Ideas to fix marring
I need some help on how to remove these marks from bubble wrap.
The biggest problem I have is the tables are in AZ and I'm in MI and can't even touch them.
The finish is a wb poly that had set for two days before I wrapped them in bubble wrap and shipped them to my client.
The fix has to be something an armature can do. Or I'm going to have to see if I can find someone in their area I can have do the fix.
2 days cure that's surprising... What WB poly did you use? How was the finish applied?
Sanding with ~500-600 grit and another application of poly would fix it but WB can be tricky. If it was a wiping poly maybe.
Drew it was polycrylic.  Three sprayed on coats
I have no idea if the client has the ability or knowledge to do anything.
I may have to try and find someone in AZ to fix them
It takes nothing for polycrylic to flake or bubble. Just a little heat will cause it to lift.  Polycrylic should only be used in places where there is no continued use. Aka: a display shelf. I have no idea why it was invented, but for any kind of furniture it's totally useless. A light sanding with a very high grit, and then a reapplication will fix the problem, but it's a table. I assume the table will get some use, if it does, the problem will arise again and again. Polyacrylic doesn't adhere to the wood, it lays on top of the wood, and that makes it subject to easy movement causing the problem.  My inclination would be to take it back to bare wood and apply a wipe on poly like ARS or minwax waterborne poly.
Probably not as surprising as you would think given they are having an unusually hot summer even for AZ. Think 90's for over night lows and 112 ish during the days
Did you mean Minwax wipe on poly? Isn't Polycrilic is Minwax's water born polyurethane? I don't use their products much only wipe on poly.
I figured the higher heat would cause the cure to go faster and that 2 days would be enough. Guess a longer cure was in order before shipping. Unless your implying that the heat melted the finish?
I'm not surprised at all that the bubble wrap left marks. There are not many curing finishes that are fully hardened after only 2 days. Most stuff takes a good month to fully cure.
I've seen that heat melt the rubber of a shoe sole so it would not surprise me if it affected a finish on a product wrapped in bubble wrap...having said that no idea whether that's possible :)  I do agree with @drzaius that most finishes take a month or better to fully harden.
Taking it back to bare wood is not on the program right now, I'm in MI and the tables are in AZ.
I have done some research after posting the first post and this is a common problem with bubble wrap.
I have shipped several tables and jewelry boxes in it before but this is the first time using this make of wrap
Two of the sights one a guitar sight and one a piano sight they used Maguire's car polish and it took them out without ruining the finish.
I think I might have them try that
Polycrylic, is a different product than Minwax's wipe on poly or their regular brush on type. For some reason, it will not bond to the wood, like any normal poly will. I've used it twice, and still have 7/8ths of a can, and can't find a reason to use it again, except on something that doesn't get used regularly. It peals, it bubles up if it gets to warm, then later peals off in flakes. I've never had that problem with any regular poly, including ARS.
Larry, do you still have some of the bubble wrap? Does it have any kind of oily finish on it? Probably not but just a thought.
@coop I have a box of it, it does not have an oily feel. What I picked up on the guitar site I read some bubble wraps have silicone in it and that is what does it. I have shipped other things in a product from Home Depot
With no problem this was a box from U-Haul
Maybe take a scrap or three of the same wood and replicate the whole process and see if you can come up with a solution. Kind of like they do with the Space Shuttle.
I have my sample finish boards wrapped up already going to wait the three days it took to ship and see what I can do
Here's the fix I used
I wrapped the sample boards in bubble wrap and then a heating pad.
It duplicated the problem, I tried Maguire's car polish but it did nothing to remove the marks, I then tried Turtle wax scratch repair and renew which took all the marks out. I sent a bottle to the client and thankfully they were able to fix the tables.
I wrapped the sample boards in bubble wrap and the a heating pad.
Nice!! Glad it worked out.
Larry,  This is a great ending to what could have been a heartbreaking situation.  I was ready to suggest a refinishing shop in the area if one exists.  Glad the fine abrasives did the job.  I have used Nova plastic polish products to rub out problems with good success.  I have not had the problem with Polycrylic that Richard reports.  I do only use it when I want a clear, clear finish and it has only been used on wall cabinets and occasional tables, nothing that sees real wear.
@gee-dub ya it could have been a very bad deal. The clients were very good about the whole thing.
If this had not worked I was going to seek help from here for a refinisher in the area.
