Stickly / Shaker hybrid display cabinet
  • Replies 107
  • Views 23.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • wtnhighlander
    wtnhighlander
    I wouldn't normally 'deliver' a not-quite-finished project, but after 15 months, this thing's footprint was just too much to work around any longer. First pics in the house: Still expe
  • wtnhighlander
    wtnhighlander
    Some redneck engineering and random hardware helped me size the cabinet doors as a single unit. They had to be tapered a bit on the outer stiles, because of the slightly out of square carca
  • wtnhighlander
    wtnhighlander
    Ok folks, time to call it a wrap. Final shots with paraphenalia ensconced and illumitation activated. I'm sure the items on display will rotate seasonally. For accent lighting we chose
Posted Images
This cabinet design would normally include an overhung top with some sort of edge profile. Material supply prevented me from making a panel large enough for that, so I did a molding, instead.
The profile is like so:
Then I routed a rabbet around the top, so the large lip of the molding would inlay flush.
Getting closer.
Here is an updated full shot.
Test piece. Like you, I’d hate to ruin the look of what walnut offers.
I have used aqua coat and do not like it.  it does not appear to yellow and all and it does not really fill the grain.  While it dreis quickly and sands nicelyl, it shrinks so much that it really does not fill the grain any better than a coat of Arm-R Seal.  The only andvantage is that, since it dries so fast, you can do a lot of coats in little time.  Which is good because you need lots of coats.
Additional thought.....I like SolarRez " I don't believe its not laquer" ( Yes, that's the name)  Very thin.  A little goes a long way. Works like epoxy and dries when exposed to ultra violet rays - 5 minutes in the sunlight.  Sands l ike a dream. Does not shrink.
Not much worthy of pictures lately. Sanding, knot-filling, sanding more. I did make a pair of these:
I call them "wobble-stoppers". One side will attach on the inside of each back leg, with lower portion held only by the screw. Tightening the screw draws the inclines together, giving about 1/2" of movement. My shop floor isn't flat, so I can't be sure the case won't wobble in the house. These give me just enough adjustment to take up any slack.
To make them, drill the 1/4" hole for the screw first, then saw the angle, then enlarge the holes on the angled edges to 1/2", about 1/2 the depth of the hole.
I used a T-nut for convenience, but gluing in a regular nut could be a better solution.
Is that 45*?
2 hours ago, wtnhighlander said:
then saw the angle,
10 hours ago, Mark J said:
Is that 45*?
Probably should be, but I just set my bevel gauge to something that looked good and ran with it.
I wouldn't go any steeper than 45*, as it would make the adjustment too 'fast', and the screw hard to turn.
These have too little stroke to replace a leveling foot where one is needed. This is more like having a built-in adjustable shim. They are nice in that the screw is acccesible from the back, not beneath.
IMG_20240724_182324608.thumb.jpg.efdcc3b817a9976180f25e4df9fd5ecb.jpgIMG_20240724_182339835.thumb.jpg.263f8754cc593ccf82acba64f181ba45.jpgIMG_20240724_182351271.thumb.jpg.10602cee24f6bb58157d1d7cb6ec6f14.jpg
Still experimenting with location, and I have to finish the interior floating shelves. There are plans for accent lighting as well.
I'll post a final 'beauty shot' when it is truly complete.
Dang, even in the living room, more than twice the floor space of my shop, I still can't seem to frame a shot that doesn't have screwy perspective...
Agree with @Coop absolutely beautiful and worth all the effort that you put into it, thanks for the ride, well done sir!
IMG_20240728_135052780.thumb.jpg.dcb6042a798544fed85699ddf5b66f23.jpgIMG_20240728_135037320.thumb.jpg.10814e8e5d95e63f0fde73fc06df4f01.jpg
For accent lighting we chose some thin LED light bars, rechargeable, that attach magnetically to metal plates under the shelves. They are dimmable (full brightness shown), and include selectable motion sensors that can activate when a door is opened. When a recharge is due, remove from the magnet mount and charge with USB-C.
One drawback to my design is that the reveal around the inset doors is highlighted by the lighting. Not a big deal, but something to consider for future projects. I like insets, but perhaps inset to a rabbet or ledge would look better in this case.
PS: Used variations of these lights.
