This is looking great! As for your glue question, TB3 always seems a little more "watery" than TB2 (just my observation). But unless you used TB2 on one face and TB3 on the opposing face, I don't see how it would make any difference. Maybe the longer working time of TB3 just gave the panel more time to move?
  • Thanks 1
Agreed definitely more watery then the TB. I did use the same glue on both faces but left them in the press the same amount of time which was about 90 min. I'm thinking I should have left them in the press much longer but may run a test to see how that pans out. I did have them clamped to my bench over night and the one that cupped was on top meaning only one face was covered also thinking that could have played a roll. Thanks for your input!!
On 1/3/2026 at 8:09 AM, Mark J said:
Yeah, I'm not sure I would blame the glue.  Do you know if the plywood was flat before you applied the veneer?
Agreed guessing it was user errors. The plywood was not perfectly flat, maybe out 1/6" over the length, but the one panel definitely cupped after applying the veneers
Handsome work.  When it's done it's going to look great.
With the marvelous doors you're making, it's also going to be heavy as wall hangings go.  Do you know how your going to anchor it to the wall?  Will you mount the doors before or after the carcass goes on the wall?
'nuther question.  What are you using for the door hinges?  They are going to be under a lot of load.
  • Who's Online   0 Members, 0 Anonymous, 36 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
