Over-sized (5/16", 7/16", 9/16", etc) forstner bit sets?
A while ago HValley Tools sold a set of forstner bits that was 1/16" larger than the standard sizes (5/16, 7/16, etc.) Looks like they don't any more. Anyone know of a place selling such a set? TIA
I don't, but if you just need a custom-sized hole on rare occassions, it is pretty easy to file an oversize spade bit down to what you need. For drill press use, you can even reduce the lead point to no more than a forstner has.
How odd.  I have a large set of HSS Forstners from Lee valley but they no longer list them(???).  Sign of the times maybe.  I went browsing around and also found them hard to find.  I think I have some spares in HCS.  I will PM you later today
Hi all, thank you for the suggestions. A hopefully helpful bit of context: I have a set of "normal sized" forstner bits already. This is the second time in the last few months I've run into the need for a +1/16" size. The last time it was installing 5/16" diameter magnets and this time it's a 13/16" diameter bit for making a holder for the set of chisels I'm cleaning up (if I use 3/4" it will be too tight for the ferrules).
I know one can buy individual +1/16" bits, e.g. Woodcraft sells them, which is where I got the 5/16" bit, but I figured since I've run into the need for two now, I can justify buying a set, hopefully "saving a few bucks in the long run" and also hopefully giving me a box to store them in. I almost bought the fill set from HValley when I bought the 5/16" bit and am now wishing I had. Since I won't be reaching for these frequently, having them in a box on a shelf is the appropriate storage mechanism for me. I also don't really want to buy a complete set of bits at 1/16" increment and have a bunch of duplicates.
If I fail to find a set, I'll just keep buying them individually from Woodcraft or elsewhere (or maybe buy the set of individuals and build a way to store them, like I need another shop project).
Thanks again.
I have a couple of sets from Lee Valley that go from 1/4" - 4". They are excellent and made of HSS. But Festool must have twisted some arms because now the only Forstners they sell are 5 piece set from Festool for a rather stratospheric sum.
Found one on clearance at Grizzly! It's a bigger set than I wanted but for $80 I'll take it.
https://www.grizzly.com/products/grizzly-15-pc.-carbide-forstner-bit-filler-set/h5862
Edited to add: I noticed from one of the reviews, if you look closely the three smallest bits (5/16", 7/16", and 9/16") are not true forstner bits, but something else (quoting the reviewer: "At best, I would describe them as the carbide tipped byblow of an unholy union between spade bits and brad point bits." I had to google "byblow", it's an archaic term for an illegitimate child.) I'm OK with this since I already have one of the three and I'll probably do what the reviewer did and replace them
On 9/10/2025 at 2:03 PM, Dave H said:
5/16"  I have a set of brad point bits that have that size perhaps that would be a cheaper option to pursue.
I prefer a forstner bit when I want a precisely located, clean-edged, (mostly) flat bottom hole. I'm not saying there are aren't other ways to do it, but a forstner bit is my preference.
1 hour ago, Mark J said:
According to the description they are "carbide coated".  Are they true carbide bits?
Not for $80 I don't imagine. Sounds like marketing wankery
Hmm. I'm not sure what "carbide coated" looks like or how I would tell. I welcome non-destructive suggestions as to how to tell.
 I'd say to rub an inconspicuous spot of one bit on a sharpening stone and see if it makes a mark. But Carbide Coated makes me think it might just be the actual cutting surfaces. So maybe that's not the best test.
On 9/14/2025 at 2:40 PM, Mark J said:
If it is truly a carbide Forstner it will have carbide teeth/cutters brazed onto the bit's steel body.  Think carbide teeth on a circular saw blade.
There is no brazed-on carbide visible.
On 9/14/2025 at 3:28 PM, wtnhighlander said:
Maybe it is a vapor-deposited film, like the titanium- or cobalt-coated twist drills have?
According to Google AI: "To identify if something is carbide-coated, look for its dark gray metallic luster and check its relatively low density and slight magnetic pull, which distinguishes it from high-speed steel (HSS). A magnet will weakly stick to carbide but strongly to ferrous metals, while carbide is significantly heavier than HSS and resistant to scratching. For a definitive identification, especially if the item is suspected to be carbide itself rather than a coating, you could use a hardness tester or a Scanning Electron Microscope (SEM) for composition analysis."
I'm not sure that is totally coherent, but I'll take a closer look in the morning and see if I can distinguish a coating.
I got curious and wandered out to the shop... with a poor excuse for a hardness test, all I can tell you is the heads are tougher than the shafts. I can easily scratch the shafts with an awl, but the heads are more resistant. They could be hardened or there could be a coating.
Visual inspection, there could be a coating as the bits look a duller than I would expect. They are kinda a graphite grey
Are those hex shanks in your Forstner bits 1/4" like those on screwdriver bits? So you can use a standard extension if needed? My PC set has rounded shafts and I had to switch to spade bits a couple of times because of the required depth of cut. It would've been nice to just use a screwdriver extension for the forstner bit.
Yes, hex. I do have drill bit extender that works on round shanks, so they do exist as well.
  • Thanks 1
Thanks. I also have one of those bit extenders with 2 set screws, but my forstner bits do not fit in it.
  • Who's Online   4 Members, 0 Anonymous, 45 Guests (See full list)
    32k
    437.5k
    Bob44
    Bob44
