Popular Post pkinneb Posted October 23 Author Popular Post Report Posted October 23 Picked what I hope is the last lumber for the project... 4 Quote
Popular Post pkinneb Posted October 24 Author Popular Post Report Posted October 24 Remade the tills today...checked, double checked, and triple checked to insure they were in the right direction this time. Although out of order in this pic That took most of the afternoon but I did manage to get a panel glued up for the travisher holder Also received the 1/4" steel rod I need for the flip out mechanism on the tills. Not sure if I'll get out there tomorrow as I need to do leaves again and probably wash a couple cars for storage. Regardless next up will be finish the tills, the travisher rack, oh and finish the brace and bit holder. 5 Quote
Popular Post Ron Swanson Jr. Posted October 24 Popular Post Report Posted October 24 This thing is going to be spectacular when it's finished! 1 2 Quote
pkinneb Posted October 25 Author Report Posted October 25 On 10/24/2026 at 6:48 PM, Ron Swanson Jr. said: This thing is going to be spectacular when it's finished! Thanks! If Sunday works out you may be helping me hang it on the wall 1 Quote
Ron Swanson Jr. Posted October 26 Report Posted October 26 On 10/25/2026 at 6:33 PM, pkinneb said: Thanks! If Sunday works out you may be helping me hang it on the wall Sounds like a plan! My potential complication is not happening, so I will see you then! 1 Quote
Popular Post pkinneb Posted October 28 Author Popular Post Report Posted October 28 Started work on the tip out mechanism for the saw tills. First using one of the old tills I started laying out where they would sit/tilt/etc With that figured out I drilled the holes (using the originals just in case) Then I used a center finder to mark for drilling the plane till side Confident the plan was solid I moved on to the actual set. I still need to drill the holes for the marking gauges. Then I moved onto the stop, cutting an angle on the table saw and trimming until I had what I wanted. Then using a plane I added a round over to get rid of the sharp edge. That should work I should be able to finish this and the brace and bit holders tomorrow. Then start on the wooden hinge on the plane till later this week. Oh and I need to start replacing my florescent lights with LED bypass kits. The ballast went out on the light right in the middle of the shop I have 12 fixtures in total to change but hopefully I can get this one done and then continue on with the project. 5 Quote
Popular Post Von Posted October 28 Popular Post Report Posted October 28 Love the tip-out. This is going to be an amazing cabinet. 1 2 Quote
Popular Post pkinneb Posted October 29 Author Popular Post Report Posted October 29 On 10/28/2026 at 7:24 AM, Von said: Love the tip-out. This is going to be an amazing cabinet. Stole the idea from Rob Cosman. Thanks! Ok not much to show tonight but a lot done none the less... First up I remade the marking gauge till (3x for those counting ) as I forgot I wanted the Kerf X-10 to sit in it as well. With that done I did all the clean up and added slight edge bevels with a hand plane. I also used a sharp chisel to cut slight bevels on the blade sections of the tills to make it easier to put the saws in. I added thin neoprene washers to insure only one till flips down at a time. Paid $3 for 5 of them, then I walked by my 3D printer and did a facepalm LOL You may also notice I modified the saw tills so the tops of the tall saw handles were all at the the same height. This is a shout out to doing project journals. I kept seeing the pictures online and thinking it didn't look right...now I'm happy and this section is ready for finish and final installation. 4 Quote
Popular Post pkinneb Posted October 30 Author Popular Post Report Posted October 30 Started working on the wooden hinge for the plane till tonight. First up was layout, you want to insure the hinge pins (1/16" metal rod are well within the wood something like so... Then I dug out an old portable router set up I had for making wooden hinge business card boxes back when business cards were a thing. I made many over the years as gifts. Ran a quick test and after fiddling with the setup a couple times got it dialed in. the exposed portion on the bottom gets planed flat to the panel. Here is the special centering bit I used to drill for the rod that will be placed as the hinge If you look close you can see the 1/16" bit Time to run the real thing Not perfect but certainly acceptable. The large panel was a little hard to hold steady on a 2" tall fence. I also struggled to keep the waste vacuumed up. One thing I have been pondering for sometime was how on earth I would clamp this for glue up and I think I will just go with blue tape (more than what's here) as it held fine and really only needs to do that for about 20 min. My 1/16" rods won't arrive until Saturday so on to something else tomorrow. 5 Quote
Popular Post pkinneb Posted October 30 Author Popular Post Report Posted October 30 Not a lot of progress today but did get what should be the final milling for the project done. Drawer parts, plane till partitions, I decided the 1/4" thick ones were to thin so going to 3/8, and the core material for the upper inside doors. Oh and I started cleaning up as I have a visitor coming Sunday, so the waste bin has been emptied... 3 Quote
Popular Post gee-dub Posted October 31 Popular Post Report Posted October 31 I had to smile at the fire pit pic. We are having a get together Sunday and I will be able to get rid of a trashcan full of scraps. People wonder where I get all the firewood. I just tell them to look at the furniture in the house . . . anything that doesn't look like one of those pieces goes here. Its like the old joke about "how do you carve an elephant?". Grab a piece of granite and chip away anything that doesn't look like an elephant. 5 Quote
Popular Post pkinneb Posted November 1 Author Popular Post Report Posted November 1 First up today was to prep and finish the parts I will not be able to get at once the cabinet is hung Plane till supports Then I needed to remove a screw I snapped off, earlier this year, on one of the door hinges Using a small drill bit I was able to drill a hole inside the broken off screw Then I screwed another screw into the hole I drilled in the snapped off one ...and walla It worked and I was able to get it removed. With the old screw out I needed to fill the hole so I could drill for the new one. I chucked a blank in the drill and went to the edge sander to make a quick dowel Then I glued it in and cut it off with a flush cut saw With that done I moved onto the tambour door pulls After picking some stock I laid out where I would remove stock and then mounted on them on my dovetail backer to cut out with a router I needed more light so... ... worked great just need to clean them up with a chisel Then I started working on the pulls, dialing the fit in with a hand plane Now to shape them, I didn't like the first curves, just on the corners (see above) so I went more half moon Then I cut the other and clamped them in a vised to insure they matched, I finished off the curve with a small spokeshave I like it... Then it was time to mount the saw tills, I laid them out using squares and tape Then the left plane till support Installed the brace and bit holder Installed the drawer case ...and last up today I finished the bottom brace and bit holder You can also see I installed the saw till tip out stop somewhere along the line. 7 Quote
Popular Post pkinneb Posted November 1 Author Popular Post Report Posted November 1 Received my 1/16" metal rods so I can move forward on with the wooden hinge. Then with the help of fellow forum member @Ron Swanson Jr. I was able to get the cabinet hung. No pics because we were focused on the task at hand. We started out by finding the studs, leveling and hanging the French cleat using structural screws, and then hung the cabinet using additional structural screws. Then we re hung the doors, we had removed them and the drawer box to make the task easier which it was very straight forward with the help. After Doug left I finished installing the remaining hinge screws... Then put things back in there place...I haven't seen this corner of the shop in many months 7 Quote
Popular Post pkinneb Posted November 3 Author Popular Post Report Posted November 3 Tired today so just worked on some easy tasks... Made a holder for my mallet Then determined the final layout for the right outer door ...and started working on tool holders 4 down many to go 8 Quote
Popular Post pkinneb Posted November 4 Author Popular Post Report Posted November 4 4 more tool holders complete... ...oh and made some changes to the final layout Hammer and roller out. I added my 45 angle square and gave myself more room for the knife block so I have more room to grab what I need. It also cleans this section up as my layout door. 5 Quote
Ron Swanson Jr. Posted November 4 Report Posted November 4 Are those marking gauges in the first picture and in the top right of the door? Quote
pkinneb Posted November 4 Author Report Posted November 4 On 11/4/2026 at 7:18 AM, Ron Swanson Jr. said: Are those marking gauges in the first picture and in the top right of the door? Yes Hamilton Marking gauges 1 Quote
Ron Swanson Jr. Posted November 4 Report Posted November 4 6 minutes ago, pkinneb said: Yes Hamilton Marking gauges I will have to check them out! Quote
pkinneb Posted November 4 Author Report Posted November 4 I really like the smaller one I don't use the larger one as much. I have two Rob Cosman wheel type I use for dovetails and use the smaller Hamilton for pretty much everything else. At the very least they are beautiful tools to look at, when I got these I started changing my chisel handles to Cocobolo I just really like the way it looks. 2 Quote
Ron Swanson Jr. Posted November 4 Report Posted November 4 23 minutes ago, pkinneb said: I really like the smaller one I don't use the larger one as much. I have two Rob Cosman wheel type I use for dovetails and use the smaller Hamilton for pretty much everything else. At the very least they are beautiful tools to look at, when I got these I started changing my chisel handles to Cocobolo I just really like the way it looks. Is that a knife, pin, or a wheel cutter on those? I've recently subscribed to the blog of a furniture maker named Matt Kenney who swears by a knife cutter over a wheel for a marking gauge. Personally, I'm having trouble seeing where it would make that big a difference. They're both single bevel blades and I've always gotten a nice, crisp scribe line with my wheel cutter gauge. So maybe it's just his preference and nothing more. But i don't really know what I'm missing, either. 1 Quote
Von Posted November 4 Report Posted November 4 19 minutes ago, Ron Swanson Jr. said: But i don't really know what I'm missing, either. 19 minutes ago, Ron Swanson Jr. said: Personally, I'm having trouble seeing where it would make that big a difference. They're both single bevel blades and I've always gotten a nice, crisp scribe line with my wheel cutter gauge. So maybe it's just his preference and nothing more. I'm out of my expertise but I've heard there are advantages depending on if you are marking with or across the grain. 1 Quote
Ron Swanson Jr. Posted November 4 Report Posted November 4 56 minutes ago, Von said: I'm out of my expertise but I've heard there are advantages depending on if you are marking with or across the grain. A pin style definitely seems to work better on end grain. You may be onto something, though, maybe the knife works better with the grain. If the grain runs towards the gauge's fence,I have to be careful or the cutter will follow it and there goes my scribe. Maybe a knife is better there. 1 Quote
Chet Posted November 4 Report Posted November 4 Paul, I am curious, in your minds eye do you see the doors on the cabinet being open most of the time or closed. 1 Quote
Popular Post pkinneb Posted November 4 Author Popular Post Report Posted November 4 On 11/4/2026 at 9:56 AM, Ron Swanson Jr. said: Is that a knife, pin, or a wheel cutter on those? I've recently subscribed to the blog of a furniture maker named Matt Kenney who swears by a knife cutter over a wheel for a marking gauge. Personally, I'm having trouble seeing where it would make that big a difference. They're both single bevel blades and I've always gotten a nice, crisp scribe line with my wheel cutter gauge. So maybe it's just his preference and nothing more. But i don't really know what I'm missing, either. Knife type. If you ever want to try before you buy just let me know On 11/4/2026 at 11:25 AM, Chet said: Paul, I am curious, in your minds eye do you see the doors on the cabinet being open most of the time or closed. Due to humidity I will keep them closed with some desiccant packets in the cabinet to keep things rust free. Having said that you will not see additional pics with them closed until I'm done and have added finish...they are going to pop 6 Quote
