I have had these saws
http://www.leevalley.com/US/Wood/page.aspx?p=66066&cat=1,42884,68511&ap=1
for awhile and haven't used them too much. First of all are they any good? My hand saw skills need a lot of work, I'm just wondering if these saws are hindering me, don't want to blame the tool though.
Secondly anybody have any good resources on improving hand saw skills, tips, videos, articles, books, etc.? Thanks
Don't take this the wrong way, but it's not your saws. The good news, I guess, is that you have some really nice saws. ;)
The other piece of good news is that if you have scrap wood, you can make your sawing better by practicing. Just mark off a lot of lines on a piece of wood with a square, and start sawing to the lines.
The most common mistake is trying to force the saw through the cut. Just move the saw back and forth, without trying to advance it, and you'll find yourself sawing straighter with less effort.
How about a hand tool lesson from a local craftsman? I took a few on hand tool use, and they were worth every penny. I learned about body positioning, speed, how to start and finish, etc.
+1 Franklin, it might be intimidating to seek out a local craftsperson but I bet most would enjoy passing on some knowledge.
Saws are great by the way. A very unique look to them which I like, and performance is reportedly very good too. Would happily have them in my tool chest.
This is a fun get to know your saws video
OK, so I just made about 20 cuts down a pine board, both rip and crosscut. On every single one of them I drifted to the right (I'm left handed) What is the problem, stance, technique, etc.? Any thoughts, thanks.
Loosen your grip on the saw. Chris Schwarz says to hold a saw with the pressure you would hold a baby bird with.
With those saws the only negative is that they don't have as much weight as a brass backed saw. I used some of the lie-nielsen saws at their hand tool event and those felt great to me.
Don't know if you do this but extending your index finger and using a "3 finger" grip will help too.  Make sure your body is positioned to the right of the saw, and your arm can swing forward and backward with ease (not hitting your side).
WJ, usually this is a stance issue and like stated above you want your sawing arm to be able to swing freely.  Step forward with your right leg and take a nice, stable stance.  Your shoulders will not be square to the work.  If you are driftng to the right you are probably pulling too far out of the way.  Try to position so that your elbow grazes your side with each stroke.  The best way to diagnose an issue is to film yourself sawing.  get a 30 sec clip from the front and one in profile.  Pay attention to your elbow.  Any movement there will telegraph to the saw plate many times over.  Finally the best thing you can do is relax and let the saw do the work.  Forcing it to cut or trying to saw will cause more problems.  In other words do what everyone has said above :) Relax and saw, a tuned saw wants to cut straight.
As always, great suggestions from the others. Like many things in life, practice makes perfect. Use the suggestions and keep trying until it becomes second nature and the cut runs true.
Like Wilbur said, block some time when you are in the shop to practice your saw cuts. Some do the "(cut a) dovetail (joint) a day" practice. Even if you pick up a piece of scrap wood, make marks across it with your combo square (in 1/2" to 1" increments) and practice sawing to the line, it will help. After you finish this type of cut, pick up your combo square and see how you did - checking the sawn edge to see if your saw cut left a straight edge, not angled in or out. In time you will get the hang of it.
The Veritas carcass and dovetail saws are a great value for the money. You will really appreciate them when your technique comes together.
Great video GS!  Thanks for your contributions!
If it's not your stance, saw drifting to one side or the other can be caused by the teeth being set more on one side than the other.  It will dirft towards the side with too much set.  Fix is to gently stone the side of the teeth on the side it's moving towards.  Careful it's real easy to over do DAMHIKT.
