Popular Post Coop Posted July 2 Popular Post Report Posted July 2 Thanks @h3nry for taking us on that last journey! 3 Quote
Mark J Posted July 2 Report Posted July 2 Yes! That joint was a complete mystery when I first saw it. (Sorry about that last joint). Quote
pkinneb Posted July 2 Report Posted July 2 Man there is a lot going on there!! I look forward to the final product regardless of whether you fix or replace that piece Quote
Popular Post h3nry Posted July 3 Author Popular Post Report Posted July 3 Well ... the right thing to do was to remake the piece from new and recut the bad joint ... not perfect, but good enough ... 7 Quote
Popular Post gee-dub Posted July 6 Popular Post Report Posted July 6 On 7/2/2026 at 6:28 PM, h3nry said: Well ... the right thing to do was to remake the piece from new and recut the bad joint . Often true. I try to limit myself to about half an hour of trying to fix a boo-boo. After that i just make another one . I will sometimes get lost down the rabbit hole and waste half a day on something that only take a short while to remake but I try not to do that. 5 Quote
Popular Post h3nry Posted July 7 Author Popular Post Report Posted July 7 Just a few pieces of hardware to prepare for installation Then after a whole bunch of sanding ... it's time to start gluing... 7 Quote
Popular Post h3nry Posted July 7 Author Popular Post Report Posted July 7 On 7/6/2026 at 7:57 AM, gee-dub said: Often true. I try to limit myself to about half an hour of trying to fix a boo-boo. After that i just make another one . I will sometimes get lost down the rabbit hole and waste half a day on something that only take a short while to remake but I try not to do that. The real problem comes when there is something unique about the piece of wood ... either you have no more supply, or the grain match is important, or add a couple of days carving work ... there are some pieces where a redo is just impractical. Fortunately not this time ... I have lots of 4/4 cherry, yes it had a fiddly joint to cut, but it was a straight piece and grain match was not critical. 6 Quote
Popular Post gee-dub Posted July 7 Popular Post Report Posted July 7 On 7/7/2026 at 7:36 AM, h3nry said: The real problem comes when there is something unique about the piece of wood ... either you have no more supply, or the grain match is important, or add a couple of days carving work ... there are some pieces where a redo is just impractical. Fortunately not this time ... I have lots of 4/4 cherry, yes it had a fiddly joint to cut, but it was a straight piece and grain match was not critical. So true. Is there anything more painful than trying to replace that perfect piece of material you had selected early on in the project? 3 Quote
Popular Post h3nry Posted July 8 Author Popular Post Report Posted July 8 Added the beading on the drawers and test fit the hardware... The frame pieces still need gluing on. 7 Quote
Popular Post h3nry Posted July 8 Author Popular Post Report Posted July 8 ... and of course approval of the QC inspector. 6 1 Quote
Ron Swanson Jr. Posted July 9 Report Posted July 9 On 7/8/2026 at 5:31 PM, h3nry said: ... and of course approval of the QC inspector. This is the only opinion that matters 2 Quote
Popular Post gee-dub Posted July 9 Popular Post Report Posted July 9 @h3nry - Love your stuff man, and I enjoy your build journals. Great info for me and any who come along. My dog was my inspector. She was not raised in the shop, we got her as an adult. If I didn't like her opinion all I had to do was fire up the shop vac and she was outtta there 5 Quote
Popular Post h3nry Posted July 9 Author Popular Post Report Posted July 9 He sets a pretty low bar for inspection standards ... a cardboard box from amazon, or a paper bag from the grocery store usually gets full approval. I don't use a lot of noisy powertools, and he's not allowed in the garage when I do ... at least the noise of the bandsaw drowns out the miaows asking to be let back in. He does encourage me to put away tools I'm not using though, since I don't think sitting on knives and chisels is a good idea. At least he's not a "push things off the table" kind of cat; that's the other one, and she doesn't try to help much with the woodwork. 4 3 Quote
Popular Post h3nry Posted July 13 Author Popular Post Report Posted July 13 There is an obvious spot that needs some decoration ... So I'm going to add a carving, but I didn't have a design in mind I think I've settled on a design I like. I'm using a contrasting wood (maple) so I hope it doesn't stand out too much. Then cut out the shape using the coping saw on the "bird's mouth"... ... and a quick preview at what it might look like: 8 Quote
Popular Post wtnhighlander Posted July 14 Popular Post Report Posted July 14 You're making the rest of us look bad, @h3nry! I mean that in the most respectful way possible. 6 Quote
Popular Post fcschoenthal Posted July 14 Popular Post Report Posted July 14 On 7/13/2026 at 6:24 PM, h3nry said: Then cut out the shape using the coping saw on the "bird's mouth" You amaze me with your hand tool work. I just don't have the patience it takes to do everything by hand. 5 Quote
Popular Post h3nry Posted July 14 Author Popular Post Report Posted July 14 Before actually doing any carving ... the blank is mounted onto a plywood backer. Using PVA sparingly glue a piece of thick paper between the wood and the plywood ... The backer can be held firm to the bench in the tail vice. By making it square it can easily be rotated 90/180/270 degrees to get the best angle to carve with the grain. Then start carving ... An initial sanding can be done while it is still mounted ... but the final sanding is done after removing from the backer. To remove it from the backer ... gently tap a chisel between the carving and the plywood at the glued paper layer. You have to be gentle at first, but eventually the fibres in the paper start to tear ... and the carving will just pop off. Then carefully (because it is quite delicate) sand the remaining glue and paper off the back ... and give a final sanding to the carving. It might need a bit more sanding before I glue it down, but I've done enough for today. 8 Quote
Popular Post wtnhighlander Posted July 15 Popular Post Report Posted July 15 That looks incredible. 3 Quote
Mark J Posted July 15 Report Posted July 15 Wow. I could never shave in that mirror. I'd be too busy admiring the bird & wreath carving. 1 Quote
Von Posted July 15 Report Posted July 15 Thanks for sharing all this. I hope to make use of it some day. 1 Quote
Popular Post h3nry Posted August 5 Author Popular Post Report Posted August 5 The next thing I need to do is turn some half-columns to go down the sides. With my little mini lathe and it's 12" bed, it will have to be done in three sections, cunningly joined at a bead to hide the join ... ... or ... 3 Quote
Popular Post h3nry Posted August 5 Author Popular Post Report Posted August 5 ... or ... Happy Birthday To Me, Happy Birthday To Me ... I could take this as the opportunity I've been waiting for to upgrade my lathe. I had to wait a couple of weeks for the bed-extension to arrive. I guess I should practise a few turnings to get used to the machine first. 7 Quote
