10 hours ago, Mike Vee said:
gotcha. I'm planning on ripping the board tommorrow. I took your advice and purchased a 2" extruded. polystyrene foam and a 1/2" CDX grade plyboard. chopped both in half and I'm taping it up so I can fold it away
Sent from my SM-G930F using Tapatalk
I just use the foam board without a backing.  I am still sawing away on some 2' x 4' pieces I bought years ago.  they are indeed nice and light and will tuck out of the way pretty easily.
On 5/22/2017 at 7:31 AM, Eric. said:
I'm not sure what that makes you.  I know what it makes me. LOL
I should've picked any other example.  Sorry for the twisted visual :D
hah yeah. I'll have to do 2 passes with the kreg rip-cut guide (it maxes at 12") but for the 12"x1"x8' board I might just do it with a table saw that I borrowed from my neighbor. I got 3 of those kobalt saw horses (the metal collapsible saw horses that have 4 independently adjustable legs) as support as the board leaves the saw
I was just able to cut the 2 bead boards and 4 common boards but I totally goofed the first common board because I miscalculated the depth. I did a straight 10" measurement instead of measuring from the start of the edge molding curve... so I need to go to home Depot tomorrow to grab another board, redo the cove edge and rerip it to size.... *sigh*
thanks! hopefully I can pick it up today or Tuesday. I have a massive housewarming party today (25 ppl) and I'm still hurt all over from cleaning the home and running errands.
this will be fun.. lol
Good for you enjoy the saw. There is a video on YouTube where the guy puts it together. Easier then reading the manual. Mobile base is a little different but that's just one step. Reminder...get a new blade while picking it up.
ah yes, I was going to ask which blade I should get. they're so expensive. the diablo blades are 46 bucks at HD.. is that normal pricing? and should I get a ripping blade or a fine blade?
If you're just getting one, I'd go with a decent combination blade in the 40-50 tooth range. I use a 50 tooth combo and a 24 tooth ripping blade on my saw, both from Dimar. Many people just use a 40 tooth combo unless they're ripping thicker stock. I'm not sure what blades specifically are at home Depot. That pricing doesn't sound out of line, although there are different grades from Freud. I'd look around briefly for blade recommendations before just buying one, since the one that's on it will cut, it just doesn't leave the cleanest cut. I use it for the times I need to cut anything I don't want on my normal blades, like pressure treated wood.
Blades can definitely be expensive, but they're also critical to how well your saw performs.....like tires on a performance car.  A lousy blade will guarantee lousy performance from your new saw, so it makes good sense to optimize the performance with the right blade. Save the stock blade for framing and junk cuts.  If you're going to get just one blade, I agree with SawDustB....a decent 40T or 50T general purpose/combo blade will do a good job of many tasks.  The Irwin Marples 50T is about $40 near us at Lowes and from Amazon.  The Infinity 50T is a bargain at $70 for top shelf performance.  If your current needs are for fine cuts in ply or crosscuts, then a good 60T to 80T blade makes sense.  If you need to do a lot of heavy thick ripping, get a 24T rip blade.
I'd stick with Freud, Ridge Carbide, Infinity, Forrest, Irwin Marples, Guhdo, Tenryu, CMT Industrial, Amana Tool and other top industrial blades, and would avoid mediocre blades like the new Avanti/Avanti Pro, Ryobi, Skil, Vermont American, Irwin Marathon or Classic, DW Construction, Oldham Construction, HF, Work Force, etc.
Tips for Picking Saw Blades
p.s.: rumor has it that the new Diablo blades are made in China, not Italy.  That doesn't mean poor performance, but no one moves manufacturing to China to improve quality.  Some of the current stock might still be made in Italy....this Amazon listing of A 50T for $35 claims Made in Italy
is a thin kerf blade recommended for that saw?
I have a sawstop and run a full kerf 40T Forrest woodworker II. This is the blade that sits on my saw most of the time.
I have a few other Freud Industrial (not to be confused with Freud Diablo ) blades and a Ridge Carbide on my 12" SCMS.
Many people here in our local woodworking club run a Tenryu blade and are very happy with it.
The money you spend on your blade is going to be money well spent. I would suggest a Freud Industrial blade as a good balance of cost and performance.
The carbide is large on it so you will be able to sharpen it many times.
Stay away from the diablo blades. It's just not worth it.
I'll give another plug for the Irwin-Marples 50T combo blade as a great bang for the buck. I run this on my 1.5 hp saw, and it works just fine. I'm sure a thin kerf would allow a higher feed rate, but it hasn't been a problem for me.
oh wow, I am kinda overwhelmed.. so I should have a set of blades right? what do you guys recommend what kind of blades do you recommend specifically and how many blades should I have?
Don't stress.  I guarantee there will be plenty of posts by folks who grab a Forrest Woodworker II, slap it on the saw and run it till it's dull.  Running a combo blade for everything is a common place to start.  I generally recommend folks run with what they have for awhile to figure out what they are going to want to do.  I still have a few tools around that I "had to have", some are still in the packages.  A wide array of cutters may not be in your future; they're for using, not for looking at ;)
I moved into hardwood furniture making.  In the area of tablesaw blades this led me to cutters that do better for thick, burn-prone material ripping and clean, splinter-prone material crosscuts at one time or another.  Thin kerf or standard kerf will be determined by your saw's power, your material and your technique.
Even when I ran thin kerf blades on my hybrid saw I ran a full kerf, 24 tooth FTG (Flat Top Grind) rip blade for ripping.  It was also used for cutting flat bottomed slots for miter keys or for narrow dados using multiple passes.  What you end up doing most of, will drive your cutter selection.
If I were to advise a "starter" set for someone who wanted to skip the "one blade does it all" phase I would go with a 24 or 30 tooth rip, a 40 or 50 tooth general purpose and a 60 or 80 tooth crosscut.  The lower tooth counts will put less stress on the saw for a given cut which is good for lower powered machines.  The higher tooth count will leave a smoother finish but, can be prone to burning if your saw's power restricts your feed rate.
Other random info:
  • FTG - Flat top Grind - Found on low tooth count rip blades and some specialty blades.
  • TCG - Triple Chip Grind - Found on some "glue line rip" blades and some specialty blades (laminates for example).
  • ATB - Alternate Top Bevel - Found on general purpose, crosscut and combination blades.  Probably the most commonly encountered tooth grind at the home stores.
  • HATB - High angle Alternate Top Bevel - Found on higher tooth count blades. Excellent splinter control but, dull faster.
There are others (ATBR, 2 and 1, ATAF, etc.) and a quick Google search will tell you more than you wanted to know.  Here's a good place to start.
That depends on a lot of things....your saw, what you cut, how critical the results are, how fussy you are, budget, etc.  Nearly any blade for wood will cut wood, but there's a science/art to getting the most out of each cut.  Familiarity with the basics will help - ie: more teeth tends to equate to a finer cut, but also comes at the cost of more resistance to the saw and more tendency to burn (and generally higher price).  Likewise, fewer teeth tends to equate to faster more efficient cut with less resistance and less burning, but will generally have a rougher finish.  Read through the link below for more detail.
Since you just picked up a 1.5hp R4512, I'd be leaning toward the 3/32" thin kerf group.  A decent 40T or 50T general purpose/combo blade  is a great starting point because it will be "good" in just about everything and good examples start at ~ $35.  A general purpose/combo blade will fall short in heavy duty thick ripping (roughly 1.5"+) compared to a 24T bulk rip blade because the number of teeth and small gullets will cause increased resistance and increased burning.  A general purpose/combo blade will also fall short compared to a 60T to 80T blade for fine crosscuts and ply cuts because the lower number of teeth will have more tearout in cross grain cuts.  You can add a rip blade and/or a fine crosscut/ply blade later on as needed.
I'd stick with names like Infinity, Forrest, Freud Industrial, Ridge Carbide, Irwin Marples, Guhdo, Tenryu, CMT Industrial, Amana Tool, Freud Diablo (if made in Italy) and other top industrial blades, and would avoid mediocre blades like the new Avanti/Avanti Pro, Ryobi, Skil, Vermont American, Irwin Marathon or Classic, DW Construction, Oldham Construction, HF, Work Force, etc that are no better than the stock blade.
Bargain Blades
The only other thing I would add is to make sure the blade is not so thin it won't work with the riving knife on the saw. That's why I have the blades I do, both from the Dimar woodpecker series. They're thin kerf, but thicker than the Diablo blades. Some of those are so close in thickness to the riving knife that they can cause binding.
Thank you knotscott! I did a quick read through just now but I want to reread it again at a slower pace but it's very very very enlightening!
I think I definitely will start with a combo blade but also keep a 60t blade for a clean cut if I need it. I will look around to see if there's a good deal today that I might be able to grab!
SawdustB, your comment about the rivving knife also helps a lot because that means I can't just buy any saw blade and think it's all ok.I never knew the thin kerfs have different measurements
  • 3 weeks later...
On 5/21/2017 at 0:25 PM, wtnhighlander said:
Not trying to rain on the parade, but what you say you want to do is pretty difficult, and somewhat dangerous, on a tiny job-site saw. I know there are plenty of folks on Youtube that use them for all sorts of things, but almost 100% of the time, they are built in to some larger table, which defeats the size requirement.
Frankly, I feel safer ripping 8' stock with a circular saw and edge guide, than on a job-site saw. And yes, I used to own one. I still have just a 'contractor' style saw, but the larger, cast iron table, solidly-locking fence, and smooth induction motor make a world of difference.
I have a woodworking friend who does amazing things with his Festool track saw, which I think is in your price range.
  • Who's Online   1 Member, 0 Anonymous, 58 Guests (See full list)
