Mark J Posted November 11, 2023 Report Posted November 11, 2023 I know one is not supposed use a powered jointer to joint the edges of a plywood panel, but I can't remember the reason why? Quote
BillyJack Posted November 11, 2023 Report Posted November 11, 2023 You could use router bit and a straight edge.. For manageable pieces I have a router table setup.. Quote
Popular Post Tom King Posted November 11, 2023 Popular Post Report Posted November 11, 2023 Glue is harder than wood, and not kind to jointer knives. It's hard to get a clean edge on plywood over a jointer. 4 Quote
Mark J Posted November 11, 2023 Author Report Posted November 11, 2023 41 minutes ago, Tom King said: Glue is harder than wood, and not kind to jointer knives. It's hard to get a clean edge on plywood over a jointer. Would you say it is more dangerous then edge jointing a board? Quote
BillyJack Posted November 11, 2023 Report Posted November 11, 2023 On 11/11/2023 at 8:50 AM, Mark J said: Would you say it is more dangerous than edge jointing a board? ? On 11/11/2023 at 9:46 AM, BillyJack said: ? Why would it be more dangerous? Quote
drzaius Posted November 11, 2023 Report Posted November 11, 2023 I ran a length of plywood over the jointer once and it left the knives slightly jagged, kinda like a bread knife. Not dangerous to do though. 2 Quote
curlyoak Posted November 11, 2023 Report Posted November 11, 2023 If you must sacrifice for the project, and cant find another way, try a very small cut. You might get lucky. Mostly avoid for the sake of the knives. No extra risk... 1 Quote
Tom King Posted November 11, 2023 Report Posted November 11, 2023 The only added danger is to the jointer knives. Plywood edges are best done with sawing, sanding, or high speed sharp router bit. 2 Quote
Tpt life Posted November 11, 2023 Report Posted November 11, 2023 Jointing end grain can lead to some tear out. If any glued ply is sub standard, you can introduce voids in the plies. 1 Quote
Coop Posted November 12, 2023 Report Posted November 12, 2023 My first and only experience with doing this led to a less than desirable finished edge. 2 Quote
Mark J Posted November 12, 2023 Author Report Posted November 12, 2023 Thanks for your responses. The question came about because I saw one of the students triming a plywood shelf on the jointer at the highschool. When I went to correct him I couldn't remember why it was a bad idea. Especially when I found out he'd already done the operation several times. Their project is an end table with a lower shelf of plywood that has to fit exactly between the 4 legs, so length and width are unique to each project. Not necessarily how I would do it, but these are the plans they use. The edges he got were fuzzy, but otherwise flat. The jointer in question is a big 12" Powermatic with carbide cutters, so maybe the cutters survived better than straight knives. I like the router table approach that was suggested. I'm stopping at the end of this semester, but if I return next year, I may try to implement that idea. Quote
BillyJack Posted November 12, 2023 Report Posted November 12, 2023 You can use a jointer for plywood. When we joint plywood, laminate, etc and it’s hard on the jointer blades, we will set the fence back as far as it will go and use the first inch.. 1 Quote
Tpt life Posted November 12, 2023 Report Posted November 12, 2023 I want to mention something I saw my dad do at a cabinet shop, that seems relevant here. I watched him joint a stick, and the finish was awful. It was awful, but straight. He never paused, but walked it over to an oscillating belt sander, and had the finish corrected in seconds. It changed the way I think about jointing at times. If you just need straight, sometimes the finish gets hidden or can be easily corrected after. 2 Quote
Mark J Posted November 12, 2023 Author Report Posted November 12, 2023 1 hour ago, BillyJack said: You can use a jointer for plywood. When we joint plywood, laminate, etc and it’s hard on the jointer blades, we will set the fence back as far as it will go and use the first inch.. Good to know, but I still like your router table solution better. Quote
Mark J Posted November 12, 2023 Author Report Posted November 12, 2023 55 minutes ago, Tpt life said: I watched him joint a stick, Stick? You make a good point, the finish in this case wasn't a primary concern. The student was just trying to nibble off a bit of the panel length. Quote
Mark J Posted November 12, 2023 Author Report Posted November 12, 2023 What we've been doing with the other students, and has worked well, is to use the table saw and rip fence set up such that we take off half a blade width. The panels are roughly 14 x 18 so even the "short" sides are long enough to register off the fence. But as Tpt may be able to confirm, not every student is paying attention when the instructions are given. In any case, to this student's credit he did find a solution to his problem. Quote
BillyJack Posted November 12, 2023 Report Posted November 12, 2023 I don’t have a jointer and only a few times wish I had one. The router seems to cover most things. The bits are cheap and only $5 to sharpen Quote
wtnhighlander Posted November 12, 2023 Report Posted November 12, 2023 @BillyJack, do you work with rough sawn lumber? If so, what is your solution for flattening faces without a jointer? Quote
BillyJack Posted November 12, 2023 Report Posted November 12, 2023 I don’t buy rough sawn. I buy from a reputable dealer. When I worked at Commercial Millwork & specialty company we use a planer on rough sawn.. 1 Quote
Tpt life Posted November 13, 2023 Report Posted November 13, 2023 8 hours ago, Mark J said: Stick? 1x2, 1x3? Don’t know the dimensions. Just know it was a long thin rip fresh off the table saw. 1 Quote
