Liquor Cabinet for a Friend
Sometimes a "clean" shop is all in the camera angle.  When I am mid-project things get pretty hairy.
Just some random stuff here during the slow visual progress phase.  I use a 1-2-3 block to transfer marks for mortises.
If you don't use abrasive erasers, shame on you.  Subscribe to Peachtree's emails.  They have sales on these a few times a year for a good price.  They are definitely less costly than replacing abrasives more frequently.
Keeping things clean with an occasional treatment really stretches my abrasive life cycle.
  • Replies 135
  • Views 5.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I rip off the excess for the inlays. I didn't purposefully make these this much oversize. It just happened to be the thickness of the blank. I put the cut offs in a drawer I have for random small
  • gee-dub
    gee-dub
    Just hop, skipping, jumping, and trying to get on the train here . . . I am always rattling on about test boards for finishes and wanted to show that I practice what I preach. The right
  • gee-dub
    gee-dub
    Been there, done that.  Mine lives out here now. I am indeed spoiled rotten but, in my defense it took me 20 years to get here
Posted Images
I cut the mortises, add the floating tenons, and glue it up.
While I watch glue dry I will edge-treat the two tops. I suddenly decided that the piece was just too rectangular. I will arc the fronts of the two tops and will "oval edge" the fronts and sides. I use a drawing bow to layout the curves. I have a commercial one and a few shop made. If you have some old tempered hardboard or 1/4" MDF laying around they are pretty quick to make.
And they store in very little space; always a bonus.
I lay out the arc, cut the bulk of the waste at the bandsaw, and move on.
I fair the curve roughly at the edge sander.
I have heard these bits called by different names but Whiteside calls it an oval-edge.
I clamp a bit of scrap from the bandsaw operation to back up the exit and avoid blowout.
The long edge can be done several ways. I seem to get away with using the router fence faces as guides.
I run the piece across the two contact points. This requires a little finesse but after you screw up a few times you get the hang of it.
I get through the two tops with almost no trouble.
I was getting ready to spoke shave the lower cabinet top and noticed I had gotten a bit of tearout on the underside.
I fill this with Timbermate and will dress it in shortly. Timbermate is like BLO; it is the woodworkers miracle drug. It is easy to work with, reconstitutes with water until top coated, takes dyes and stain well. It does everything you wish a filler would do. I posted as fast as I could but the piece I filled is probably ready to be worked right now. Ya gotta love it.
What do you do to get a color match with Timberlake?  I see it comes in about 10 colors.  Do you use them all, a few, or just one?
I keep 'cherry', 'walnut', and 'neutral' on hand.  Walnut can sometimes be too dark, cherry too light, but you can always add a drop of dye to neutral.  For this finish, which leans from brown toward black, the 'walnut' was perfect right out of the container.
Does anything in the shop feel as right as a smoother on walnut?
OK, maybe a smoother on cherry but . . . ahhh.
Easy clean up too.
A raking light is always your friend. It takes so much less time to double check your surface than to try to fix a post-finish scratch or ding.
Even though it will face the wall I dress up the back of the upper cabinet as well.
Grandpa's 'Plumb Tools' awl has been re-pointed so many times it may be on its last legs after three generations.
I use it to dimple holes to help me guide the Forstner bit that sets the recesses for the figure 8 connectors.
I make sure things are centered and the cabinet is square and level before marking the holes on the underside of the top.
A drill guide helps me keep my aim true.
It also acts as a depth gauge in this case. Nothing worse than drilling out of the top of your . . . er . . . top.
So visually not much change but all surfaces are prepared for finish.
I just need to make a final decision on how I will attach the upper cabinet to the lower. Since the corner posts align (blocking access from below) I will probably go with threaded inserts and flushed bolts up from the bottom of the lower cabinet's top. We'll see. I have to knock off for now as I am on task for roasted veggies for dinner tonight. Gotta get to choppin'.
I keep the same less neutral and plus white and red oak. They all dry out . I add a few drops or more of water to the top layer and work it with a putty knife. Prepare as much as needed. It will dry out anyway. Water base but all types of finishes work fine.
I keep mine in a "Foodsaver" doo-whopper.
I have been using the same three little containers for well over 10 years.  It is cool that the product will re-emulsify with water.  I have hit hard layers in the little containers and run a teaspoon of water in, mixed it with a spatula and all is well by the next time I need it.
Here is that Timbermate repair prior to final surface prep and finishing. I feel pretty comfortable that it will be invisible.
I keep squirt bottles of shellac and DNA on hand. One bottle is Seal Coat right out of the can (2lb cut), another is out of the can hit 1:1 with DNA. This is the mix I use most. I use it to seal interior spaces to avoid odors, make clean up easier, etc. Anything that is going to store clothing either gets no interior finish at all or a light coat of 1:1 shellac. This cabinet will store liquor so basically, food items. So I seal it on the inside. The oil varnish blend and lacquer top coatings will take care of the outside.
Oh, I also cut paper towel rolls into 1/4's at the bandsaw. I use these for all sorts of things. Finish application, clean up, whatever I need a bit of towel for without using a whole sheet. This isn't me being cheap. I just had a few incidents where I used "the rest" of a paper towel that was laying around only to contaminate my piece and make me a lot of work. At Costco prices I will use these little piece and throw them away in droves so I always have a clean piece.
No voodoo here. Just a light seal coat of thinned shellac.
I just noticed you can see a trace of the layout triangle in chalk that didn't quite get cleaned off. The Seal Coat will take care of that too.
Trying to finalize the method of securing the upper cabinet to the lower.
I lay tape on the inside and outside surfaces of the lower cabinet's top. Position everything and add layout marks.
That all looks like so eventually.
I use a bit of coat hanger to confirm my screw path that will anchor the front posts of the upper cabinet. From the top (laying on its side).
From the inside (still laying on its side).
Years ago I added draw catches to the adjustable rolling tables.
This lets me hook them together to increase the working surface.
I mis-measured or miscalculated my angle. At any rate the screw path under the lower top passed through one of the top rails as opposed to just coming right out of the top. Rather than drill more holes I grabbed a hand gouge and cut out a little pocket for the screw head.
The screw enters from below the lower cabinet's top, passes through (now) a bit of the top rail of one side, through the top, and enters the upper cabinet front leg like so.
This is just to secure the upper. You would not want to try to lift this thing by the upper. The connection at the rear is more basic and boring.
But, it is starting to look like something. I think I am ready to finally start on the doors.
I'm after some material for the door rails and stiles so I have to go digging.
I find what I am looking for and layout some parts.
I cross cut into the board with a jigsaw and then rip the blanks off at the bandsaw.
And a few more.
These will all set aside to rest.
I have a piece of reddish walnut left over from a media cabinet project. I have been looking for something to do with it . . . maybe this is it.
The layout may look odd but, I want what I want ;-)
Here is my yield; keepers on the left and spoil on the right. Definitely some box parts in that spoil ;-)
The material is only about 13/16" so I want a thin kerf bandsaw blade for the resaw. I've got a few to choose from but the Woodslicer is my go-to for this sort of thing.
ALWAYS be sure your machine is de-energized before you get your hands into the meat-eating parts.
A blade change from one 1/2" blade to another only takes about 5 minutes. The only change in this case is tension.
This is the general appearance (book matched across both doors) that I am after.
I still have concerns that the material may be too thin. If that turns out to be the case I will go digging again for some interesting material that will yield thicker panels.
Thanks all. I cut the door stiles to length. All door parts have already been ripped to various widths.
I flip them this way and that and decide on an appearance I like. Then I flip them over and mark them with the ever-faithful cabinet maker's triangle.
Once I am well along I take measurements from the piece as opposed to from the plans. Ruler stops or bar gauges are great for doing internal dimensions.
I generally cut internal parts a smidge large and then shoot (shooting board) to final.
I have a little vise on the end of my outfeed table. I have a better vise that I have been meaning to put on for years but this little cheap-o keeps doing the job so . . .
I hardly take off any material but . . .
In the words of Ace Venture "like a glove".
I finish laying out the tenon positions.
Cut the mortises and away we go.
I need a break but, hope to get back to the grooves and panels before I quit for the day.
For some reason I lost track of this project.  But I just enjoyed catching up will drinking my second cup of coffee.  Great work as always Glenn.
Every time I see you using your edge sander it makes me wish, once again that I had the floor space for one in my shop.
@Chet - We all have those tools we get the most use out of.  I gave up on the SCMS long ago; too big of a footprint for what I got out of it.  Left me room for the edge sander and a drum sander.  Other people couldn't get along without a RAS or a SCMS and more power to 'em.  We all have our methods and preferences.  What works for us, works :)
I wandered off . . . I hate it when I do that. Seriously we had some family get together's and neighbor gatherings that were great. Now where did I leave off? Oh yeah, grooves for the floating panels.
Unfortunately the figured material I had planned (and really wanted to use) for the door panels did indeed turn out to be too thin for my comfort level. Sometimes we have to make decisions on 'what is' as opposed to 'what we wish it was'. I choose some thicker replacement material. A couple of framing squares can help you picture the portion of the material you want.
I cut out and mill the new panel material to rough size.
I finalize dimensions.
Always good to have piece of scrap to test joinery and fit.
Seems like it took forever to get here. Probably because I had to remake the panels.
At any rate I get the fit and look I am after.
I will surface prep and pre-finish the panels and move along.
*** UPDATE *** Dear Mods, I accidentally cross-site posted the pics in this post . . . I fixed it.
For people who have given up their chop saws, what do you use to make 90° cuts in long pieces?  Track saw?  Hand saw?
Table saw is not great for cross cutting long pieces.  Band saw doesn't have enough clearance between the blade and the riser.
I'm picturing cutting a 10' board in half, or into 30" pieces.
It would be great to ditch my chop saw and get back that floor space.
Totally agree.  I rarely cut anything longer than about 60" when building furniture.  When I need to trim out something with long thin stock I walk about 45 feet to one of the outbuildings and grab my CMS / stand.  We all have different needs.  The last time I used the CMS was probably 3-4 years ago but (like long pipe clamps) I am darn glad to have it when I need it.
This is why our shops and tool selections vary so much.  There's a zillion ways to do woodworking and we all gravitate to what works for us and how we do things.  For long stock crosscuts I just use a jigsaw and cut a little oversize.  Once the blank is created it is generally 60" or under so I just use the tablesaw and a sled.
Depending on how rough the lumber is and how precise I'm looking to be, I'll use, from rough to precise, hand saw/jig saw, track saw or Kapex. Also depends on how big the wood is - my Kapex isn't set up to handle>4' well. I use it mostly for precision work.
In the past I struggled with cutting lo0ng and wide pieces. If I had the money and space I'd want sliding table saw. So I got an incra 5000. https://incra.com/miter_gauges-miter5000.html With the tool I am able to cut plywood bulkheads for cabinets. Roughly 23+"X  35" is easy. With reliability I can cut several pieces all square all the same. I can cross cut 60" long plywood. I am restricted to 60" due to space. For lumber I have a 12" delta radial.
The 5000 is a lot cheaper than a sliding table saw.
Thanks to gee-dub for tolerating this conversation in his build thread and thanks to everyone else for sharing. I find it easy to get set in my ways and very useful to hear all the different ways things can be done.
My perception is that gee-dub encourages ideas and thoughts. Thanks gee-dub!
Thanks guys.  I do blather on a lot and hope that something will help someone along the way.  I know a lot of what I have learned and ideas for tricks and tips in the shop have occurred outside the main theme of someone's thread I am reading.  I will see something in the background of someone trying to show a dovetail technique and say "hey, what's that?".  :)
My last couple of threads have been a sort of rambling discussion of everything that goes on.  I think some of this is due to my declining eyeball health; it slows me down.  I can only spend a few hours in a row in the shop anymore.  I'm an antsy sort of guy so I would go dawn to dusk a year ago.  I have learned when to stop because tired eyes and meat-eating machines don't go together well.
I hope to finish surface prep and pre-stain on the door panels today that I thought I would finish yesterday <_<.  It's a good thing I don't have a day job anymore or I'd never finish anything. :D:D:D
Sorry, there are some gaps here . . . I sometimes try to over-engineer things and end up with tolerances too close for comfort. In the case of these floating panels the solution is to decrease their dimension by a "smidge".
I mark them with the edge of a white pencil which is about 1/32".
Then I sand that off each edge at the edge sander. Following assembly I need to treat the edge profiles of the door frames. I use part of a large round over profile to get the door edge treatment I am after. Obviously I change the throat plate.
Sometimes I want a good amount of clearance for spoil removal. Other times I want t tighter fit to help with a clean cut. It all depends on the material and the profile being applied.
I have various throat rings stepped in eighths with some in between like a Porter Cable Template collar size. I also have a solid which hardly ever gets used since I use the router table so much.
For the big-ole-whompin' round over bit I slow the router down quite a bit. This helps prevent burning or tear out as I cross from edge grain to end grain during the operation.
I got called away for lunch so as I often do (although sometimes not enough) I leave a post-it to remind me where I left off and where I am picking up when I return.
I end up here right off the machine after lunch. I will probably cut the cup hole hinge positions before I finish the surfaces on these. That way if I bump something I can fix it before final surface prep and finish application.
As a side note, I am still messing with the spa and so have to stop for now to try to get that bad boy primed before dark. It is being a real pill about it this time around.
How is your eyeball doing, @gee-dub?
@Mark J - PM sent.
Back when I was knee-high to a grasshopper my dad gave me an old shop knife. I still have it. I put 3 or 4 layers of abrasives on my rubber blocks and my Preppin' Weapons. When the current layer wears out I slice it off.
I pull the tabs that are left over and save them.
I made a little holder for my rubber blocks and so added a little index for my scraps as described. I use them for all sorts of random jobs around the shop and then toss them when they are done in. I'm a child of the 60s and it makes me feel good to milk one more use out of things before they get trashed.
I use this cup hole jig. It is not super sophisticated but I don't do many cup hole hinges :)
It has a vac hook up and does pretty well.
The door-holder-helper-thingy comes in handy once again.
Ta-Da.
So moving along. It is funny how you tend to think you only have 4 or 5 more things to do only to realize you have 24 or 25 more things to do <_<
