wtnhighlander Posted August 5 Report Posted August 5 Happy Birthday, @h3nry! I can't wait to see what your gift allows you to 'turn out'! Quote
gee-dub Posted August 5 Report Posted August 5 I like the birthday solution . Thanks for the ride-along. I always enjoy them. Quote
Popular Post h3nry Posted August 8 Author Popular Post Report Posted August 8 Turning the columns ... Since they will be half-columns, a single whole column is turned, then split in two. The blank is made by two pieces of 4/4 cherry glued together with a sheet of thick paper in the joint. However, to prevent the lathe centres splitting the join prematurely, I also glued on some solid blocks onto the ends. With the bed extension attached, the new lathe is quite a beast ... fortunately the extension can be removed for normal use and storage. It's not a complicated shape ... so just roughed round and then brought down to size, with a bead near the middle. I want the upper part of the column to be fluted. I'm doing this the old fashioned way. Using the spindle lock on the lathe to pencil in the lines ... then cut out the flutes with a gouge. taking light cuts to make sure the cut is right on the pencil line ... a bit of help from the "60 grit gouge" wrapped round a round sanding block helps smooth things out ... They still look a bit hand carved, but good enough. Finally split the column in half along the paper joint and mount onto the case ... and I think I'm ready for finishing. 7 Quote
wtnhighlander Posted August 8 Report Posted August 8 Very cool technique! Where did you come up with the brass ends? Quote
Von Posted August 8 Report Posted August 8 First time I have seen the technique of gluing paper between two pieces to split them later. Thank you for sharing. Quote
Mark J Posted August 8 Report Posted August 8 ... and I liked the way you posed the chisel in your photo . Quote
gee-dub Posted August 8 Report Posted August 8 Man, some of you folks have got skills. Really nice h3nry. Quote
Popular Post h3nry Posted August 10 Author Popular Post Report Posted August 10 And finally ... I suppose I now have to think about replacing the main wall mirror to match somehow. 7 1 Quote
Mark J Posted August 11 Report Posted August 11 Love it! 17 hours ago, h3nry said: suppose I now have to think about replacing the main wall mirror to match somehow. Made me chuckle. 1 Quote
