daviddoria Posted January 14, 2015 Report Posted January 14, 2015 I am making the wine display from the Drunken Woodworker site (http://drunkenwoodworker.com/how-to-make-a-wine-display). Everything was going well until I tried to route the roundover in the slots for the wine glasses. As you can see in the attachment, the 1/2" bearing on my 1/2" shank 1/8" roundover bit does not quite fit into the hole. I assumed (you know why that's bad to do...) that if I got a 1/4" shank bit, the bearing would be smaller. It arrived today, and it still has a 1/2" bearing! I just found this "minature" bit http://www.rockler.com/rockler-miniature-round-over-router-bits-1-4-in-shank that has an 8mm bearing (about 5/16") that looks like it would work. My question is (before I buy *another* bit), is there a way I'm missing to make this roundover with a "normal" size 1/8" roundover bit that I am missing? It seems as though the bearing must be flush with one side of the roundover profile (meaning I can't just replace the bearing with a smaller one). Do you guys typically keep a "minature" of a few small profile bits for cases like these? Thanks, David Quote
Brendon_t Posted January 14, 2015 Report Posted January 14, 2015 My 3/8 profile round over came with two bearings. I've figured out that it works on other bits as well. Quote
Trip Posted January 14, 2015 Report Posted January 14, 2015 My first inclination is to grab a carving gouge and do it by hand -- I’m sure there’s a router solution that someone can provide… 1 Quote
Popular Post Eric. Posted January 14, 2015 Popular Post Report Posted January 14, 2015 Do it by hand with a modeller's rasp or some sandpaper. 3 Quote
bgreenb Posted January 14, 2015 Report Posted January 14, 2015 My freud 1/8" roundover bit has a very small bearing. I don't know how big but I just used it to round over a 1" hole so I think it would work for your application. Edit: I checked and I guess my bearing actually is 1/2". Sorry about that. Quote
Trip Posted January 14, 2015 Report Posted January 14, 2015 Others may have a different perspective – When routing, having a small margin for error to 'grab', 'trap', 'capture' (or whatever the correct term is) has always made me nervous – not for getting cut myself, but having the bit grab the stock and leave a really poor profile… When I look at an operation like that and the production count is low, then I think hand-tools… By the time you setup a router, make a practice cut or two to dial-it-in, you can probably get five or ten done by hand… If you’ve got three hundred to do in an afternoon, then, yea, get a new router bit… 2c 1 Quote
wtnhighlander Posted January 14, 2015 Report Posted January 14, 2015 Can't use a smaller bearing, that would turn the round-over into a bead. Make a template, use a collar, and remove the bearing. Or just do it by hand, probably a lot simpler, if you don't want to open the gap any wider. Quote
Boatworks Today Posted January 14, 2015 Report Posted January 14, 2015 The round-over for that display doesn't need to be much (heck, you could even leave it mostly square and break the edges with some sandpaper and it would look nice). Personally I wouldn't bother buying a new bit unless I needed to crank out at least a dozen. 5 minutes of hand work and you'd be done per display ... 1 Quote
TerryMcK Posted January 14, 2015 Report Posted January 14, 2015 I have to agree. Nice as it is to use a roundover bit in this case hand tools and/or sandpaper is the best option. In the past I have made a tool simply creating a profile by grinding a piece of tool steel on a dry grindstone. The small radius on the side of the wheel created the profile I was looking for (1/16 to 1/8 round over) and used the resulting tool to scrape the external corner (or hole in your case) of the wood. I created a cutting edge on the tool by grinding it like a metal lathe tool. About 2 minutes work no heat treatment as it was a throw away once only tool. It worked well too with elbow power used to create the roundover I wanted. Quote
TerryMcK Posted January 14, 2015 Report Posted January 14, 2015 A deburring tool also works just fine on wood - admittedly out of the box it's a chamfer but modding on a grindstone can create a radius http://www.amazon.co.uk/Bahco-316-2-Reamer-Replaceable-BAH3162/dp/B001OXFFMU/ref=sr_1_1?ie=UTF8&qid=1421231916&sr=8-1&keywords=deburring+tool http://www.amazon.com/Grizzly-G5618-Deburring-Length-blades/dp/B0000DD4CY/ref=sr_1_2?ie=UTF8&qid=1421231975&sr=8-2&keywords=deburring+tool&pebp=1421232000205&peasin=B0000DD4CY Quote
Tom Cancelleri Posted January 14, 2015 Report Posted January 14, 2015 If you really really really must use a router for this operation you could get a dremel router base and a tiny dremel roundover bit. Quote
duckkisser Posted January 14, 2015 Report Posted January 14, 2015 is it possible to use a large countersink bit and just use your drill? Quote
