Popular Post pkinneb Posted September 26 Author Popular Post Report Posted September 26 After determining the divider size with tenons I prepped the stock Then set up the PR for the joinery I found with the short ones that using a scrap and two clamps held better then a single Tenons done Next up the mortises And with that I'm ready to make the tambour door track template. Oh and make a lumber yard run for some poplar drawer stock. 6 Quote
wtnhighlander Posted September 27 Report Posted September 27 Moving along nicely! I bet the panto-router is a real sweet machine to use, once you get the workflow nailed down. 2 Quote
pkinneb Posted September 27 Author Report Posted September 27 On 9/26/2026 at 8:39 PM, wtnhighlander said: Moving along nicely! I bet the panto-router is a real sweet machine to use, once you get the workflow nailed down. Thanks. Exactly, still working on that but it has quickly become one of my primary machines in the shop. 2 Quote
Popular Post pkinneb Posted October 1 Author Popular Post Report Posted October 1 Not much for pics the last few days but making progress none the less. Made a wood run needed some drawer material as well as a nice piece to use on the veneer of the tambour door. I decided the piece I was going to use wasn't doing it for me. Also after waaay too much fiddling I was able to get the right inner door installed and gapped. Just need to add the magnet catches to keep it closed. Oh and figure out what's going here and make the required mounts. Not sure what's next but probably machining the drawer and tambour door stock so it has time to release any tension I cause. 5 Quote
Ron Swanson Jr. Posted October 1 Report Posted October 1 On 9/30/2026 at 9:12 PM, pkinneb said: Not much for pics the last few days but making progress none the less. Made a wood run needed some drawer material as well as a nice piece to use on the veneer of the tambour door. I decided the piece I was going to use wasn't doing it for me. Also after waaay too much fiddling I was able to get the right inner door installed and gapped. Just need to add the magnet catches to keep it closed. Oh and figure out what's going here and make the required mounts. Not sure what's next but probably machining the drawer and tambour door stock so it has time to release any tension I cause. Impeccable! 1 Quote
Popular Post pkinneb Posted October 2 Author Popular Post Report Posted October 2 Milled up the tambour and drawer front stock tonight. Hard to beat at sub $55 a blade ...HWW Woodslicer for the win. let those sit for a few days. Ultimately they will be milled down to 3/8" x 38" by 5" staves Also got the drawer front stock resawed since the saw was set up 6 Quote
Popular Post pkinneb Posted October 2 Author Popular Post Report Posted October 2 Back on the tambour track templet today not that proficient in Shaper studio but between YouTube video's and AI searches I was able to get close. First up wanted to mark out the cabinet shelf and top. I located the center lines on both panels since they are not the same width I will reference off centerline. With that done it was back to the computer to finalize the design This view shows what will be cut 99% correct but for some reason the track is 1/" narrower then desired and the location holes are both wrong one is obvious (should be 1/4" the other is they are too far away by an eighth inch. While this is taking longer than if I had just made a template the old fashioned way it is good experience with the Shaper so I will make the adjustments and retry tomorrow. 7 Quote
Ron Swanson Jr. Posted October 3 Report Posted October 3 On 10/2/2026 at 6:36 PM, pkinneb said: Back on the tambour track templet today not that proficient in Shaper studio but between YouTube video's and AI searches I was able to get close. First up wanted to mark out the cabinet shelf and top. I located the center lines on both panels since they are not the same width I will reference off centerline. With that done it was back to the computer to finalize the design This view shows what will be cut 99% correct but for some reason the track is 1/" narrower then desired and the location holes are both wrong one is obvious (should be 1/4" the other is they are too far away by an eighth inch. While this is taking longer than if I had just made a template the old fashioned way it is good experience with the Shaper so I will make the adjustments and retry tomorrow. I respect that you boldly forage into new realms like Shaper. I'm sure you'll get it buttoned up in no time. 2 Quote
Popular Post pkinneb Posted October 3 Author Popular Post Report Posted October 3 On 10/3/2026 at 8:44 AM, Ron Swanson Jr. said: I respect that you boldly forage into new realms like Shaper. I'm sure you'll get it buttoned up in no time. Thanks Ron! Well it took waaay to much time but other then the alignment pin holes (I finally drilled them at the drill press) the 3rd time was the charm. I learned a lot and ultimately it was only 1/4" MDF and my time so a relatively cheap lesson First up today I took a few more passes on the tambour door stock. Should be able to final mill them tomorrow or Monday. Then after cutting my third template I was ready to cut the tracks in the project. I did double check my collars to make sure they would slide all the way around their respective tracks. One had to be cut down a bit first, quick work with a hacksaw and file. . With that done I needed some 1/4" pin stock. All I had on hand was birds eye maple so I guess that will have to do Then I pulled out the double sided tape to mount the template Set the depth of the router And I was off... Just replicate that 3 more times...A couple minor mistakes on the top panel but nothing that will ever be seen. Then it was time to fit the inner wall panels ...and finally that part is complete! This glue up is going to be fun LOL. Houston we may have a problem!! looking at this on the computer I think those top dividers may need to be full width Here is a pic of one of the install ramps. These will allow me to slide the doors in after glue up. 6 Quote
Popular Post Ron Swanson Jr. Posted October 4 Popular Post Report Posted October 4 Wow, man, this thing is really something! Enjoying the ride so far!! are you heading to the expo this yar? 2 1 Quote
Popular Post pkinneb Posted October 5 Author Popular Post Report Posted October 5 On 10/4/2026 at 7:11 AM, Ron Swanson Jr. said: Wow, man, this thing is really something! Enjoying the ride so far!! are you heading to the expo this yar? Thanks! Yes I will be working the Windsor Chair SIG table, stop by and say hi. I'm Paul if I haven't mentioned it before. Todays progress started by final milling the tambour staves. I am trying to mimic the outer door panels a bit by going darker wood on the tambour doors and lighter on the drawer fronts. Outer door for reference I also want straight grain so I cut with the grain at the BS before milling the strips Then they were cut to length With that done I started playing with the layout and an NFL game later I was satisfied with everything except the top drawer panels, to the left and right of the tambour doors. I just wasn't happy with anything I found. So I glued up a panel that I think will provide something I can live with Here is what is likely the final for the doors and lower drawer fronts I probably spend way more time then I should picking wood but I hope the end product will make it worth it. 3 Quote
Ron Swanson Jr. Posted October 5 Report Posted October 5 @pkinneb Sounds good, sir! I look forward to meeting you in person. I'll (Doug) be at the Box Maker's SIG , and also doing a hand tool demo at the main bench f 12-1:30ish. I'll track you down! 1 Quote
Popular Post pkinneb Posted October 6 Author Popular Post Report Posted October 6 First up today I got the top left and Right drawer fronts milled to rough size Then I made a small jig for planing the front left and right edges on the tambour staves ...and then I got after it...only about 60 to do on two edges. Does make a big difference, those on the right are done Just a few more to go all done With that done it was time to add finish to three sides in preparation for gluing the canvas on. Two coats of shellac is what I went with. Next up cutting and gluing the canvas to the staves 5 Quote
Popular Post Mark J Posted October 6 Popular Post Report Posted October 6 Just curious if you numbered the backs of those staves, in case you sneeze or something . 2 2 Quote
Chet Posted October 6 Report Posted October 6 On 10/4/2026 at 6:00 PM, pkinneb said: I probably spend way more time then I should picking wood That is one of my favorite part of a project. 2 Quote
Popular Post pkinneb Posted October 6 Author Popular Post Report Posted October 6 On 10/6/2026 at 8:18 AM, Mark J said: Just curious if you numbered the backs of those staves, in case you sneeze or something . No but if I was doing a grain match I would have. I did run a line down the top edge so as I removed them I knew which sides to chamfer. I do have to flip them on there faces, for gluing the canvas on, which I have a bit of anxiety about but will just go slow and make sure the line is all on the same side. At this point I suspect I have about 6 hrs into these staves 3 Quote
Popular Post Tom King Posted October 6 Popular Post Report Posted October 6 We have my Grandfather's rolltop desk in our office. The tambour door still works great and it gets used a lot of days during a year. I wonder what kind of glue they used 126 years ago. I don't think it ever has not worked. 4 Quote
pkinneb Posted October 7 Author Report Posted October 7 On 10/6/2026 at 2:04 PM, Tom King said: We have my Grandfather's rolltop desk in our office. The tambour door still works great and it gets used a lot of days during a year. I wonder what kind of glue they used 126 years ago. I don't think it ever has not worked. That's awesome! I suspect it was hide glue. 1 Quote
Popular Post pkinneb Posted October 7 Author Popular Post Report Posted October 7 Not much of an update today, went out to the shop only to realize while I thought I had canvas it was actually muslin which will not work. I have ordered 10 oz canvas via Amazon so should be able to glue it up tomorrow. 5 Quote
Popular Post Botch Posted October 7 Popular Post Report Posted October 7 Really smart civilian in my Group built a tambour desk back in the '80's, and he used a combination of router bits that allowed the staves themselves to interlock, and bend just enough to work. It did operate smoothly, but I never got a chance to see how he cut them. 4 Quote
Popular Post Beechwood Chip Posted October 7 Popular Post Report Posted October 7 On 10/6/2026 at 10:04 PM, Botch said: Really smart civilian in my Group built a tambour desk back in the '80's, and he used a combination of router bits that allowed the staves themselves to interlock, and bend just enough to work. It did operate smoothly, but I never got a chance to see how he cut them. I found a bunch of cool options by searching for "tambour router bit sets". 5 Quote
Popular Post Mark J Posted October 7 Popular Post Report Posted October 7 10 hours ago, Beechwood Chip said: I found a bunch of cool options by searching for "tambour router bit sets". The Amana set is pretty slick. This site has a short video on how it's done. https://www.woodline.com/products/tambour-door-set?variant=17523096455&country=US¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gad_campaignid=23593442768&gbraid=0AAAAADK-IDLUNtc01pM7wodj5D_pI5PHI&gclid=CjwKCAjw25fWBhAVEiwAMopNjp_LAoRliXKsaf7CzhpS3gOKSiJTNbQDx2Qunydu1fB9MLQmbCewGxoC3isQAvD_BwE 3 Quote
wtnhighlander Posted October 7 Report Posted October 7 David Piccuto on YT did a project with those. Worked well, but I recall the bend radius was not very tight. Flip side is, the bend worked in both directions. 2 Quote
Popular Post pkinneb Posted October 8 Author Popular Post Report Posted October 8 First task today was to clean up any shellac that found its way to the backs. Quick work with a card scraper Then it was time to flip them over and tighten them down for the canvas glue up. Note to self not to tight. @Mark J probably should have marked them huh...facepalm ...after getting them back in order I did draw a triangle on the back, just in case. Then I drew lines on to insure I did not get glue or canvas where the dado's will be cut on the panel(s) Next up I cut the canvas to size. These rotary cutters work awesome but careful they are sharp Next I spread the glue (titebond original) with a roller to insure an even coating Followed by attaching the cloth using my hand to spread it out tight and then I followed up with a veneer roller. After that I waited 30 min and then rolled it up for final drying to insure none of the staves were stuck together While I was waiting for that to dry I played around with what I am thinking for the drawer pulls I think I like it! I made the cove on the drawer front with the Pantorouter and a router bit but failed to get a pic. 6 Quote
Chet Posted October 8 Report Posted October 8 On 10/7/2026 at 7:16 PM, pkinneb said: Then I drew lines on to insure I did not get glue or canvas where the dado's will be cut on the panel(s) Does your measurement of the lines on the staves ensuring that no canvas can drag in the dado? 1 Quote
