Wall sheathing question
So my shop walls are currently bare studs. I was going to put OSB up for ease of hanging stuff on the walls and out of my hatred for doing drywall. But my local HD has 4x8 sheets of 5/8" melamine on clearance for $8.33 a sheet. So far 5 have followed me home. Should I just sheath my walls in it?  I was planning on using it for shop projects only but I'm thinking it would be faster and easier than just about any other wall finishes. I mean it's already white and smooth so how can I go wrong?  I know it won't be the best for hanging stuff on but there are always toggle bolts for heavy stuff. What do you guys think?  I feel like I can't go wrong at that price, I could do nearly half my shop for what primer and paint would cost.
$8.33 is pretty cheap, it seems you already know about hanging heavy stuff from it, i don't know why it wouldn't make a nice bright shop and easy to clean, OSB smells forever it seems and would be much darker for a shop unless you painted it, i think i would use it.
At that price, do it, do the whole shop, and get a few extra sheets for projects! Bolts work predrilled screws will work, and clean up is a breeze, leaf blower!
good question Ross, not in the trades myself but here its required (fire barrier) between the house and garage if the garage is attached to the house, i don't think drywall counts but i could be wrong.
Drywall is popular because it has mudded seams etc. Wood does not burn as fast as wallboard paper, but takes special treatment at the joints to maintain the rating. CAR siding is tongue and groove. With regard to melamine, it can get quite staticky and will collect a lot more dust than some other surfaces. Fire rated walls often have thicker drywall. 5/8" or double 5/8" depending on the minutes worth of rating required. Half is typically fine between house and garage.
Both good points, especially the staticity! I thought it was a heck of an idea until you mentioned these.
I'm not too worried about fire rating as its only a workshop (detached) but that is a valid point.
The static thing is a good point. I'll look into that a bit. See if there are easy ways to mitigate it.
I guess Ill be the odd ball and say I like the osb. No it doesnt look that great.
4 minutes ago, xxdabroxx said:
But the OSB is also about $16 per sheet.
Darn. I had no Idea it went up that much.  Looks like melamine now.
I think that was for 5/8" osb. They had thinner with the radiant barrier for about the same.  The melamine is normally $30 but this stuff is on clearance. I'm not sure if there is enough left to do all my walls or not but it would do at least the two longest walls and maybe one end.
I think If I could afford Id get back over there soon.:)
I do think it will look good and would like to see the shop in progress.
This type of stuff is usually made from melamine, or a similar substrate.
So...it can be done. You could even cut similar grooves in it, or make peg-holes for hanging stuff.....But I wouldn't use it, personally.
1. As you mentioned, you don't get the ability to just slap in a screw to hang stuff like you do with plywood. This kind of defeats the purpose, to me.
2. It's heavy as hell. Not only will it be harder to hang, it will require better fasteners than cheap drywall screws. Between the weight and fasteners, that eats into the savings by at least a buck or 2 per sheet, I would guess.
3. No way to fill and level the seams. Even with plywood, you have a few options for filling and leveling the seams if needed someday. Might not be important to you, though.
4. No way to change the color. Maybe the high gloss white will work for ya...you're not gonna be able to paint over it easily if you don't, though.
I do a double wall in bathrooms these days. 7/16" OSB can be had for $10 a sheet or less if you buy a whole bunk. 1/2" x54"x12' wall board is about $13 a sheet. You can have a smooth, paintable, patchable wall over universal hanging support. Shops will hang heavier stuff than bathrooms, but the principle remains.  None of these materials are budget breakers at these prices. Use what makes sense for you to work in, for you to resell in a hurry if needed, for you to be able get the max out of your space. It is not our space:D
4 minutes ago, andrew-in-austin said:
Drywall over OSB sounds like a really good idea for a workshop. I'd probably do that or some kind of shiplap.
That would definitely be ideal, although the budget is far from ideal.  haha, headed to the HD in a few minutes to grab some more of the white junk.  I'll see how much is still there when I get there.  I also have to grab some electrical boxes, I think I have plenty of romex already.  Just prewiring for now, no panel yet.
