Stickly / Shaker hybrid display cabinet
Great job! Looks wonderful.
  • Replies 107
  • Views 23.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • wtnhighlander
    wtnhighlander
    I wouldn't normally 'deliver' a not-quite-finished project, but after 15 months, this thing's footprint was just too much to work around any longer. First pics in the house: Still expe
  • wtnhighlander
    wtnhighlander
    Some redneck engineering and random hardware helped me size the cabinet doors as a single unit. They had to be tapered a bit on the outer stiles, because of the slightly out of square carca
  • wtnhighlander
    wtnhighlander
    Ok folks, time to call it a wrap. Final shots with paraphenalia ensconced and illumitation activated. I'm sure the items on display will rotate seasonally. For accent lighting we chose
Posted Images
Very nice! I like the contrast of the back panel.
Who is the cowboy in the pic?
  • 4 months later...
On 11/4/2023 at 6:33 PM, wtnhighlander said:
A little shop time during football today. Got the panels cut and the sides dry-fit.
Some of this walnut is quite poorly sawn, but at least it is thick. I needed to take near 1/4" off a piece to get it flat, so I rigged a setup that I'd seen done with a router table, only I used my TS and just the chippers from my dado stack.
After setting the cutter height to match the strip of ply, I ran the ply part way through to remove the width of the cutter. This offset provided a 'fence' leading into the cut, with support behind the cut. By taking successive passes, with the 3/8" rabbet formed by the previous pass supported on the ply, I was able to mill a fairly flat face.
A little hand plane work removed the tracks. Much easier to take a few shavings from a relatively flat board, than to plane away 1/4" or more of gnarly crotch grain.
@wtnhighlander  I have been doing some research on book matching panels or just keeping the grain flowing across boards, for example the grain flowing through drawer fronts across the front of a cabinet.
TBH I have not tried it much and when I have played around with it in the past I feel like I could not get the grain to stay after cutting apart and milling. For example I would try to spit 5/4 into two book matched boards or cut my two parts that I want to flow and after I got the boards milled to final thickness the grains were different and did not have that bookmatched or flowing look.
Do I need to keep the parts in one common board and mill that to thickness before I split open or cut into the individual parts?  I was worried this would release tension and the board would warp or move?  Do I just need to be more careful and take exactly the same amount off each face?
@Woodworking_Hobby, in my experience, the best bookmatch occurs when the matching faces come from as close to the same plane in the board as possible. That means doing everything you can to keep the kerf narrow, and surfacing the sawn faces to a minimum.
If you can, split the board with a bandsaw, using a blade that has been 'stoned' to reduce the set of the teeth. Set up the saw to take the smoothest possible cut, so minimal refining of the surface is needed. If thicknessing is still necessary, remove stock from the unmatched faces.
Even after all this, beware that the grain runout on the matched faces is still in opposite directions, so chatoyancy, and sometimes color, will still differ between the two halves when viewed from different angles. This is especially evident in figured stock, so if uniform color is important, I suggest using material with the straightest grain possible.
Some of the panels in my project are glaringly different on each side, and the appearance changes as the sunlight from the windows advances across the room. It can be distracting.
In addition to everything wtnHiglander said above, sometimes the grain pattern can shift along the length of the board as you go down ...
my diagram isn't very good, but consider a cathedral grain pattern on the top face (dark green) and the grain running down the side (red) then the same-ish cathedral pattern will be on the back face lower down the board (light green)
Sorry I don't have a better photo to show it ... But as an example of this, when I was trying to get four matching faces for the top of my music cabinet, there was quite an offset between the veneers ... in the top-left panel you can see I had to include a check that was at the top of the board (eg blue line in diagram). The check is also visible but smaller in the bottom left board, which was the opposing cut face, just one kerf away, but not present in the two right hand panels because I had to offset the veneers about 4 inches to match the pattern (these were fairly thick veneers). There was still some noticeable offset needed between the faces opposite the same kerf.
What I am trying to say is that sometimes, if the grain is doing this and you have a thick kerf, it might be best to resaw the board first, and then offset it slightly before cutting out your pieces to get a better match.
