Help! Total newbie with odd pieces, need to dry right
First post on forum, looking for quick and dirty advice to not screw this up.
Within a day of cementing my decision to get into woodworking with no prior skills, and little knowledge..... A sign from the universe dropped into my lap. Long story short, I came into possession of some wood that has sentimental value that I wish to dry properly. Elm trees were cut down, with a claim from the power company that they were diseased. I spotted them on a drive, and noticed the trunk was nearly exactly a heart shape. With help from some folks authorized to dispose of the wood, (these were considered nothing but firewood) I now have several "slices" cut via chainsaw. My thought is small tables, and I even have pieces of a smaller branch that also grew in a heart shape for kid sized chairs or stools. (Longer version of this: i am a pastor who just left my first call after a great 16 years. I happened by the old congregation for the first time in six months and saw this lumber. My grandfather always put hearts in his wood and iron projects. So keeping the integrity of these pieces would mean a lot to me.)
I am in central Pennsylvania. Brought them home and set them outside my basement entrance. Right now it is very cold outside. I plan to take them in tomorrow (jan 2) - tree was cut down about a week ago, slices cut off on 12/30. I had no idea there were so many factors in drying wood. Should I be slapping a sealer on both sides of them? Should I do anything but stack them with slats between? How long should they go before being rotated? I am just now beginning to build a shop, so I don't plan to cut for a long time, and if it is a two year process to dry, I can handle that. I have basement space to spare. It is a heated basement.
I just want to not crack them. I'll worry about how to finish them much later.
post-16635-0-25902600-1420169880_thumb.j
post-16635-0-07097600-1420169891_thumb.j
I am by no means an expert in drying but I have a feeling your going to get some serious cracking and warping from those slabs. The only thing I could think of is to make sure each side has equal air flow and apply even weight to hold it flat.
How thick are the slabs? If they warp but don't crack, you could always true them up one dried. Won't be fun but could work. Good luck.
Welcome to the forums!
How thick are the pieces?
First thing do do is stack and sticker them (slats as you called them) and keep them dry.  Get yourself a moisture meter so you can monitor their progress.  Then go build your shop and be sure to share pictures so we can watch!
Seal the end grain as soon as possible. The stuff I use is Anchorseal I think. It's kinda waxey. If you can weigh the pieces and track it when the weight stabilizes it's ready to work. Might be a year per inch of thickness to dry it. Still possible it may crack, tough to dry complete rounds.
They are thick pieces, like, 3-4 inches mostly. When you say seal the endgrain, this is basically the whole piece, right?
Correct me if I'm wrong but sealing the ends just helps to reduce rapid moisture loss in the end knowing the bulk of a log is stiill wet inside causing torquing of the fingers quick leads to checking. . If the slabs are only 2-3", I would think you would be sealing in the moisture. .
If it were me and refer to line one of my first response, I would try to get the most moisture out as quickly as possible.
Prepare yourself for the inevitable: they will crack.  The only way to get cross-section slabs like that without cracking is to cut them out of an already dried log.  I'd be willing to bet that they'll have cracks in them within a few days.  Perhaps they're cracked already, overnight.  Being pure end grain, the moisture is escaping rapidly...far too rapidly to remain intact.
But that doesn't mean they're worthless.  Do NOT bring them inside.  Drench them in Anchorseal.  Both sides, multiple coats.  Stack and sticker them somewhere outside that stays dry and gets a breeze.  And wait.  And wait.  And wait.  For years. When they're finally dry, you'll need to fill the cracks and stabilize them with epoxy or some other kind of resin.  There are ways.  Those rounds are full of challenges, which is why you don't see them used in furniture very often.
Good luck and welcome to the forum. :)
   Try your best not to get the sealer on the bark side... That's where the moisture will escape, a lot slower than it does in the end grain.  If you seal the whole piece, what have you got.. a slice of wood that the moisture can never leave..... That sounded like a Hotel California line!
A couple follow up questions...... We leave town for disneyworld in a few days, and I cannot for the life of me figure out where to buy anchorseal or anything like it in a retail store. If i have to ship it via amazon, i wont make it before the plane leaves.
As for outside where it doesnt get wet, i don't have anywhere like that in this new place. I could put it under a tarp, that's it, but that would defeat the point of a breeze. I do have an un-heated breezeway where it would be out of the sun, semi-inside.
Wait, never mind on the where to get AS. I just found there is a woodcraft in Harrisburg. I can head down tonight. Now as to the storage..... Still confused. And, if temps are freezing here, can i seal the wood outside successfully?
You can cover and store out doors.  You'll need to seal them, let them cure, then flip them and do the other side.  If you're doing this outdoors, your cure time will be longer I'm sure.
I've never actually used this sealer product so, someone correct me if I'm wrong on the curing.
I don't know how the freezing temps will affect the Anchorseal.  That would be a question for the manufacturer, or perhaps the retailer, or it may be written on the can.
The fact that it's freezing right now will probably work to your advantage (in terms of the raw wood), since it will help slow the loss of moisture from the wood.  I've seen rounds like that crack overnight during the summer.  The wood fibers simply cannot combat the intense shrinkage that occurs due to the rapid loss of moisture through all of that end grain.
Your goal is to let these slabs dry as slowly as possible, which is why it's a bad idea to take them inside.  The reality is, they're going to crack...you're just trying to minimize the damage.  Don't think that Anchorseal will prevent any and all cracking...it's only an aid to help slow the drying and minimize the cracking.  Which, like I said, is all but inevitable.
Oh..  And if you're going to Woodcraft and just getting into this, only take enough money to purchase the sealer  ;)
I second this motion. .
Yes, especially as a first timer. This was quite the experience. I have leads on used power tools for just about everything I want, but walking the aisles of things I never knew existed..... Wow. Of course I have been in hobbies before that are prone to G.A.S. (Gear acquisition syndrome.)
Thanks for all the help. I am home with a box of brushes and gallon of anchorseal 2. (No original in stock) i'll seal a side right now, flip in the morning and seal again, do a couple more times before stacking. I am so new at setting up shop, I literally have nothing to use to sticker them. One of my errands tomorrow.
Most anything will work..  The idea is to just get airflow around the pieces..
See if a local hardware store or home center has a deal on plastic painter's pyramids. Might be better that regular stickers for stacking those rounds, as long as the stack isn't so heavy it crushes them. The points will have minimal contact with the wood, and shouldn't slip very easily.
If you have electrical wire nuts laying around, those will work until you get a more permanent solution
Ok....I'm gonna throw a chicken snake on the dance floor.....I turned a small cedar bowl the other day and it was wet.  I got it within reach of finishing and brought it inside and put it in the microwave on power setting 1 for about 2 hours.  When it finished, it was warm but not hot.  It came out great.  No cracking or warping.  It's a little different with this project because it would have been better if the slabs were much thicker (I think?) but could the 'microwave kiln' work?
A friend put a small piece of wood in the microwave once. The wood caught on fire. He caught it in time so there was no great damage but his wife had a few things to say bout it.
Rog
Rog
He missed the "Power 1" memo....and yes Highlander, the house smelled great!  If you ever turn, cut, get shavings from cedar, put them in a small pot of water on the stove and heat them slowly.  Smells great.
