Liquor Cabinet for a Friend
On 8/23/2026 at 9:07 PM, gee-dub said:
71 year old man .......    Powerman 5000
Sorry but i would have never expected a person of 71 years of age to know who Powerman 5000 is. There are a lot of interesting items in this post but this is the most interesting so far. That band is from my generation and i can count on 2 hands the number of people that would recognize that name. And now i have to go listen to Worlds Collide as it's stuck in my head.
  • Replies 135
  • Views 5.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I rip off the excess for the inlays. I didn't purposefully make these this much oversize. It just happened to be the thickness of the blank. I put the cut offs in a drawer I have for random small
  • gee-dub
    gee-dub
    Just hop, skipping, jumping, and trying to get on the train here . . . I am always rattling on about test boards for finishes and wanted to show that I practice what I preach. The right
  • gee-dub
    gee-dub
    Been there, done that.  Mine lives out here now. I am indeed spoiled rotten but, in my defense it took me 20 years to get here
Posted Images
That and 'Tonight the Stars Revolt' are a couple of my favs.  Dad was a music lover and I grew up learning to listen to almost everything.  I remember as a child going over to play at a neighbors.  I asked him where their stereo system was as it was conspicuously missing.  He pointed to a plastic housing radio on the breakfast table . . . I was so confused.  We learn what we live :D.  Ain't no wrong way, only different ways.
Out of state guests this weekend so trying to get some things done before they get here. A little hand plane work to set the raised panels. This is a Millers Falls No. 9 which equates to a Stanley No 4. I equipped it with an after-market Veritas PM-v11 iron and chip breaker.
Despite taking my time and being careful my recent eyeball problems keep allowing me to miss things (grrr).
Rather than plane the whole bevel down I use a bit of sandpaper to touch things up. These little pieces come from the stubs off of commercial sanding blocks and come in handy for all sorts of things.
Anyway, that gets me from what I don't want to what I do want.
So here are the panels for the frame and panel end parts of the carcass as shown in the original diagram.
Irvingstein Brainwave's (an old college nickname) mad scientist laboratory.
I did end up adding a bit more Transtint brown and black to get the color to smoothly transition from the sapwood (some of which is in this piece) to the heartwood. LOML wanted the color darker anyway so all is good.
I think this color is going to work.
This is just a base coat so that the floating panels don't expose unfinished material through the seasons. There will be multiple top coats.
A side discussion about plane tills broke out a while back and I mentioned that I set my planes on cardboard but did not include pictures. . . . It's like so . . .
Be that as it may; I tend to clamp sub-assemblies to reference surfaces to assure things stay straight and square.
This gives me these parts-of-parts.
Ever onward . . . .
Out of state visitors this weekend so I am squeezing in shop time where I can. Side panel sub-assemblies in the clamps.
We're supposed to do a dine-out dinner tonight so maybe once we get back I can start mortising for the legs . . . Unless they have two-for-one Margaritas in which case I don't go near power tools :D
The panels are set back form the legs by about 1/2". This lets me use brass seup bars to support the panel when the sub-assembly is face down so I can mark the mortise positions.
Face down and ready to mark.
A center rule makes this kind of layout really easy. These positions are not super critical as long as the mating parts line up.
My eyesight challenges continue so more light is good. These little gooseneck LED lights are about $30 a pair and I have been using them as machine lights for some time. I decided to add a couple of positions to the Domino Table. They come with these 3M stick-on metal plates if you need them magnetically mounted to a non-magnetic surface.
It takes "this" which looks perfectly normal to most of you . . .
And turns it into this which is much easier for "ole one-eye" to see now-a-days.
At any rate . . . a bunch-o-mortises.
The legs join to the panel frames like so.
And there you go.
I will knock out the other one and then break for lunch; I've got some pastrami calling my name.
This post is going to wander a bit. Probably because I started before daylight and then had to go take a mid-morning nap. You've all seen this little rig before. It quickly mounts to the disc sander and allows for repeatable angle grinds.
I drew lines in for common angles and these are generally good enough for most woodworking.
If in doubt it is easy enough to check.
Bevel the ends of the legs to avoid spelching if the cabinet is moved during house cleaning.
I resaw some material to make the front frame. Despite having been in the environment for years the material can still exhibit stress release when resawn; very disappointing. This is why we cut our blanks oversize and plan for a certain percentage of spoil in any project.
It is apparently time to have a box-making marathon right after this project.
I am gathering way too much "too good to burn but not big enough to use" stock.
I had clamped the legs together to keep them safe. I am usually pretty diligent about using cauls but apparently got lazy. The amount of time to remove the stain is way more than the amount of time required to grab a piece of scrap for a caul. Why do I do this??? It is one of the mysteries of life.
I started about 5am today and while I was selecting material for the front frame I heard a weird sound. It was coming from my tablesaw . . .
I then realized it was coyote calls and was being carried in from the DC ducting.
The little buggers were out here. Probably hunting the rabbits that live and breed under some of the out buildings. These pictures were taken later after the sun came up. I didn't go out right away since I don't want to scare them off . . . they keep the critter population down.
Anyway, finally got the front frame (basically a face frame but captured between the legs instead of applied to the case) joinery done.
I will glue that up and let it set while I do the back frame for the lower carcass.
A long time ago I was at business meeting at a fancy hotel outside of phenox , Az. It was very hot. As I recall around 115 degrees. Walking from building to building through a glass hallway I noticed in the distance a bunch of large jack rabbits Laying on their backs. Lounging. I asked an employee and it was explained to me that the rabbits were lounging near the line  not to cross to get shot by marksmen waiting for the coyotes to cross the line. The rabbits knew this and were taunting the coyotes.
The back frame and panel will be poplar. I know, boring, but, never seen. I cut some blanks from a board that has been in the racks for years. This will get resawn to yield the stock required.
I do my usual witness marks to track milling progress.
I am after some 3/4" material for this frame and just barely make it.
I think this is a good time to break for coffee.
I will start to make the back slats after I recharge.
I had a brain-fade . . . I should have made stopped grooves on the upper and lower of this rear frame that will capture the back slats. I grab a piece of scrap out of the burn barrel and fill the end of the grooves.
This is to provide better support for the floating tenon joinery.
That done, I glue up and square up the frame. As is my habit I use clamping squares and a reference surface to assure things are well aligned.
You old timers have seen me do this many times. Just in case some visitor wanders in and this is the only post of mine they see . . .
I use stacked feather boards (most of the time) when resawing at the bandsaw.
I use a piece of the stock (or a scrap from it if the actual blank is unwieldy) to set the feather board depth.
If there will be a lot of surface area under pressure at the fence I will add a clamp. This is not terribly tight as the fence rail is an aluminum extrusion. It just adds a bit of friction to assure that the fence does not try to creep on me. This has only happened a couple of times but, I don't have much room for error on this material.
I resaw off a part. This leaves me a part and the blank with one milled face and one resawn face. I plane the blank to provide me with two milled faces once again.
I adjust the feather boards and make the next cut.
The yield is 6 parts with one true face and one bandsawn face.
These are about 1/2" in thickness. I will mill them some more to get the 3/8" back slats I am after.
With the back slats cut to width and length I mill the rabbets. The top has a longer tongue.
The bottom has a shorter.
This allows me to slip the top tongue into the deep groove in the top rail.
This allows clearance for the bottom tongue.
And they slide into position. With the planned gaps between slats there is enough room to insert them all in this way. I use some 1/8" strips to set the spacing.
And I end up with this look.
The white and green poplar will get dyed. This will be the back panel in the lower part of the cabinet behind the doors.
So here is that olive green poplar after a couple of hits with Watco Dark Walnut and 20 drops of Transtint black per ounce.
I'm surprised the color is so uniform across the boards.  I thought the green would show through.
The joy and wonder of dyes versus stains :)  You can still see the variations between the previously green and white areas but as this is the back panel of the bottom portion of the cabinet, behind doors, I am willing to risk it.
I use a lot of offset elevations on a piece.  This means when I am marking Dominoes I have to account for offset and orientation of the reference surface.  I didn't want to go back and erase a lot of pencil marks on these legs so I ran some tape over the area where I will mark.
The mallet is my "micro-adjuster" to align reference surfaces before marking.  In typical Bradley fashion I laid things out too consistently.  Some mortise positions overlapped.  Fortunately I did one test hole that exposed this.  I offset the positions and forged ahead.
I am now getting my first look at the form.
Feels pretty good.  More mortises, more pre-finish, carcass bottom, shelf, top and upper section still to go.
In typical Bradley fashion, it's only 25% of the way done and already looks way better than anything I've never built!
Nice work, sir!!
One of the nice things about using shellac is that once you are done with your primary task you can use the rag or piece of paper towel to wipe service parts around the shop. In this case my crank neck chisel gets yet another coat of shellac on the handle. I do the same for vise handles, hammers, awls, whatever gets a lot of hands-on use.
I have been wanting to try this spline/cleat joint ever since I saw it in an article. It might have been Tim Coleman or someone else but I forget.
At any rate it looks like so. This is just an increase-in-glue-surface type joint when laminating parts instead of dado or dovetail type joinery.  Modern glues are very strong and this joint amplifies the glued surface area.  It does not provide any significant mechanical strength like a sliding dovetail.
A little time and some tape takes a lot less time than trying to clean glue off of clamp bars.
The humble hand screw serves as a third hand yet again. It is interesting how we each develop our own methods of accomplishing tasks. After a decade or so of doing things we just "do them again" and hardly think about it.
The straw trick, courtesy of Timothy Rousseau, is a great way to take care of squeeze out in inside corners. You can see it here at about 10 minutes in. Works great. I also have used his tip on the acid brush with the bristles cut short.
I have heard people ask me (for 20 years) why I have so many clamps . . . well . . . .
On 9/8/2026 at 12:28 PM, Beechwood Chip said:
Feather board behind the blade?  Do you worry about pinching the kerf / blade?
I am not exerting that amount of pressure after the blade.  I certainly would never do even light pressure at or after the blade on a tablesaw for a through cut; OK for a dado.  It is all about stabilizing the material to help make the cut as smooth as possible.  When I have plenty of material or for secondary woods I will often just hand feed resaws.  The double/double feather boards are for when I have specific stock that I want o milk the maximum yield from.  I also keep a Woodslicer band on hand for times I cannot spare even a little extra spoil.
109 degrees in the back yard today so I didn't feel much like pulling weeds or transplanting plants.  I did manage to drill some shelf pin holes.  I clamp a couple of stops onto the side panels to help my old arthritic hands keep things lined up.  This Kreg jig was on clearance at Lowe's so I snapped it up and it has proven to be my preferred jig for shelf pin holes.
And we get some nicely aligned holes for the shelf.
Time to add the front frame.  I (almost) always do a dry run before a glue up.  This takes all the stress out and makes sure I have everything I need and everything right at hand.
A bunch of glue, some floating tenons and a ballet dance to make Mikhail Baryshnikov jealous.
As long as I am done for the night I lay another color coat on this poplar back assembly.
Even though it is the back of the lower compartment and is behind doors I want it to match the walnut as best as possible.
I found a good candidate for the lower cabinet "top" after digging around for a while. I want to take the whole top from this board so that I have a good color match without a lot of fooling around.
The board had a long check at one end but I was able to take advantage of that since the overall board is plenty long and wide for what I need. I jig saw the blanks to general length, then I used the bandsaw to remove one side of the check area.
My overall depth is 17". I will use one narrow board (from the check area) and two wider boards. I go ahead and mill the narrow board first so I know what I am working with. I get a solid 3-1/8" piece.
Now I can select the parts of the remaining wider blanks that will make my 17" deep top. This will let me get rid of the sapwood.
I'm not against sapwood and often use it as a design element. It just doesn't fit with this piece since it will be colored pretty dark (per the client).
So I think I have my "top" selected.
I get the boards glued / clamped up
Some material that I want to use up for some no-show parts look a little rough.
I use epoxy to stabilize them.
I have another board for the bottom of the lower unit . . . I may need to contemplate using this for the top of the upper unit. We'll see tomorrow after coffee.
I have sort of gotten into this rambling discussion format in my journals. If something passes by that you want more info on just post in the thread or PM me. You know me, I'm more than happy to talk about it :). I brain-faded last night and forgot to fill this void. I am using a couple of questionable pieces of material but, they are for the floor facing surface of the bottom of the inside of the cabinet. I thought I would be milling and gluing these parts up but now I guess they will wait till tomorrow. No worries, I have plenty of other stuff to do.
I started milling the parts for the top of the upper portion of the cabinet. The material was not feeding well all of the sudden. I couldn't remember the last time I waxed the planer which almost assuredly means it is time. As always, de-energize your machine before you stick your hands into it.
I wasn't milling any challenging stock so the degraded performance told me quickly that the machine needed some love.
Wind that table down (or cutter up as is appropriate. You want lots of room for this procedure. If you have never raked the back of your hand across a cutter head . . . believe me . . . you're not missing anything.
The beds looked and felt OK. I went at it with a little mineral spirits and a paper towel . . . ah-ha!
Tools of the trade.
This is just a gratuitus picture to make me feel good about my efforts. The table looks essentially the same.
At any rate I got the top parts milled.
I will rip the desired meeting edges and glue them up.
