SirNot Posted December 19, 2018 Report Posted December 19, 2018 So, I'm getting a new bandsaw for Christmas. Yay for me! The specs call for a 100 3/4 inch blade. Most of the good blades that I'm finding are either 100 1/2 or 101 inches. So I guess my question is, how much of a difference does that 1/4 inch make and do I go 1/4 bigger or 1/4 smaller? FYI, I'm looking at Timber Wolf blades from Grizzly... Quote
Isaac Posted December 19, 2018 Report Posted December 19, 2018 I'm going to follow this. I've always thought you needed this to be dead on. I've never tried anything but the exact size. Quote
Tom King Posted December 19, 2018 Report Posted December 19, 2018 I would think it should work fine. When I'm ordering a blade for a bandsaw, I stay towards the shorter end of the range. I bought a 24" cheap because the previous owner couldn't keep a blade on it. I measured the blade curled up in the machine after I got it home, and it was right at the max length for the saws range. I ordered one a couple of inches longer than the shortest end of the range, and it's done nothing but run perfectly ever since then. Quote
Mark J Posted December 19, 2018 Report Posted December 19, 2018 25 minutes ago, SirNot said: So, I'm getting a new bandsaw for Christmas. Yay for me! The specs call for a 100 3/4 inch blade. Most of the good blades that I'm finding are either 100 1/2 or 101 inches. So I guess my question is, how much of a difference does that 1/4 inch make and do I go 1/4 bigger or 1/4 smaller? FYI, I'm looking at Timber Wolf blades from Grizzly... Ditto for me. My new bandsaw calls for 116 1/4 inch blade. An odd size. I have to investigate with Jet if there is an allowable range. Quote
Tom King Posted December 19, 2018 Report Posted December 19, 2018 Usually, the blade size range is shown inside the top door. 2 Quote
Isaac Posted December 19, 2018 Report Posted December 19, 2018 My craftsman uses 99 3/4, and that is all I've ever tried on it. Never occurred to me try something else, though I do know there are a few similar sizes, so I guess it probably would be fine. It also says to use 1/4 to 3/4 blades, and I regularly use a 1/8 inch wide blade on it, no problems. Quote
gee-dub Posted December 19, 2018 Report Posted December 19, 2018 As long as the blade can be tightened to proper tension within the range of your saw's adjustment, you're fine. BTW, just call Suffolk and order the size you want, it doesn't cost any extra. Same for most quality blade suppliers. I always just order 131-1/2". Whatever minor differences there are to enable them to weld between teeth has never been an issue. Even my 10" saw can adjust for 1/4" in difference. 1 Quote
Chestnut Posted December 19, 2018 Report Posted December 19, 2018 52 minutes ago, SirNot said: So, I'm getting a new bandsaw for Christmas. Yay for me! The specs call for a 100 3/4 inch blade. Most of the good blades that I'm finding are either 100 1/2 or 101 inches. So I guess my question is, how much of a difference does that 1/4 inch make and do I go 1/4 bigger or 1/4 smaller? FYI, I'm looking at Timber Wolf blades from Grizzly... Check the bandsaw manual mine says 115" and specifies a tolerance of 114 13/4" to 116". So it seems like toms advice of being towards the bottom of that range is better. 1 Quote
RichardA Posted December 20, 2018 Report Posted December 20, 2018 The blade size given for any bandsaw, is just a guess. Adjusting the tension will make your blade a tad longer or shorter than the average that they specify for that saw., generally it's longer when you tension the blade. But you can measure your "new" blade and it may or may not be the "exact" size you ordered, but it will be very close. Quote
Battle Ridge Posted December 20, 2018 Report Posted December 20, 2018 I like the bi-metal Lenox Diemaster 2 blades and run both the 1/4" 6tpi and the 1/2" 4tpi with each providing great cut quality, durability and overall value. I get them from bandsawbladesdirect.com and they have free shipping on orders over $100 with orders filled and delivered quite quickly. Each blade is made to order and you can specify the length to the nearest 1/8". Other blade suppliers also offer blades built to the size you specify and the price can be as cheap and at times less expensive as pre-boxed blades. The specs for my Laguna 18BX is for a 143-3/4" to 145-1/2" blade length and I order my blades 145". With this length, should an unexpected blade brake occur that doesn't otherwise damage the blade, there can be an option to have the blade repaired which may not be possible with a shorter blade, though I have yet to have a blade fail for me. 1 Quote
AceHoleInOne Posted December 20, 2018 Report Posted December 20, 2018 http://www.woodcraftbands.com/ Where I get all my bands. Do yourself a favor, give this guy a call, super nice and can tell you all about bands and the saws. -Ace- 1 Quote
