Brendon_t Posted November 5, 2014 Report Posted November 5, 2014 My wife asked me to make 7 cutting board for her to give as xmas presents/ auction one off at a charity event. I have never sanded down an end grain board with only a ROS until today and its killing me. My buddy who's drum sander I normally use is away for a few months so I guess it's hours of sanding for me. . How aggressive do you guys normally go on starting grit? 150 isn't cutting it. Quote
..Kev Posted November 5, 2014 Report Posted November 5, 2014 Until I got my drum sander, I would start at 80 grit on end grain boards.. You might try a local cabinet shop and see if they can run your boards for you for a minimal fee.. Quote
Eric. Posted November 5, 2014 Report Posted November 5, 2014 I wouldn't even bother making an end grain cutting board without a drum sander unless you don't mind a wavy surface. I was never able to get them dead flat with a ROS no matter how long or hard I tried. If you're able to do it then I want some of your magical powers. I ended up taking my boards and a six pack to a buddy who had a drum sander until I got my own. It may sound crazy, but I might try flattening with a super-sharp LAJ before sanding...if you're really determined to get it flat. Quote
chefmagnus@grics.net Posted November 5, 2014 Report Posted November 5, 2014 I start with 40 grit on a belt sander and move up throught 80, 100, and 120 then switch to the ROS with 120, then 150, 180, and 220 grit Quote
Brendon_t Posted November 5, 2014 Author Report Posted November 5, 2014 So I see my aggravation is warrented. I know it's 150 but I don't feel like I'm making any headway. I think I'm going to call my buddy and see if there's a spare key to the shop around in exchange for filing the beer cooler up. If taking over the shop doesn't happen, I'll pick up some 80 and start again. And eric, I don't own a low angle Jack. Just a #5 and a block plane and my technique on both is still questionable. Quote
..Kev Posted November 5, 2014 Report Posted November 5, 2014 Yep.. Looks like a daunting task for an RO! Quote
tcarswell Posted November 5, 2014 Report Posted November 5, 2014 I start at 60 in aggressive mode with my 6 inch ros. I really want a drum sander bad lol Quote
Trip Posted November 5, 2014 Report Posted November 5, 2014 ==>guess it's hours of sanding for me I'd contact my local cabinet shop, stair builder, etc and ask them to run the cutting boards through their wide-belt. Before I got a wide-belt, that’s exactly what I did. I found all my local shops to be very accommodating. A few tips... 1-be ready to go when you hit their driveway. No screwing around. They probably won't charge you a dime, but remember their time is $$. Remember to scrape all glue/tape/etc prior to arriving at their shop... Wide-belts and glue lines don't mix.. 2-offer to pay. if they won't take payment, offer to contribute to a new belt 3-keep your eyes and ears open -- you can learn a lot from pros by just watching their workflow and how they manage the machines... 4-call ahead and ask them when would be a good time. You should work to their schedule -- they don't care about yours. I usually had to schedule a couple of weeks in advance. They will accommodate you when there’s a lull in their work. 5-call right before you leave for their shop... they may have gotten busy and need to reschedule. 6-don't offer to help. You're a liability as it is... Don't compound the problem. 7-just ask them to run the boards on both sides just to level and remove burn marks. They may offer to swap belts and go higher, but that's more of their time (and belts). Once they get them flat and burn free, thank them and go... There are a bunch more, but those are the highlights... good luck. Quote
Eric. Posted November 5, 2014 Report Posted November 5, 2014 Trip had wine tonight. Election party with the girls? Quote
Brendon_t Posted November 5, 2014 Author Report Posted November 5, 2014 ==>guess it's hours of sanding for me I'd contact my local cabinet shop, stair builder, etc and ask them to run the cutting boards through their wide-belt. Before I got mine, that's exactly what I did. I found all my local shops to be very accomidating. A few tips... 1-be ready to go when you hit their driveway. No screwing around. They probably won't charge you a dime, but remember, their time is $$. Remember to scrape all glue/tape/etc prior to arriving at their shop... Wide-belts and glue lines don't mix.. 2-offer to pay. if they won't take payment, offer to contribute to a new belt 3-keep your eyes and ears open -- you can learn a lot from pros by just watching their workflow and how they manage the machines... 4-call ahead and ask them when would be a good time. you should work to their schedule -- they don't care about yours. I usually had to schedule a couple of weeks in advance. They will accomidate you when their's a lull in their work. 5-call right before you leave for their shop... they may have gotten busy and need to rechedule. 6-don't offer to help. You're a liability as it is... Don't compound the problem. 7-just ask them to run the boards on both sides just to level and remove burn marks. They may offer to swap belts and go higher, but that's more of their time (and belts). Once they get them flat and burn free, thank them and go... there a bunch more, but those are the highlights... good luck. All good tips. I actually spent about 45 minutes calling cabinet shops in the area last round of boards I made. Being in the LA area, I get the same answer every time. I can't help you, our insurance prohibits it.. Quote
Trip Posted November 5, 2014 Report Posted November 5, 2014 ==>Trip had wine tonight Just tired -- you can't trust anything I post after midnight... Actually, before I had big tools, I used this exact strategy at Frank Klausz's shop... And believe me, those rules applied. He had about a dozen apprentices and their time was his money. But it was kind of cool watching FK run my projects through his kit... Fluid motions, no wasted energy, etc. I never wasted his time and he never took money... I always offered some cash to support the sharpening and/or belt fund... It was a little unnerving watching someone else's belt shred on one of my projects... That day, he took the cash ==>get the same answer every time. I can't help you, our insurance prohibits it.. Have you tried woodworking clubs? Vocational schools? Personally, I'd try just about anything to avoid RoSing seven cutting boards... How about local woodcrafts -- a lot of the staff members have home shops... Gunsmiths -- long shot, but I've got Griffin&Howe about two miles from my house, and they have several thousand sqft of patter maker's kit... Quote
chefmagnus@grics.net Posted November 5, 2014 Report Posted November 5, 2014 I had taken a couple of my early cutting boards to the local woodworkers supply and asked to see how well their demo machines work. And unfortunately cabinet shops are a disappearing thing. Quote
chefmagnus@grics.net Posted November 5, 2014 Report Posted November 5, 2014 My drum sander doesn't get to me for another week to ten days... Quote
bushwacked Posted November 5, 2014 Report Posted November 5, 2014 I had taken a couple of my early cutting boards to the local woodworkers supply and asked to see how well their demo machines work. And unfortunately cabinet shops are a disappearing thing. Haha I like that idea. I think they would catch on to what you are doing if you bring in 8 boards though?? Quote
CessnaPilotBarry Posted November 5, 2014 Report Posted November 5, 2014 I have wraps as coarse as 24 grit for my Performax... Along with fast stock removal, the 24 grit is also useful for adding decorative textures to outdoor projects in woods like cedar. Both of my wood providers offer wide belt and drum sanding services on a time basis + a setup fee... Quote
Tom Cancelleri Posted November 5, 2014 Report Posted November 5, 2014 That's terrible Brendon, what area are you in? If you are in Northern VA I'd say you can run em through mine. I've got a Performax 10-20 (I regret not buying the 16-32 but I only bought it for thicknessing guitar sides/backs, and soundboards) It's never too late. Quote
Tom Cancelleri Posted November 5, 2014 Report Posted November 5, 2014 If you have a Rotex 90/125/150, running it in Rotex mode would make it somewhat quicker. Quote
..Kev Posted November 5, 2014 Report Posted November 5, 2014 Planer + belt sander? It's end grain.. No planer.. Unless you like crap flying all over your shop 1 Quote
dwacker Posted November 5, 2014 Report Posted November 5, 2014 All good tips. I actually spent about 45 minutes calling cabinet shops in the area last round of boards I made. Being in the LA area, I get the same answer every time. I can't help you, our insurance prohibits it.. I wouldn't lie to you about insurance but I wouldn't do it in the wide belt either. I would however run it through by drum if you left it with me and do it when time permitted. Quote
collinb Posted November 5, 2014 Report Posted November 5, 2014 It's end grain.. No planer.. Unless you like crap flying all over your shop Says something about my skill level. Thanks for the warning. Quote
skiback46 Posted November 5, 2014 Report Posted November 5, 2014 I know this is the power tool forum, but a low angle jack plane makes quick work of flattening endgrain cutting boards. That is how I have flattened all of mine. Only takes about 5 minutes, and then you can start at 220 with the sanding. If anyone does go this route, a little bit of mineral spirits/DNA helps, and be sure to chamfer the edges first to avoid any chipping. Quote
krtwood Posted November 5, 2014 Report Posted November 5, 2014 Matthew Cremona did a video where he used a router flattening jig to get them flat first before going to the drum sander. It won't get you a finished surface but it will get you a flat surface to start from. Quote
