Liquor Cabinet for a Friend
There are a lot of ways to assure that your drill press table is level and perp with the quill and I have probably tried all of them. I read a lot of posts about not trusting your 'tilt box' but I have been using the Beall version since around 2005 and have never had a problem. A piece of drill rod is inexpensive and very reliable.
I was trying to post a link but unfortunately, like many quality products, it has gone "unavailable".
At any rate, I'm glad I bought a spare. Check for perpendicular at the compass points.
You have all seen me use this push pad for router operations, It supplies a backer. You use all four corners until they are unusable, you cut the pad down a bit, rinse and repeat.
Once it gets used up you move the handle to another pad.
I have a grip of particle board courtesy of a dumpster dive. You just have to cut the blanks so that they are dead square and use them up.
Meanwhile back at the project we are here for . . . . I am ready to start slapping on finish and so will need a lot of surfaces to hold parts. My non-adjustable rolling table is at a good general height. I want my parts a bit higher and so use the torsion beams we have all seen before.
When LOML is at Wal-Mart or wherever shopping for the latest who-knows-what I cruise the clearance racks. When I see shower curtain or table cloths at stupid cheap prices I see "disposable drop cloths".
I have the bottom, shelf, and top of the lower cabinet as well as the top of the upper cabinet that I want to deal with first.
I will do the undersides first (queue the chicken sounds: bawk, bawk, bawk).
This is a lot darker than I normally finish walnut but the piece will be adjacent to some "kona" finished built ins; the customer is always right.
I'm gonna let this settle in, make sure I'm happy, and then move on to the carcasses and doors.
  • Replies 135
  • Views 5.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I rip off the excess for the inlays. I didn't purposefully make these this much oversize. It just happened to be the thickness of the blank. I put the cut offs in a drawer I have for random small
  • gee-dub
    gee-dub
    Just hop, skipping, jumping, and trying to get on the train here . . . I am always rattling on about test boards for finishes and wanted to show that I practice what I preach. The right
  • gee-dub
    gee-dub
    Been there, done that.  Mine lives out here now. I am indeed spoiled rotten but, in my defense it took me 20 years to get here
Posted Images
Hang on to your long mitered cutoffs.
I use them like so.
I feel like this coloring is really dark but I get what she is going for.
I do enjoy being able to cut off 1/16" slices whenever I like. I have used a lot of blades over the years. The most economical blade turns out to be the most expensive. A Laguna Resaw King on a Tia-Chi Grizzly G0513 series.
Once cut to thickness and width dimensions I crosscut to length.
Back in the early 2000s my dad and I went to a woodworking show. I picked up this set for about $4 a bit.
The shop made micro adjustable stop comes in handy once again.
These are the parts I need for the design I decided on.
I saw some relief cuts as I am going to go with exposed sliding dovetails.
I failed to get any "in process" pics but you guys have seen me use this router table sled before.
So I get these.
I use the tenon jig to cut the mating parts. I test on a piece of scrap saved from when I was milling the blanks.
And I get to here. Now that I know the settings are correct I can cut the keepers and move on.
On 10/16/2026 at 6:48 PM, wtnhighlander said:
@gee-dub, do you have any particular logic for keeping the groove width to what looks like a single pass of the bit? I feel like my OCD would have demanded a tail closer to 1/3 board width where it meets the shoulder. Symmetry is sometimes my downfall...
I doubt there is any real logic :D.  I put the center line of this particular dovetail at 1" from the edge.  The material is 13/16" thick so it is pretty stout for the 21" run between verticals.  The dovetail groove is 3/8" deep x 3/8" wide at the widest part.  I tend to make them a little snug so that I have to tap (and I emphasize "tap") them into place with a dead blow. This combined with the wonderful characteristics of our modern adhesives seem to do the trick.
This one has been in place for over a dozen years, is quite heavy and shows not signs of giving up the fight.  Just as with any panel connection I glue a portion of it ( on this case the front 2 inches) and leave the balance to "breathe".
We all get to fail along the way and get to learn from those struggles.  That certainly doesn't mean I've run out of ways to fail (if only) but I am rich in the opportunities to continue to learn.
Endeavor to persevere :).
I save left over cove moldings for the same purpose.
@wtnhighlander - I think I wandered off topic in answering your question.  A 14 degree bit would have given me a better visual balance but my 14 degree bit is pretty thrashed.  I'm sure I have a spare somewhere but stumbled over the Stone Mountain set (Peachtree's store brand, not sure who makes them) while looking and just went with it.  The DT does look a little small due to the thicker material but is mostly a decorative element.
The sliding DTs are just mating a couple of small verticals to a moveable horizontal shelf for drinkware.  There will be no pulling stress on the joint and very little lateral stress in use. This is one of those things that will make more sense when you see it.  I always appreciate all the comments and sharing of experiences.  I have changed my approach or methods more than once thanks to the input here :),
Sorry gang. I have been a bit of hit and miss lately. Lots of good family get together's going on and I always treasure those. Ignore the hand plane. It just happened to be setting there. This is the 3rd lacquer coat for the bottom of the lower cabinet. I wanted to be sure it was pretty tough since they will be storing liquor down there.
The free-standing shelf for the drink ware is pretty simple; two verticals via sliding dovetails to a 22" horizontal. No rocket science but sometimes the simplest things are the ones that trip us up.
I use a piece of like-scaled scrap as a backer to set the profile.
I end up here. I didn't take enough pics but basically the first third of the sliding dovetail gets glue. The act of assembly pushes the glue through the joint.
The Mark-J version 1 glue top popper comes into play again (named for the man who suggested it to me).
Too many clamps? My rule is that if I have 'em I ought-a use 'em.
I apparently did not rub down aggressively enough on these pieces so I will have to give them at least another 24 hours to cure. It's one of those things where you have a window about 20 minutes and if you miss it, you have to wait 48 hours.
Other panels getting additional coats.
The upper carcass getting its initial coats.
And I still have to address this beast.
It is not all that large. It just has a lot of elevations and I keep putting it off.
So when I apply this mixed finish I walk away for about 20 minutes (thank you phone timer) and then come back and wipe it down. The resultant amount of finish wiped off looks about like this.
The finish in this case is my usual plus some black dye. I also up the mineral spirits to get the dye to seep deep into the material. I am not using any Japan drier or additional metallics as the weather has been dry and hot lately. With this kind of mix you do need to keep the finish well mixed. I tend to shake the pee-wad out of it before uncapping. Then I use a Popsicle stick to keep things mixed as I go along.
I also learned long ago (you can watch numerous YT videos on this) that high VOC materials create their own temperature when they cure. Don't be one of those poster children for spontaneous combustion due to oil conversion tragedies. I keep a pail of water nearby and toss my spoil in there. I always put the lid on before leaving the shop for lunch or whatever.
I haven't used these for a while but they have a storage spot over under (wait, is that a line from the movie 'Airplane'?) the saw horses.
Look Ma; I'm on top-o-the world!
At any rate, an assembly of various shop fixtures lets me support this carcass at a good height for working.
I encourage everyone to make shop fixtures that will help you out, store efficiently, and do double-duty.
Cue Bill and Ted's Abraham Lincoln . . . "Party on Dudes!".
I didn't realize this was your own invention.  Kudos!  Was this recently published?
I missed that - thanks for pointing it out. Very cool!
Gee-dub, several years ago you gave me this idea and I have used it many times and I am sure will use it in the future.
I was installing mechanical drawer slides that were on the bottom which caused me to lie on the concrete floor. And gee-dub gave me the answer. One of many answers. Thanks Gee-dub!
It is an extra bench when needed. If not needed it disappears. Perfect for a small shop.
Thanks Guys.  @Mark J - It is from an older ShopNotes from back when they were originally published.  You may notice that after I had submitted the idea I made a field modification that is not shown in the plans. I cut an arc on each edge that contacts the floor in the tall and short configuration.  This creates "feet" of a sort at each corner.
I found the long straight edges were problematic on the uneven garage floor of the old shop.  I kept the straight edges on the top positions for each configuration since I sometimes use the torsion beams instead of the flat top.
These pics are before the arcs but you can see them in the previous pics. I am glad some of this stuff sparks conversation and ideas.  I find many woodworkers have all sorts of ideas rattling around in their heads.  I know I have certainly benefited from many of the things others have shown.  Glad to give back a little.
Me too...
Dealing with some appliance issues but, let's get back to the fun stuff. You would think with all these shorts and cut offs I would have one lousy piece of Peruvian Walnut that I could get a couple of handle blanks out of . . . nope image.gif.71a1c8ee2477561aa25c1ebff4523fbf.gif .
I did pick up a piece of purple heart that I will use for a bit of inlay on the pulls as the unit will go against a purple-ish accent wall.
I pull a piece of Peruvian Walnut out of the rack and select a section.
Here are my pulls.
I was never a very good student and sometimes layout can make my brain hot.
One of the weight plates I use as a hold down turns out to have just the radius I am looking for.
There will be a couple of 7/8" Forstner holes that will get connected to the outside world via the bandsaw.
I set up some stops that let me do all the holes pretty quickly.
So I end up here. The smaller arc is just free-handed in.
There will be some more machining before I cut the arcs. This will be a groove to allow the purple heart inlay to set in.
I cut some purple heart 'slips' to use as inlays.  The low profile stop comes into play.
I cut the grooves in the blanks before cutting the arcs. I notice that I cannot get the inlays to fully seat. The light bulb goes off . . . I have a glue line rip blade that has a triple chip grind tooth in the pattern, the other is FTG. I was using the triple chip grind blade. This leaves a ridge that is of no consequence on a through cut but for grooving??? . . . Not so much. Fortunately I had a 3/16" cutter for my router plane on my Christmas list years ago and my daughter came through.
Flattened the bottom without issue and glued in the slip.
I have a pair of twin screw vises on the bench and used them to assure a warm loving hug on these parts.
Once the arc is cut, if things are not well seated it is on display for all to see.
The lower carcass has gotten a second coat. Shellac inside.  Oil:varnish bland outside.
His buddies are on their last coat.
Final assembly is at hand . . . OK, I'm exaggerating . . . it will be several days yet. I love the look of oil blend finishes but, they cure by chemical process. That is a double edge sword . . . on the one hand they will not wait for you so be diligent. On the other hand they are done curing when they are done and all you can do is wait or find something else to occupy yourself with
I put the cut offs in a drawer I have for random small exotics and figured material.
When setting the inserts I am always concerned about blowing out the "show" side. There are a few ways to take care on this. I can measure the height of the insert.
Thereby giving me a telltale on the tail of the micrometer.
If this fits the depth without exceeding the layout, you're good.
If you really trust your depth stop you can just use the hardware to set the depth.
Of course you always de-energize your meat eaters before getting your pinkies into the danger zone.
Once unplugged I use the drill press manually to set the inserts. This helps me assure that they are square and perpendicular to the material.
Ta-da . . . I really need to stop saying that.
I rough out the other waste.
A trip to the spindel sander brings me in to the line and a trip to the router table rounds things off. I end up here.
And in position it looks like so,
The door does not have the final finish coats on and will darken for a better match.
This poor thing has really been dragging on. In my defense some rainy weather (super rare around here) and a lot of birthdays and anniversaries have created breaks in the flow. I mean we just had a big get together and there is another on the 9th and one on the 11th. Then Thanksgiving and we roll right into Christmas. I am not complaining. I love the fellowship of friends and family. I just really want to get this thing done before the holidays set in ;-)
I've gotten pretty good at guessing how much finish a project will take. I will use this last couple of ounces for any touch-up after assembly.
I am taking care of a few details today. The top fasteners for the upper cabinet go on.
Here's one of those things you do without really thinking about it. Since I do a lot of pre-finishing of some components a bit of marking makes things go back together more easily. For example, I use a striking knive to mark the centerline of the upper cabinet and its top at the rear of the piece. I mark the line with a fine point felt tip pen. When the final assembly occurs you just line up the marks and screw it down.
And you end up here.
I just realized I already posted the pulls but, here you go again.
The little shelf that will stand on top of the lower cabinet and inside the alcove created by the upper is not attached. This lets the client position it left, right, or center as they see fit.
I put some low profile stem bumpers on the bottom of the side panels to keep things from sliding around or marking up the top surface. That's about it for now.
Grrr . . . I went out this morning expecting to start final assembly. I had laid the upper cabinet face down to do some final details on the back. I was not diligent enough about assuring the surface was clean. There was a bit of schmutz on the surface and of course the front leg sat right on it. While I happily moved the upper cabinet about while putting the finishing touches on the back (that no one will ever see anyway) I scratched the front of the leg up pretty good. I sanded it back and reapplied the finishing protocol. All will be well but I just cost myself a couple of extra days image.gif.07c812738272ae343107a01add82f1f4.gif:(
One of the greatest inventions since the wheel??? The folding ruler.
With extendable depth extension.
One of those tools from times-gone-by with super usefulness.
I believe in Lufkin! From habits of the past when working in a large production shop, I wrote my name under the sliding rule to keep the thieves at bay. I use my folding rule more than any other tool. I have a collection of old ones for loaner purposes.
I keep a 2', 4', and 6' level on magnetic hooks on one side of a cabinet that is out in the parts storage area.
I find things like drawers, doors, and table tops all go on more reliably if your assembly platform is level with Mother Earth.
Some times a small wedge is needed. What's the old saying? Give me a lever long enough and a fulcrum on which to place it, and I shall move the world.
I do the layout for the door pulls.
I have found that a bit of light colored tape serves me very well for this.
I want that center "foot" to stand dead center on the mid-point panel stile.
Feelin' alright.
A bit of paste wax on all surfaces except those that are lacquered for "service". That is, the lower cabinet top where one would pour drinks and perhaps spill and the upper top where one might set drinks that are ready but also spill. These surfaces have four coats of lacquer to survive the tequila and Russian vodka that may find its way onto their surfaces.
The doors are waxed out. What a lot of nooks and crannies they have.
The bottom cabinet gets waxed.
The handy-dandy door holder thingy comes into play once again.
It is surprising how quickly something that I have been dinking around with for 2 months suddenly jumps together once all the "to-do's" are done.
