12 hours ago, wdwerker said:
"Clamp porcupine "  wonderful term !  I've made several projects over the years that took every short clamp in the shop. Looks like a very interesting project to follow .
I ended up cutting down six of my 18" clamps to 8" so that I would at least have room to move around the thing.  That hurt.  You know I'm going to need more longer ones than I have now on the next one.
I watched the vid you made on transferring the water marbling to the board and it was really interesting. I like the outcome on the curved case much better than the graphic makes it appear. I commented about how it'd be interesting to use contours from a geographic area that is sentimental to you, but realize that wouldn't really work bent around the outside of the case.
I can't help but notice that you have a lot invested in power carving. Have any advice for someone that wants to dive in sometime soon?
Ah, that's you :)  I once did a picture frame with contour map of a mountain range for my brother and his wife's certifcates for completing hiking all the 4000'ers in the state.  I could totally see something like that on this as it's kind of a mountain.  But then you're narrowing down the potential customer base.  They have to have a connection with that place and like the style of the piece.  And my style is well, not normal...
Quote
It depends on the scale you're working on, but I would go right for the turboplane.  I started with a kutzall burr disc and while it certainly works, it's really hard to clean.  It's a cheaper way to get started but it's kind of like buying a jobsite table saw.  You're going to outgrow it in a week.  I thought the burr disc would still be useful as a finer option, but I think the turboplane is actually better at making light passes.  You can hear it cutting and it doesn't really do much without a tiny bit of pressure, whereas the burr just removes material without you really knowing how much you're taking off unless you take off enough to make the grinder motor change sounds.  The turboplane throws chips everywhere whereas the burr kind of sends a stream of dust in one direction, so in certain circumstances the burr is easier to do dust collection.  But practically, it's going to make a mess either way and the turboplane makes less dust and doesn't spread the mess as far.  It's just utterly hopeless to try to do dust collection with it though.
I have nothing but good things to say about the arbortech mini-grinder for smaller work.  Though I would recommend the opposite advice and get a 2" burr disc for it.  I haven't tried the mini-turboplane they have for it, but I have tried all the blades and you get way smoother results with the burr because of the curved edge.  The one I have is from saburrtooth, and it's much easier to clean than the larger kutzall.  I don't know if that's because of the different manufacturer or that it's the finest grit.  As far as grit goes, I would only get the finest grit.  There isn't really that much difference in how aggressive they are so you may as well just leave the best surface.
For sanding I use the Tim Skilton sanding pads with the wavy edge discs.  Klingspor sells them in a 50 pack for pretty cheap and you burn through them in no time.  I have used them in my cordless but it really doesn't like it and gets super hot.  So for this project I bought a milwaukee close quarters drill, but haven't used it yet.  I have tried my regular corded drill and it's just too awkward.  The chuck is too long and the balance is just wrong for the way you have to move it around.  So hopefully that's going to be worth it.
I have a Foredom flex shaft unit.  I have the lower end one, I think the SR, and it's a little underpowered.  I would get the bigger one if I had it to do over.  Might get it eventually if I end up using it more.  Also getting the burr caught up in your sweatshirt breaks the internal part of the flexshaft, so you should have an extra one or two of those lying around.  Or so I've heard ;)
Full disclosure:  I did get the turboplane from a sponsorship but there were no strings attached.   I bought all the other arbortech stuff I have before that.
Awesome information!
So I didn't mention I'll probably only be doing chairs with it ... to start. I at first was looking at the Holey Galahad because i was nervous the turbo plane might be too aggressive and cause me to do more damage than do good eg. the kick backs you had on your crayon vase (i realize that was an entirely different cutter just an example). I never thought about cleaning out the bur discs though that's a good point. The big benefit i can see to the arbor tech if i can tame it, is that i wouldn't need a coarse and a fine so the price is essentially a wash.
What is edge durability like does the turbo plane wear out? Can you sharpen it? I feel like i should just dive in and practice on some of the firewood that i have drying on the side of my house.
I think you'll be surprised at how easy it is to use.  It can get away from you a little if you really push it but nothing like those kickbacks.   You have the most control pulling it toward you, so I do that when I'm being aggressive with it.
I've only had it a short time, but it's 3 carbide cutters.  I'd expect the durability to be similar to a router bit.  You should be able to sharpen it with a diamond file.
  • Thanks 1
So the interesting thing I think at this point is the total lack of a reference surface.  The sides are all curved.  The faces/edges are not flat.  And the case has some flex to it, which meant trying to flatten a face at this point would probably lead to chasing my tail.  So I had to start somewhere.  So my first goal was to get rid of that flex by joining the two ends, so that I could then flatten a face.  Before I could do that I had to square up the ends, since I obviously can't be cutting through them after there's something joining them.  Well, I suppose I could have done some kind of temporary joining, flatten the faces, and then come back to squaring up the ends.  But really if they aren't absolutely square it doesn't make any difference.
Next I made a fixture to hold the case.  There are high stops at the ends to force them all to be the same width.  The ones with the sculpting had more springback after I removed a lot of material at the top curve.  There's a rail at the front and back which supports a template that I used to route a flat area on each end.  I had the bit extended as far as I dared to get to the lower side and it didn't completely flatten it, but the low spot is only 5 thou or so below, it just looks like it's more than that.021.thumb.jpg.d00ef008db6849a882066f1e02027734.jpg022.thumb.jpg.72e273ec1dd3f9cad2d151c7f5244ca9.jpg023.thumb.jpg.7f7518c0298b55a4061ca0174261a087.jpg
The walnut piece brings the two level with each other and extends out in both directions.  I used walnut here because you can just barely see it in the finished piece from the right viewpoint and I want it to disappear in the shadows.  024.thumb.jpg.dcd81d7f0fe8e3e67d47f1faa81acbeb.jpg
I used block with a cleat on the right side to reference off the edge of the walnut piece to locate the plate that joins the two ends in the same spot on each case, and to hopefully get the slot in it aligned parallel to the sides of the case.  The slot is going to receive a vertical divider, more on that at the end of the post.
With the two ends joined now I could flatten a face.  To do that I had to modify my shop built drum sander for a larger depth of cut.  Fortunately I never glued the cabinet together so I could remove the front and back of the cabinet and move the motor to the outside.  Then I just had to rig up a temporary support for the table.027.thumb.jpg.5111f0f6c1c7d9725d35b969e6f67fc6.jpg
If I just had a couple of these to do I would have done the other side with the drum sander as well, but with 20 to do and more than 1/8" to remove I did something I don't like to do and that is use the table saw to cut something that isn't flat.  They are big enough that my hands were nowhere near the blade and I had a lot of leverage.  It went fine.  The blue tape did it's job preventing splintering for the most part, just a couple spots I had to fix.028.thumb.jpg.9fa42c899193ee1adb68af8a9482baf3.jpg
That brings us up almost current.  I've started working on the rabbet for the back panel.  Rather than use a rabbeting bit I cut a pattern on the cnc and am using a pattern bit so they all end up the same.  Then I can cut the panels on the cnc and not have to fit anything once I get it dialed in.
That vertical divider is what is currently vexing me.  It attaches at the bottom into the groove in the joining plate.  It attaches to the top of the case... how?  I am thinking pocket screws, but on the sculpted version there is not enough material there for a screw.  I've got 1/4" at best thickness to the case there.  I was thinking about a "pocket dowel", where I would use the pocket hole jig with a regular 3/8" bit instead of the step bit to make a shallow hole in the case so I could insert dowels after sliding the divider in place.  But I'm open to other ideas.
On the right side of the case there will be a slide out unit for hanging storage on full extension slides.  So I have to also get another slide at the top.  I think that will be mainly attached to the divider rather than the case, but there's some opportunity to reinforce the divider/case joint there as well.
Is the divider going to be plywood? Honestly i don't see a lot of stresses in the dvider ply has decent edge gluing strength i'd just get the angle right and glue it no joinery. Should have a good amount of long grain to long grain glue surface.
I question whether I can get the fit perfect on 20 of them.  Also, I should have mentioned it would be nice to be able to remove it for finishing.  Perhaps just a couple of blocks glued in on both sides to lock it down laterally.
I guess i wasn't sure how the final product. I don't have the vision that you do. If there is going to be a back and a front so everything gets hidden the 2 blocks would work great. If the area is going to be seen at all is where things get iffy.
Absurd suggestion. You could find a way to clamp the divider in place and then do another ply of 1/4" lamination around the inside creating a slot at the top it would make it look like there was a perfectly cut groove.... jokes that sounds miserable.
Yeah, there's a back panel and then walnut drawer fronts covering everything up.  The divider will have a walnut solid wood edge banding on the front and I figure I can apply that after fitting the divider so that if there's a tiny gap at the top I can cover it.  The edge banding will be in front of the plate at the bottom so I don't have to worry about fitting it between the two.
I cut all the rabbets for the back panel and cut the first back panel on the cnc.  I used a -0.007" tolerance as you usually need some tolerance to get things to fit.  It was way loose.  So I cut a second one with +0.002".  Still loose.  Super weird.  Then I went and looked at the template and sure enough the new Whiteside pattern bit i got was overcutting.  Try number three at +0.015" did the trick.  I would be more annoyed if I had only just enough plywood for all the back panels.  But some idiot had already used half a sheet for something else so I gotta go buy more anyway.  Of course it's supposed to rain for the next two days.
  • 1 month later...
Been a while since an update.  This week I routed a few dovetails.
The layout of the tails is pretty odd because of the curved side.  Some of them have two tails on one side and one on the other because the top of that side of the drawer is going to get cut off.  The bottom drawer has one tail on each side but in different places.  This drawer is going to have three levels to it, to make use of the odd space at the bottom because of the way the case curves up there.  So the middle section will be deeper than the two sections on the sides.  It's not a big drawer so this may seem silly, but jewelry isn't big either.
Nine drawers in each box.  I made one extra set of parts for each drawer in case I screw something up later, so twenty-one of each drawer.  So that's 189 drawers.  I don't think I have the stomach to start on the grooves for the drawer bottoms just yet tomorrow so perhaps I'll just work on my website redesign.
4 minutes ago, wtnhighlander said:
I've been following this crazy build on YT. All I can say is, More power to you! I would have totally pulled my hair out, long before this.
I've been following this on YT as well.. I'll admit that when I saw the post here, I ran to YT to see if there was a video...lol
Looking forward to seeing how you pull this one off!
very nice work!
very nice work!
Monday night!  It's a boring one though.  First half stock prep.  If you survive that, the long version of what I wrote above.  I imagine it's going to take a week to get the drawers assembled before things get interesting again.  I would just assemble drawers for five of them to get things moving as the sooner I have something done the sooner the chance to start selling them.  But being able to fit each drawer once and repeat the same thing for the rest with the same setup is kind of the whole point of making 20 of them so I've got to muddle through all of it.  Which means I'm going to have stacks of drawers everywhere, in addition to the boxes themselves stacked up on the table in the other room I normally stack that stuff on to get it out of the way.  I need to build the storage shelves I'm going to store these things on long term so I can free up the table.
  • Who's Online   0 Members, 0 Anonymous, 60 Guests (See full list)
