wdwerker Posted October 6, 2017 Report Posted October 6, 2017 If she can't sleep she doesn't want anyone else to sleep ! 1 Quote
SawDustB Posted October 7, 2017 Author Report Posted October 7, 2017 1 hour ago, wdwerker said: If she can't sleep she doesn't want anyone else to sleep ! That sounds about right! She doesn't do laying quietly or calm very well. Quote
Popular Post SawDustB Posted November 13, 2017 Author Popular Post Report Posted November 13, 2017 So I haven't forgotten about these, but life got in the way the last few weeks. I planed the flat parts and used one of those contour sanding kits for the rest. I got a few coats of spray lacquer on this weekend. They're currently curing a bit, then I'll rub out the finish. I'll post some better pictures once I finish the framing this week. I'm pretty happy with the general result. The maple is my favorite, but I suspect my daughter will only have eyes for the purple ones. 4 Quote
mat60 Posted November 14, 2017 Report Posted November 14, 2017 Frame looks great She is going to love it. 1 Quote
pkinneb Posted November 14, 2017 Report Posted November 14, 2017 That turned out great! Nice tight joints and great wood selection. 1 Quote
SawDustB Posted November 14, 2017 Author Report Posted November 14, 2017 Thanks guys! I was happier with cutting the miter joints on the table saw this time. If I don't get a new Incra miter gauge for Christmas I think a miter sled might need to happen. One of the frames had a couple of minor gaps, but sanding and CA glue filled them no problem. I like that method since it basically doesn't show after the finish is on. My daughter likes them, but she's 4, so she would have probably been happier with painted purple frames. Oh well. My wife's happy, so I'll count that as a win. Unfortunately, I found a couple of little drips on one of the frames, so it'll need to get scraped and have one more coat. Quote
Popular Post SawDustB Posted November 26, 2017 Author Popular Post Report Posted November 26, 2017 The frames are done, the pictures are in, and they're on the wall. I had trouble finding the mats I wanted locally, but eventually tracked them down. In front of the pictures is 0.080" acrylic, and behind is 1/8" hard board. They're installed using flexible points, which is quick, easy, and allows the pictures to change out. Because I used the key hole slots, hanging them meant putting in 3 screws at the same height and correct spacing. I'm very happy with the final result. My daughter hasn't seen them up yet, but I'm sure she'll like them (after all, they're purple). Thanks for following along! 4 Quote
bushwacked Posted November 27, 2017 Report Posted November 27, 2017 those turned out great! I have some picture frame making requests coming up in the near future too ... hopefully mine turn out half this good! 1 Quote
SawDustB Posted November 27, 2017 Author Report Posted November 27, 2017 22 hours ago, pkinneb said: Those turned out great! Thanks! 2 hours ago, bushwacked said: those turned out great! I have some picture frame making requests coming up in the near future too ... hopefully mine turn out half this good! Just make sure when you cut the miter the wrong way, you glue the off cut back on quickly before anyone sees. No one that has seen the maple one in person has been able to tell, so that was a relief (and I put a hidden dowel in for strength). Seriously though, I think a miter sled is in my future. I got much more accurate miters on the table saw, even with my jury rigged setup on my cross cut sled. 1 Quote
Isaac Posted November 27, 2017 Report Posted November 27, 2017 On 10/2/2017 at 7:05 PM, davewyo said: I just did the same thing about a half hour ago. It was no big deal for me because I had milled more stock than I needed, but I do it "Every. Single. Time..." too! Ever try doing crown molding with compound miters? If you don't have a system and experience it will make your head explode before you get things right! just make sure you have about 300% extra stock and you should be good to go. 2 Quote
Immortan D Posted November 28, 2017 Report Posted November 28, 2017 16 hours ago, Isaac said: Ever try doing crown molding with compound miters? If you don't have a system and experience it will make your head explode before you get things right! just make sure you have about 300% extra stock and you should be good to go. That's one of those things that look so easy in the tutorials but are a nightmare when you have to do it without experience. 1 Quote
difalkner Posted November 28, 2017 Report Posted November 28, 2017 Those are very good looking frames! And well documented, too. Good job. David 1 Quote
