bleedinblue Posted November 20, 2017 Report Posted November 20, 2017 Should I expect better cut quality from a 1/8" 11 (or was it 14?) tpi blade? Changing feed rate doesn't seem to matter. Lester has me hooked on the stupid reindeer and this is making for a lot of cleanup. Also, no matter what I cut, thin or thick, it screams like a banshee. The thicker woodslicer I usually use is almost silent in comparison. Quote
minorhero Posted November 20, 2017 Report Posted November 20, 2017 My bandsaw leaves marks that looks like that as well. I'd be surprised if it wasn't normal. But /shrug. 1 Quote
gee-dub Posted November 20, 2017 Report Posted November 20, 2017 That looks about normal for that blade to me . . . I slightly modified my reindeer to make sure the curves fit my smallest spindle sander sleeve. 1 Quote
bleedinblue Posted November 20, 2017 Author Report Posted November 20, 2017 Ok, gotcha. I'm very close to buying a new saw and this would have been a push toward that. I can be more patient now. I have the Ridgid sander already. The reindeer I've been making are a little larger, out of 8/4 and 6/4 scraps, so they're taking a good bit of time to clean up. Quote
Brendon_t Posted November 20, 2017 Report Posted November 20, 2017 That's about what the cut on my small blades look like. I've found that going slower and taking a minute more to cut the template out leaves a much easier piece to sand. Quote
wdwerker Posted November 20, 2017 Report Posted November 20, 2017 I clean up with a coarser belt to quickly remove all the lines. After I have cleaned up all the parts I've cut I switch to a finer belt to remove the heavy scratch pattern and get really get a smooth surface. Quote
wtnhighlander Posted November 20, 2017 Report Posted November 20, 2017 Try a blade with fewer teeth. I always get better cuts in anything thicker than 1/4" when I use a much lower tooth count. In fact, it makes such a difference on my little saw, I made a video: Quote
bleedinblue Posted November 20, 2017 Author Report Posted November 20, 2017 Seems counter intuitive, doesn't it? More teeth with a jig saw produces a cleaner cut than fewer. I did buy a 3/16" 4 tpi blade when I bought this 1/8" blade. I haven't tried the 3/16" blade yet, it might work with the larger reindeer. I don't know if it will allow me to cut the tight curves of the smaller deer, but it is worth a shot. Quote
Bankstick Posted November 20, 2017 Report Posted November 20, 2017 The only dumb question is the one not asked. Interesting thread- need to watch the video. Quote
bushwacked Posted November 20, 2017 Report Posted November 20, 2017 7 hours ago, bleedinblue said: Ok, gotcha. I'm very close to buying a new saw and this would have been a push toward that. I can be more patient now. I have the Ridgid sander already. The reindeer I've been making are a little larger, out of 8/4 and 6/4 scraps, so they're taking a good bit of time to clean up. what do you have now and what are you thinking of upgrading to? dang those are some big reindeer ... any pics of them completed? Quote
bleedinblue Posted November 20, 2017 Author Report Posted November 20, 2017 11 minutes ago, bushwacked said: what do you have now and what are you thinking of upgrading to? dang those are some big reindeer ... any pics of them completed? I have a Craftsman BAS350, will be upgrading to the laguna 1412 or the rikon 10-326. The larger deer are around 11" tall, the deer cut from 6/4 stock are about 8" and from 4/4 are about 6.5. I'll post some pictures when I get some finish on them. 1 Quote
bushwacked Posted November 20, 2017 Report Posted November 20, 2017 ooooh I will be interesting in hearing why you chose whatever model you do... I think next summer I will be upgrading to a proper bandsaw Quote
bleedinblue Posted November 20, 2017 Author Report Posted November 20, 2017 So the 1/8" blade broke on me today. I didn't get much use from it, I'm going to email Highland and see if they'll replace it. This did force me to switch to the 3/16" blade though. It handled the tight curves in the smaller deer just fine, left a slightly smoother finish and cut probably twice as fast. It's a winner of a blade. Quote
bleedinblue Posted November 20, 2017 Author Report Posted November 20, 2017 2 minutes ago, bushwacked said: ooooh I will be interesting in hearing why you chose whatever model you do... I think next summer I will be upgrading to a proper bandsaw I don't think you can go wrong with either saw. The 1412 has the reputation and a slightly higher price tag, the Rikon is cheaper, has storage in the base but is that annoying blue color. 1 Quote
bushwacked Posted November 20, 2017 Report Posted November 20, 2017 6 minutes ago, bleedinblue said: I don't think you can go wrong with either saw. The 1412 has the reputation and a slightly higher price tag, the Rikon is cheaper, has storage in the base but is that annoying blue color. agree ... I just hear so many good things about the laguna bandsaw, but the nightmares of their support. Have not heard much about rikon support though. The $100 price difference isnt worth choosing one over the other though. Just wait for either to go on sale and both can be had for under 1K Quote
bleedinblue Posted November 20, 2017 Author Report Posted November 20, 2017 The Rikon sale now is $100 off plus a free mobile base. That's an attractive sale I think. Quote
