TWWG Split Top Roubo Build #544
Not done with hand routing yet, still gotta do the deadman groove and the top mortises :)
Mortises look great.  Nice work man.
What makes you think I'm not using my router plane for that? Should take about the same amount of time, right? :)
  • Replies 179
  • Views 28.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • My bench is finally done* and I couldn't be happier how it turned out! I ended up putting 2 coats of Watco Danish oil on the entire bench. Of course there were a few mistakes along the journey but I w
  • The width of my base came in 1/32" under and I decided to have the back slab overhang by that much instead of being flush which kept my bench 24" wide. I could have just shrunk the gap stop buy I want
  • Oh yeah this feels good and every corner came out dead square! Poor old bench is getting its last use before being retired to the garage. Sure hope I didn't miss anything before assembling because thi
Posted Images
Bought a 3/8" drill bit that was 6" long from Lowes which was total crap. I could tell just eyeballing it that it was too big and steel rod confirmed the obvious.
ABF26151-D1D8-4B02-A0BD-6FCA87962E17_zps
So I got impatient and decided to try drilling from both sides using my existing drill bit. I was careful and dead on! Need to do some more studying before finishing the vise install.
F96CE6A3-42DA-4DB4-B6C1-13EAE3AE5F9D_zps
Instructions said 1/8 - 3/8" toe in is normal and I'm at 3/8".
0D2191D0-A310-4F20-9A18-5258F29893BB_zps
Edited by estesbubba
Hit save accidentally :(
http://i411.photobucket.com/albums/pp200/mike290/Woodtalk/ABF26151-D1D8-4B02-A0BD-6FCA87962E17_zps0mv22jxi.jpg
told ya :)
The one I got at Woodcraft worked well. Same one Tom got too.
told ya :)
Well I avoided the Bosch and still picked a crap one. Good news I'll return it since my drill from both sides method worked. Hey now I have cut from both sides and drill from both sides skills from this project.
Installed the tail vise tonight and man it's smooth. Just like Brian I found the slotted screws suck and ended up using square drive for the install. Took the vise off and will buy better screws for final install.
2BF2AE4F-2B71-4FEB-9F7A-B4D6A2BC61DB_zps
Nice!  Another big milestone. I hate slotted screws. I honestly can't understand any non-aesthetic reason to use them.
Oh yeah this feels good and every corner came out dead square! Poor old bench is getting its last use before being retired to the garage. Sure hope I didn't miss anything before assembling because this sucker isn't coming apart. Getting the guts to glue it up was like trying to jump into a cold pool! Clamps aren't needed with the draw bore joinery but it makes me feel better that they are there.
353AEBCB-6C65-4EEB-BD8A-FE64B2760B97_zps
4EBD731A-D9A0-4121-A241-36C814DB6108_zps
Sweet, getting down to the home stretch. Bet you're excited. First time you clamp stuff up you're going to wonder how you did anything before
Sent from my 831C using Tapatalk
The width of my base came in 1/32" under and I decided to have the back slab overhang by that much instead of being flush which kept my bench 24" wide. I could have just shrunk the gap stop buy I wanted that extra 1/32" of workspace! I trace the feet and routed the mortises and deadman groove. I got lucky as the base dropped in the first with absolutely no play.
8FEB7553-DBF2-431C-B819-B238A9F480DA_zps
Please Brian and Tom tell me I'm finally done with all this crazy deep hand-held routing! My 1/2 spiral upcut is ready for retirement.
A7669D8F-59DE-42AA-BB1A-C0A4B0424B55_zps
The slabs are in pretty good shape but the back one drops by 1/16" on the leg vise end which would mean removing that much from the front slab. I put a couple of washers under that end which would mean removing a lot less material to flatten. You guys think I should cut some wood shims for under the rail to raise that end to reduce the amount of material removed? Here it is with the washers under it.
84968F15-08F4-456D-B19C-A8465EE99D77_zps
It's a great feeling seeing it finally on the floor and for the first time looking like a bench. My concrete floor is nice and flat in that area so more good luck today.
3B80C652-9C71-49E5-86DA-D3483B5F6433_zps
E5974EF0-D067-4F47-9609-260C00B2E07D_zps
Mike it looks fantastic. Now you're REALLY in the home stretch. No more routing!
Since your slabs sit perfectly flat on the base and it's only 1/16 to remove, I personally wouldn't mess with shims. 1/16 is nothing. You might notice if you look closely at the dovetails, but I doubt it.
Also: make sure you leave the dogs in the dog holes when you flatten. That way they stay at or below the surface after you remove material.
Looking amazing Mike. Its crazy how that monstrous bench doesnt even look all that big in that enormous shop!
Sent from my SGH-I337M using Tapatalk
Brian did you hit your dogs while flattening? I'll peel my suede down or remove because no idea on what would happen if the bit hit it. I'm going to install my spax screws before doing my final analysis of the top to pull everything tight.
8FEB7553-DBF2-431C-B819-B238A9F480DA_zpsxizmiyp9.jpg~original
A7669D8F-59DE-42AA-BB1A-C0A4B0424B55_zpservymkzg.jpg~original
84968F15-08F4-456D-B19C-A8465EE99D77_zps3pcycjtz.jpg~original
3B80C652-9C71-49E5-86DA-D3483B5F6433_zpsuzemixlb.jpg~original
E5974EF0-D067-4F47-9609-260C00B2E07D_zpsqhqghqyn.jpg~original
The spax screws were fun to install.... Looks good Mike
I did hit my dogs but I hadn't applied the suede yet. I doubt it would matter since you're removing so little but you're probably right better safe than sorry.
Last night I chopped the mortise in the leg for the dog, installed the Spax screws, then sanded the bottom and put Danish oil on it and the bottom of the legs. Put another coat on the bottom of the legs this morning as they keep sucking it up. It didn't darken it too bad.
CAAEB530-C7C4-4986-AE43-4C5375A88FAC_zps
4 hours ago, shaneymack said:
Cant see in the pics, what do the spax screw hold?
They just hold the slabs to the base. One screw on each end of each slab through the short upper rails.
Well crap first some people couldn't see my Google Photos and people said to use Photobucket which appears to have same problem.
Anyway Brian answered the question on the spax screws. They probably actually do nothing unless you lift up on the top. The slabs are so heavy and register into the leg mortises and don't budge when pushing on them.
Take a breather Mike. Re read what i wrote. I can see the photo i just couldnt see where the spax screw was :D
I guess 2 letter words really do matter! Maybe I shouldn't try to write code and reply on a forum at the same time.
Sanded most of the base tonight to 180 while it was upside down and no top on it. I put the slabs back on and tightened the spax screws. The slabs sit nicely on the rails and most of the height differences are because the front slab is 1/32 thicker than the rear. This is actually good since the dog strip needs a little cleanup anyway. Looking at the slab from the pic below here is the depth of the low spots at 5 positions working top to bottom.
0,0,1/32,1/32
0,0,3/64,1/32
0,0,1/32,1/32
0,0,1/32,0
0,1/64,1/32,0
Marc's had a corner 1/4" high so looks like I got pretty lucky.
Really looking incredible Mike!
At least it wasn't a punctuation issue.
Let's eat Mike.
Vs
Let's eat, Mike
