Ron Swanson Jr. Posted February 6 Report Posted February 6 On 2/5/2026 at 9:55 PM, pkinneb said: Finished prepping the chisel holders, starting with cleaning up the dado for the magnets Then I laid the magnets in. They are friction fit but to insure no movement during glue up I just used a dab of thick super glue on each end. Then I spread out some glue, taped them together. and set them in the vacuum bag to dry. Once dried I needed to relieve the edge by the pull so that it did not sit above it. A couple swipes with a rasp and it was good to go. Then I clamped them to the inner door and screwd them in from the back With those done I started working on the bevel so the door would close, quick work at the bench with a hand plane. Still need to dial in the gaps a bit more but getting there. This thing is a work of art, Paul! 1 Quote
Von Posted February 6 Report Posted February 6 Very nice! Where did you find the magnets for the chisel holders? 1 Quote
Popular Post pkinneb Posted February 6 Author Popular Post Report Posted February 6 On 2/6/2026 at 7:13 AM, Von said: Very nice! Where did you find the magnets for the chisel holders? Amazon, here is the link: https://www.amazon.com/dp/B07DFZH4WT?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_4&th=1 FWIW I found about 1/16th to 3/32nds of an inch wood over the magnets provides enough holding power but still easy to remove the chisel's. I started with closer to an 1/8" but decided it felt a little sketch. Probably would have been fine but the last thing I wanted was one to fall out and chip the end or something. 2 1 Quote
Von Posted February 6 Report Posted February 6 Thanks. I like your approach. I made my chisel holder with round disc magnets installed from the front and covered with plugs, but your approach is more flexible since you don't have to worry about landing the chisel on magnet. 1 Quote
Popular Post pkinneb Posted February 8 Author Popular Post Report Posted February 8 Today started with marking the desired inner door gaps Then using a plane I dialed them in Before reinstalling the door I finished the faces off as well This will work Next I needed to make the magnet blocks to hold the inner door closed. I started by routing a recess for the round magnets Then did the opposing ones in the door Then I glued them in Next up on the list was to deepen the main door hinge recesses I had about an 1/8" gap and wanted closer to 1/16" That's better 5 Quote
Popular Post pkinneb Posted February 22 Author Popular Post Report Posted February 22 Got the other inner door DT's cut today. Dang I can make a mess! All better I need to get moving on this hoping to finish in the next month or so as I will need to move back out side to finish the deck, outdoor kitchen, and a couple other quick outdoor projects before we leave on our Route 66 trip in May. 5 Quote
Chet Posted February 23 Report Posted February 23 On 2/22/2026 at 3:20 PM, pkinneb said: Route 66 trip in May. That ought to be a blast. Just the two of you or are you doing it with a group? Quote
Popular Post pkinneb Posted February 23 Author Popular Post Report Posted February 23 On 2/22/2026 at 6:33 PM, Chet said: That ought to be a blast. Just the two of you or are you doing it with a group? Just the two of us. Looking forward to it for sure, been a bucket list item for a while. Taking a little over three weeks for the trip. We'll start in Chicago and end in Santa Monica before heading north in CA to see the redwoods then back home. I can't wait. Its the 100th anniversary this year so lot's of extra stuff going on along the route throughout the year. 4 Quote
Popular Post pkinneb Posted March 1 Author Popular Post Report Posted March 1 Today I recut the dove tails on one side of the inner door becuase I forgot to leave room for the hinge strip, twice!! First I thought dang I forgot the hinge strip so I shortened them a 1/4" and recut the DT's before remembering there is a strip on the door as well so I took off another 1/4" and recut them again! Facepalm Then I cut the back panel as I did on the first door and glued it up. Another mistake today as I forgot to cut the door pull before glue up, not sure how I will fix that After hanging the right main door I glued the hinge strip to it Then cleaned up the squeeze out. After it dried a couple of swipes with a hand plane to flush it up and then a quick final sand Once the inner door is done I will start on the lower drawer bank So I milled up some stock for that. 6 Quote
Popular Post pkinneb Posted March 7 Author Popular Post Report Posted March 7 Back at it today. Kicked off by final milling the material for the drawer case framing under the shelf. Then cut the sides, top, and bottom to length Cleaned up the long grain edges with my #4 A couple passes to go from this to this Then did the same on the end grain with a shooting board and my #5 until they fit under the shelf Some nice end grain shavings right there Next up I laid out for the box joints I will be doing at the TS. This centering ruler doesn't get used much but when you need it its nice to have Knocked out a quick fence to do 3/8" box joints Then knocked out the ends Followed by the top and bottom It will need a little fine tuning once its glued up but close enough for now Last up today I determined and laid out for the drawer frames 7 Quote
fcschoenthal Posted March 8 Report Posted March 8 With dovetails for the cabinet and box joints for the drawer case, what do you have planned for the drawer frame joinery? 1 Quote
Coop Posted March 8 Report Posted March 8 Does the ruler have a hook on the end? I tried to zoom in to see the brand but couldn’t get close enough. 1 Quote
Popular Post pkinneb Posted March 8 Author Popular Post Report Posted March 8 On 3/7/2026 at 6:00 PM, fcschoenthal said: With dovetails for the cabinet and box joints for the drawer case, what do you have planned for the drawer frame joinery? DT's. I thought the box joints would be quicker and since you will never see them decided to go that route. Ultimately I probably could have done DT's quicker. On 3/7/2026 at 6:38 PM, Coop said: Does the ruler have a hook on the end? I tried to zoom in to see the brand but couldn’t get close enough. Yes. Its a Woodpeckers I really like their stainless rulers, I find their red ones hard to read with my crappy eyes 4 Quote
Popular Post Chet Posted March 8 Popular Post Report Posted March 8 On 3/7/2026 at 3:42 PM, pkinneb said: This centering ruler doesn't get used much but when you need it its nice to have Yeah, I have the 6", 12" and 24". They are the only Woodpecker's gear that I have other then the 6" Paolini stainless steel ruler you recommended for old eyes. Over the years that I have had them the 6 and 12 inch have been used the most but I count them all as useful investments. 4 Quote
Popular Post pkinneb Posted September 20 Author Popular Post Report Posted September 20 So after a 6 month hiatus, to work on summer outdoor projects, I'm finally back in the shop... First up was to make the drawer webs so after some layout I got the PR set up to cut the mortise and tennons Then glue up One done The webs are complete While those were drying I worked on dialing in the gaps and flushing up of the face of the left inner door Next up I had to fix a mistake I made on the right inner door...I forgot to route the handle in it before I glued it up I have been thinking about this for months and the only way I could see to fix it was either carving tools (I don't have) or a burr in a rotary tool...what could go wrong lol While not perfect it came out good enough to keep me from remaking the door With that complete I started to install and work on gaps for this door. Next up I will continue with the drawer framing and more fiddling with the right door installation and gaps. 5 Quote
Botch Posted September 20 Report Posted September 20 I admire that you could set this aside for six months for "summer outdoor projects", you're far enough along I'd be in a hurry to see it finished. 1 Quote
gee-dub Posted September 20 Report Posted September 20 I used to love my wall hung tool cabinet . . . now I'm embarrassed. Looking good man. Keep 'er going. 1 1 Quote
Mark J Posted September 21 Report Posted September 21 I admire that you could set this aside for 6 months and remember what you were doing and what comes next ! 1 Quote
Popular Post pkinneb Posted September 21 Author Popular Post Report Posted September 21 On 9/21/2026 at 8:44 AM, Mark J said: I admire that you could set this aside for 6 months and remember what you were doing and what comes next ! It helps to have these posts to look back at On 9/20/2026 at 4:58 PM, Botch said: I admire that you could set this aside for six months for "summer outdoor projects", you're far enough along I'd be in a hurry to see it finished. LOL gotta work on the outdoor projects while the weather is good. The good news is I started phased retirement, on my day job, in June so I am only working 4 days 32 hours a week with my last day (after 38+ years) 11/20. After that I will just have my business which I can do in 15-20 hrs a week so I should have a lot more time available for shop projects which is great news becuase there is a looong list of pending projects 3 Quote
Popular Post Chet Posted September 21 Popular Post Report Posted September 21 On 9/21/2026 at 11:57 AM, pkinneb said: The good news is I started phased retirement, I think everyone should try retirement at least once in their life. 7 Quote
pkinneb Posted September 24 Author Report Posted September 24 Working through a couple classes re Tambour doors, during breaks this week, as I will need to route the tracks in fairly soon to keep this project moving. Taking a FWW Class with Larissa Huff (side note always look for coupon codes, this class had one for 50% off), A guild class with Philip Morley, and a shaper session on YouTube. 2 Quote
Popular Post pkinneb Posted September 25 Author Popular Post Report Posted September 25 Tonight I started working on installing the drawer frames into the lower case using stop dado's cut at the router table Then I set up the L fence at the TS to cut the tenons After several test runs I got them dialed in Next up I will cut out the fronts so they slide all the way forward Oh and I made an extra web becuase I forgot about the solid bottom 6 Quote
Popular Post pkinneb Posted September 25 Author Popular Post Report Posted September 25 More work on the case dividers today. First up fix yet another mistake I couldn't live with, I mis cut one of the tenons. To fix it I milled and glued some thin stock onto the tenon Then planed it flat so I could recut the tenon Not perfect mut much better Moving on...next I got some hand tools out to clean up the dado's, first I marked the area, then cleaned them up with chisels before dialing in the depth with a router plane With those done I moved on to notch the dividers, first marking them out. then I used a knife to scribe a line on the face Then staying away from the line I cut out most of the waste I cleaned up the final little bit with a sharp chisel I also cleaned up the leading edge with my LN #4 That'll work. Apparently I didn't clean up the face of the web I'll have to catch that tomorrow Time to dry fit the case and start laying out the divider placement Once complete I made up a quick story stick Than marked out the entire case from each side ensuring everything stays square Finally I milled up the divider stock That's it for today. Looking to get the dividers done and then start working on the tambour door track template. 7 Quote
