The 36v  Black& Decker is called the 40 v max now. And the  String trimmer, blower and hedge trimmer all last a long time.
Previous girlfriend had a Worx but she was 4' 8" , without a spare battery it's kinda limited.
I use a with a 3 point 60 inch land pride finish mower. With the amount of mowing I do with the hills and a field exc a zero turn will not work for allot of my lawn. A zero turn also doesn't do well in the spring if you have any soft areas also. They are however  fast and do a lot better looking job than what I use.
Like Steve said, the Worx is a short little thing.  I'm not tall, but I can only use it with one hand.  It also doesn't hold much string.   Stihl has started pushing battery powered tools.  If their string trimmer uses the 25-2 string head, I'd be very tempted at theirs.
I had a finish mower, decades ago, and it did a good job.  I started with a 35 hp tractor, and had the finish mower, and 5' bushog.   When I bought the larger tractor, I wanted a rotary cutter that was a little wider than the back tractor wheels, so I could clip the trails, and close to fences.  I bought a 7' one with two tailwheels-one tailwheel you can see in the picture of the lifted riding mower.  With two tailwheels, it doesn't scalp the ground when you go over a bump, like one with one tailwheel.  I fabricated a door that can be opened, on the back of the deck, so I can sharpen the blades easily, by opening that hatch.   With sharp blades, and the two tailwheels, it cuts as good as a finish mower, but still has the capabilities of a bushog.
I also welded a 40 gallon tank on the top of it, and an ATV boom on the back that's only about four feet wide, but sprays a 30 foot swath.  It has a selector valve, and a wand that stays up by the tractor seat.  I can flip the selector valve, hit the switch for the pump, and spray either with the boom, or spot spray with the wand from the seat of the tractor.  That mower stays on that tractor during mowing season.
Not necessary Tom, but thanks for the info. i'll check them out. the gas one is a bit much for my yard and i don't want my wife to use it so the battery one would be easier for her to use and eliminate another job i have to do:o
My battery string trimmer has adjustable length shaft and the head rotates to let you edge with it. The head has one string and the spools are easy to rewind. It auto feeds the string pretty good, no tools to swap the spool. Fairly lightweight too. 13" head
I have a B&D 40V trimmer.  I have no problem with the battery life or power for my suburban yard, that's all good.  It's on the short side though, and I'm only 5' 10"  The worse part though, is that I have to re-string it almost every use, too...it doesn't matter if I use thin string or thick, it feeds too quickly and breaks too often.  If working properly, one spool of string should last my yard many, many cuts.  It's very frustrating.
The only thing I hate about my current trimmer. I worked commercial trimmers for years the spun counter clockwise viewing the cutter arc from above. This one spins clockwise from that view. It screws with my muscle memory.
  • Haha 1
  • Who's Online   2 Members, 0 Anonymous, 54 Guests (See full list)
