SawStop inadvertent brake activation causes
On 11/20/2022 at 6:35 AM, JohnSH said:
On 12/28/2018 at 8:56 AM, Mark J said:
I have a 4 month old SS pro table saw. Yesterday the brake activated, either at the very end of a cut or after. Didn’t hear or sense anything. Went to cut again - red light was on and blade was immobile. No visible damage to the blade. Wood was totally dry. Kiln dried white oak. Any idea why?
I second Chet's question.  Did the safety feature fire and drop the blade below the table?  If not then something else is going on.
  • Replies 136
  • Views 48.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I cut off a small, thin triangular piece of wood from a wood block.  The triangular piece jammed between the blade and the insert stopping the blade.  I used the red paddle to shut off the saw.  I rea
  • The condition of the blade after any activation is something that seems like too many people take for granted.  It may appear to be okay to the naked eye, but there can be microscopic damage to the br
  • Mine was from cutting some anti-static UHMW material that I had scrounged from some electronics packaging at work.  Boy, I sure saved money by scrounging that waste material didn't I !?!  The moment I
Posted Images
On 3/9/2022 at 8:51 AM, gee-dub said:
I would absolutely send them the cartridge.  That way you would have a definitive answer.  Not necessarily one you may like but, definitive.
As to staples and bullets.  I have sawn right through embedded material.  Small items don't seem to have enough conductive effect on their own.  I have triggered the saw when I have accidentally cut something conductive while I am touching that conductive thing by holding the material against a miter gauge.  The system is made to detect the skin that wraps up us big ole bags o' water :).
After my first dumb-guy move of trying to saw conductive (anti-static) UHMW I became real careful.  If there is any suspicion I make a cut in safe mode.  The thing that'll tick you off is if you had no reason to suspect or bother to test in safe mode and you fire the system :angry:.
I cut thru a staple one time and a piece of the staple caught between the brake and blade and activated it. Right place and activation.
Sent  the cartridge in and it was source of activation. I think in 7 years I have activated the Sawstop system 4 times. 2 times were operator error and twice Sawstop error.
  • 2 years later...
I cut off a small, thin triangular piece of wood from a wood block.  The triangular piece jammed between the blade and the insert stopping the blade.  I used the red paddle to shut off the saw.  I reached for the jammed piece of wood to remove it, and heard a click.  The click was the brake triggering.  Even though the blade was stopped dead and the red paddle was off there is a delay before the safety system is deactivated.  I was just too fast in touching the blade.  Turn off the red paddle and the main power switch and watch the indicator lights before touching the blade.
Ok that's a new one :)
Thanks for sharing!
Yes, you're correct.  I think it's a 3 second delay.  Thanks for bringing it up, and sorry that happened to you.  Were you able to reuse either the blade or the brake?
  • 3 weeks later...
I've had (2) brake activations with my PCS 3HP, both were mysterious to me. No skin contact and no conductive/wet material. I cut kiln dried maple and walnut hardwood. I inspect all boards, pull staples, and check with a moisture meter. My 1st activation was 6/14/23, I called Saw Stop to report it. After explaining the event which involves a standard repetitive process of sawing kiln dried hardwood (same process I've done for many years). The customer service rep immediately suggested I was inexperienced and probably activated it running wet wood through or from poor technique. I assured him that was not the case but he continued to be defensive and I left that call feeling like Saw Stop CS is not here to give support to it's customers. I also mentioned that I run a business with this saw and needed a solution to keep me up and running. They did not even attempt to help trouble shoot with a tech or try to find a solution to get me up and running. Keep in mind I haven't even sent the cartridge to them yet. I needed to keep my business running while the cartridge was being mailed. After inspecting the saw internally I decided to use my extra cartridge and install a new blade, it then cut with no issues.
So that day I overnighted the cartridge back to saw stop. They analyzed it and replied back 7 days later with, "we determined that the activation was most likely caused by a problem with the cartridge cable or the arbor." They emailed me a "Service Procedure SP-CNS-190718-002 Inspecting a Rev 2 Arbor Lead Circuit Board." Basically they wanted me to re-tighten (2) screws that carry the signal from the circuit board to the cartridge. The way I understand this is, I should pay $200 and experience business financial loss, then spend time un-assembling/re-assembling Saw Stops poorly engineered part.
Once I received the evaluation back from Saw Stop I was already nearing a hundred BF run through the saw with my extra cartridge and blade over those 7 days so I'm still a little suspicious on their evaluation. I still believe Saw stops owes me at minimum a new blade and cartridge from this event.
My 2nd activation occurred 3/18/25. I just installed a brand new blade and immediately when flipping on the paddle switch the brake activated. I'm not going to waste the money to send them this brake. I'm already out (2) blades and (2) brake cartridges. They don't pay for the brake shipping and wont send a replacement brake so that's just even more money and time down for me.
I am starting to look at other more reliable table saws for my business. I do like the concept of their saws but I am questioning how professional and reliable their brake system is and very disappointed with their customer service. I also am starting to add up the unnecessary costs of brakes and blades for more or less poor engineering/manufacturing.
@roughsawn - Agreed. Any time I am going to do anything questionable I make the first run in bypass mode and check the lights. Takes less time and money than guessing.
But @DC Wood complained of brake activations when he was partway through a number of identical cuts, so just testing the first cut in bypass mode wouldn't have helped.
If several people had the sort of problems DC reported, it would be all over the wood working community.  Since tons of people have Sawstops and don't have these problems, my guess is that there is a problem specific with DC's unit.
I had to replace the control circuit board on my Sawstop (after many years of use).  It wasn't misfiring the brake, it just wouldn't give me a green light when I turned it on.
This sound to me like you may have forgot to adjust the distance between the brake and blade.  If they are too close you can get an activation.
Maybe not but my knee-jerk reaction as an experienced SawStop user is . . . Ding, ding, ding.  The triggering mechanism is fairly complex but you need only send in the cartridge for analysis to confirm. Proper setup of the physical orientation is required of the operator.
Roughsawn and Gee-dub I do use the spacing gauge on blade switches so I don't believe that's the issue and I use bypass mode if I ever run something questionable which is rare because I consistently run kiln dried hardwoods (mostly maple and walnut). I also test a few boards with a moisture meter per bunk. Nothing scientific just a quick check. It kind of goes without saying but I also inspect and pull all staples.
Gee-dub, your correct the brake analysis is the only way to get Saw Stops opinion on what may have caused the issue. So I will send the 2nd one in. And I also agree the triggering system is complex so maybe I'm having an unusual issue with a part of my saws system malfunctioning. When I spoke with Saw Stop CS last week they suggested I may need to replace my arbor circuit board & wire harness or some other electrical parts but that was just speculative.
As far as getting back up and running, I overnighted 3 new brake cartridges and blades. I inspected the entire saw, the 3 arbor circuit board screws are tight, checked the wire harness, checked for anything loose and found no issues. I installed the new cartridge and blade (with spacing gauge as usual) then ran in bypass mode to test. I didn't see any errors from the LED's. Saw is running with no issues. Sure is a mystery.
I think for my use, I'm going to look into installing an A/B switch for reliability so I can run the saw with no brake at all. Instead of having to have a cartridge installed and re-initiate by-pass mode every time start/stop (which is fine but a bit annoying) I can just run it with a separate paddle switch & A/B switch. I need the saw to primarily run every day so that will solve that issue if I'm having more false triggering and need more time to investigate/troubleshoot. I wish it was more obvious what is causing the activation but for now its a game of wait for the next one and hopefully there wont be a next one...
