So much for that planer and jointer
I opened my shop Saturday morning for the first time this year and discovered I had no lights.  After poking around in the breaker box I was able to get the dedicated circuit I use for my saws back online but the other circuit is shorting somewhere.  My instinct is that the short is in the buried cable between the breaker and a sub-panel.  When I shut down all of the breakers in that sub-panel the circuit still shorts and trips the breaker in the main panel.  I guess my next shop project will be a 20 yard ditch and my next shop purchase will be $600 worth of copper cable.  That DW735 would have looked so much nicer...
If your running a 60A or 100A feeder then look at aluminum. It's so much cheaper & if done right, just as reliable as copper.
Thanks for the advice.  It looks to be about 1/3rd the cost.
==>my next shop purchase will be $600 worth of copper cable.
Before you dig...
Disconnect the feeder from breakers, ground, neutral, etc -- i.e. everything... Test for continuity first... IF AOK, test the breakers...
What tool do I need for testing continuity on the lines?  I've done this before on com lines but never on NM cable.
I'm still holding out some hope that the issue is somewhere in the sub-panel but the first thing I did was replace the breaker with a spare I had on-hand so I don't think the breaker is the problem.
I do have a simple digital multi-meter.  If I tied two lines together at one end I could test through them at the other end and repeat that process for each combination.
Before you purchase any aluminum wire, be sure to check local building codes. It isn't allowed in some localities.  Even where allowed, the current carrying capacity for aluminum is lower that that of equal sized copper, so you may need a larger wire gague.
Example, the NEC 2002 table of ampacities lists (for 60* C rated wire) 110 amps for AWG #1 copper, but only 85 amps for AWG #1 Aluminum.
Correct, using a jumper, tie two ends together, check continuity across those lines then record the reading in ohms.
The troubling thing about a short is that it's not always an all or none. The wire doesn't nessisarily have to be totally broken. The sheathing could be warn through arching to something else. It may still read just fine because the continuity is there but once it juices up, the power takes the path of least resistance.
I spent $10k when I bought my house to get rid of most of the aluminum. Wouldn't be my first choice to add it in,
Have you tried removing the individual breakers from the subpanel? Am wondering if a bad breaker in the subpanel, especially the main, might be the culprit.  Or even a weak breaker in the main panel can do this.  Weak breakers can be misleading and time-consuming but are the easiest to fix.
No you don't tie them together.  You test them relative to each other and if you get any resistance and not an open you have found a short.
Big difference between using aluminum for branch circuit wiring & panel feeders. Nobody uses it for branch circuits anymore.
A multi meter will work, sort of. Measure the resistance between each wire and from each wire to ground, after you have disconnected both ends of all wires of course. You should get open circuit, or infinite resistance on all readings.
A more definitive test is to use a Megger, or high voltage insulation tester. That will for sure let you know if there is an insulation breakdown that may not show up with just a multi meter. Rather that using 3V or 9V to detect the resistance, it uses 500V or 1000V. You may be able to rent one. Don't touch the leads when you're using it though & make sure you read the instructions!
==>Before you purchase any aluminum wire, be sure to check local building codes. It isn't allowed in some localities
+1
I think it's now banned around here... I'm pretty sure you can't use it the Chicago area... There must be others...
  • 26,009 Total Members
  • Joseph b Newest Member ·
