On 1/17/2026 at 7:02 PM, Coop said:
Now that’s fancy and fine! What type of wood is the last pic?
Thanks! The bottom is Ash like the rest of the cabinet. The top is poplar for the lumber core till slab I need to make.
11 hours ago, pkinneb said:
The overall door may need to be mounted proud an 1/8" or so as the inner door may be too tight to the rasp handles. I will make that call once I can stand the door up on end. Com'n Mcfeely's I need my screws LOL. If I do need it to be proud I will bevel the outer edge all the way around and the hinge strip will be mounted flush. Whatever I  decide will be replicated on the other door as well.
(Maybe I don't understand correctly).  Looking at your picture, if the point of contact is the chisel shelf against the rasp handles. could you just relieve the front edge of the chisel shelf?  Or are the chisel handles striking the rasp handles?
So the inner door for the chisel's needs to be 1 1/2" wide all in (front to back) for them to fit /look correct. currently it appears I have about 1 9/16" space from the front of the door to the chisel handle which may be closer than I would like. If that's the case I will just install the door so it sits proud a 1/16 or an 1/8" and then bevel the edge back to the outer door. Not sure if that helps but when I get there I think it will make more sense...maybe :D
On 1/24/2026 at 4:19 PM, pkinneb said:
Not sure what will go behind that on the main door just yet.
A little unused space is a good thing; it fills up somehow.  You're at the fun part now, enjoy!
On 1/26/2026 at 8:07 AM, Mark J said:
Was making the lumber core done primarily for the learning?  Why not just use regular lumber?  I confess, I didn't know what lumber core was, until you made some.
Yes for the learning and also becuase I am using a wood hinge so wanted to be some solid material on the top edge. Due to movement you would not want to use solid wood for this piece but could have used BB plywood.
  • Who's Online   0 Members, 0 Anonymous, 36 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
