dust extraction jargon
To Marc, Shannon,  hairy giggler, and community
 I'm currently in the process of setting up my very first workshop its the size of a single car garage (minus the car) 7m long x 3.6m  wide roughly.
I am trying to figure out what to do for a dust extraction machine set up & lay out. I have  set aside an area of the shop 3.6m wide x 3.5m length for my machines. These are the machines I currently have
 1) 10 inch saw stop professional cabinet  table saw
1)   Hammer N4400 Band saw
3)   Hammer A3-41-A jointer/planer due to  space issues.
 Eventually down the track i would like add to add a virmac lathe.
What i am struggling with
1) Understanding the manuals technical jargon and how i am suppose to translate this into understanding what horse power i need to look at for an extractor.
 I've tried reading books, looking up conversion charts, you tube clips, wood talks podcast archives ect. even my electrician and local wood working tool shops. But i can't find anyone or anything that can clearly state the basics in lamons terms on how go about this. This seems to be an area that no one talks about.
2) once I have this translated how do I then proceed to find the right extractor required for my machines to accommodate slight variances in horse power and more importantly the CPM per machine.
3) what would be the best way to set up the hoses/ pipes  in such a small area where i will need to move the machines around in from time to time depending on the projects.
if anyone can suggest a "Dummies guide" of instructions to point me in the right direction I'd greatly appreciate that.
Also I live in Australia so would anyone be able to recommend brands to look at that suite us.
Cheers in advance from down under.
Most of the majors have a service that will do this for you.  There's usually a fee for the service but, most apply that fee to the cost of the machine if you buy from them.
Welcome to the forums.
I'll simplify it for you.   Get 3 hp at least.  A 2 hp is almost enough, but almost is not too good for dust collection.
I have a very simple rule of thumb.  No motor in the system should be larger than the motor of the dust collector.
A cyclone takes up less room, is more efficient, and easier to dump than a simple bagger unit.  I use a 3hp four bagger inside finished houses, and we have no dust anywhere, but I have helpers that keep the bags empty.  I use the bagger because it rolls in, and out of regular doorways.
If you have to move tools around, a ten foot flexible hose helps a lot.  I use a 6" one for our use, and it goes almost directly to a planer, when we use it.  It will serve tablesaw, and jointer without worrying about blast gates.
I have not found 4" ports to be large enough to suit me on large tools.
Judging from the equipment you already own, you're a man who doesn't mind spending money on good stuff.
Any 5HP cyclone will suit your needs.  You can get away with a 2 or 3HP but if you want the ultimate efficiency you need to stretch it to 5HP...if air quality is of concern to you, rather than simply cleaning up the mess.  Which one you choose and how you duct it is a huge can of worms.  The Bill Pentz site, while extremely dense, is a comprehensive guide to what your goal will be with DC and how to achieve optimal performance.  The best route, as Kev mentioned, is to have whomever you purchase from develop your ducting layout for you.  Not sure what kind of availability you have in Australia...but I'm not sure it matters because they can do it through magic over the internet.
I can't vouch for the machine quality but here are a few of the companies that sell woodwork machinery over here. They sell some of the quality brands but the majority is their own branded equipment.
https://www.carbatec.com.au/dust-control/dust-extractors
http://www.machineryhouse.com.au/Dust-Collector
There's also this website. https://www.machines4u.com.au/browse/Dust-Extractors/
1 hour ago, Hadas said:
,  hairy giggler,
This made me laugh!
+1
I went with a  2 hp for the sole reason that I could shoe horn it into the location I wanted it to occupy. The money wasn't even the deciding factor. I almost immediately realized the flaw in my thinking. 2 hp is reasonably adequate for a cyclone.   I'd be happier with 3 to 5 hp.
Dave Stanton is an Aussie who we all know and love . He can help with what is , and isn't, Available down under.I would only add 3 HP is far  better than 2 HP in a DC blower.
I think here the real limit for you is whether you want a stationary system or one that moves around. The best as others have said is a stationary cyclone with piping installed in the cieling and drops down to your individual machines. This requires your machines stay in place. You could just use a bunch of flexihose if needed but the cyclone will be stationary. The next best is a moveable machine with a flexihose where you disconnect it from one machine and then move it to the next machine. This is more time consuming but gives you the benefit of not having a lot of unnecessary pipe to move air through.
No matter what you get you should also consider getting an air cleaner. No dust collector is perfect and what dust escapes the unit will go up into the air in your shop and eventually settle...everywhere. Better if you can trap as much dust as you can in a machine. The good thing about air cleaners is they all either hang from the ceiling or a wall so they are space efficient in that way. I just went through the process of looking for an air cleaner and after much deliberation went with this Jet model: https://www.amazon.com/708620B-AFS-1000B-Filtration-Electrostatic-Pre-Filter/dp/B00004R9LO/ref=sr_1_1?ie=UTF8&qid=1500166199&sr=8-1&keywords=jet+air+cleaner
To be clear the air cleaner is not a substitute for a dust collector, you really need both.
Hi Everyone,
thanks for all of your responses. They have been very helpful,  sorry for replying to my own question so late to acknowledge i have read through all your responses.
I guess i should should clear something up just  a little about usage.  I'm doing my woodwork as a side business around my main job and trying to step up from a hobbiest.  so i won't be running my machines all day every day, predominantly on weekends . i am running my business from home and not a warehouse/factory, my power voltage is 240V so what ever i choose can not exceed this, therefore running a  proper 3horse power or above would kill my power to the grarage. therefore i would need something to run on a 10 or 15 amp plug  to keep everything  running smoothly with whatever machine i am using at the time.
I haven't heard of Dave Stanton i am sad to say so i'll have to look him up. Where can i find him?
 lewisc  i have looked at the websites you mentioned multiple times but get caught up in paralysis by analysis as i still don't have a strong grasp on converting /understanding how to translate the air volume and machine power into horsepower to make a more clear decision as to  what i am looking in  a dust extractor.
knowing how to under the above mentioned is whats driving me nuts and making it hard to make a decision .
Cheers
Hadas
240v 3hp should be just under 15amp. A cyclone is still the best option unless it needs to be mobile.
Thanks Minorhero for the input its helped to clear things further, i also looked up Dave Stanton and what he did with his, so thats given me  solid ideas in regards to  running the extraction hoses.
 I've found a 3hp that can work on 240V from Baileigh it can stay stationary  or move around a bit  for cleaning ect. Now just waiting on the $$ to see how this baby is going to brake the bank.
thanks for all your help, much appreciated.
Hadas
