefinish the back slats for the upper portion of the cabinet. These get a little more razzle-dazzle since they will be on display as you approach the piece.
I have a selection of spacers for back-slats. These happen to be trimmings off of some 1/8" PVC lattice that I used in the BBQ area.
Everybody is clamped up square and flat.
That may be it for today . . . we'll see.
Another great idea. I like the way they give enough height to grab onto easily.
Agreed - great idea. I find a lot of things are consistent enough thickness for woodworking and worth collecting as spacers/shims/etc. now that I keep an eye out for them.
Ever have one of those days where you feel like you just are not making any progress? I use screen shots from Sketch Up for reference diagrams.
The side panels of the upper cabinet will be frame and panel with the vertical posts acting as stiles. This means some stopped grooves. I do a first run at about 1/8" and then follow up with the full 3/8" depth.
These side panels will mortise and tenon to the back panel frame. This will make more sense later.
Anyway, the joinery goes something like so.
I started about 5am and my back is barking at me. I am taking LOML out for dinner tonight so I am going to knock off (even though I have a lot more I would like to do), kick back for a bit, and get cleaned up for our date.
I do the raised panel profiles at the table saw.
They will nest in the frames like so.
I give them the usual hand tool work.
Looking better.
Ready for a pre-finish session.
This is just the normal protocol to assure that no unfinished edges go peek-a-boo when the weather changes. Everything ends up getting two or three more coats as the client has requested a finish leaning more towards black.  Not black, but brown with a heavy black component.
I love your work gee-dub, and aspire to keep my shop as clean as you and Chet when I'm working on a project. So far I am failing on that front miserably :D
Paul, any time you want to feel better about the cleanliness of your shop, you have an open invitation to check my horror show. Welcome to My Nightmare....
