I have a dirty Circular saw blade... Figures right, i never really use the circular saw in the shop its more for cutting chucks up for the firepit... But the blade is dirty (I think) it started getting stuck in the wood outside and just spinning... I figure its all the pitch and crap on the blade giving me an issue...
Whats everyone use to clean your blades,  I dont really want to have to order something online since i actually need the saw in the shop for a project that i do not wanna put on hold.... Anything good around the house or the local hardware store??
Thanks
Dave Turner
Oven cleaner will do in a pinch. Wear rubber gloves, spray it on both sides let it work a few minutes, scrub off the resin build up with a stiff plastic bristle brush. Rinse well. Dry off thoroughly . Make sure the face and edges of your teeth are clean, repeat if needed.
I use an abrasive pad on the stubborn deposits on the body of the blade. Be careful around the teeth wipe parallel to the cutting edge, you can slice a finger open on a sharp blade. I clean my blades and router bits almost every time I change them. There is less build up so it is easier to do and the blades stay sharper longer.
Lately I have been using the blade cleaner sold by CMT, it has an orange and black label . Do not leave oven cleaner on the blade too long, it is pretty strong .
409, Fantastic, Goo Gone, Dawn/water, Greased Lightning, LA's Totally Awesome....most household degreasers will work well....spray, hit it with a stiff nylon or brass brush, rinse, wipe...done in 3-4 minutes.  If it's really bad, Freud suggests a soak in kerosene b/c it's pH neutral, neither acidic or basic like oven cleaner.
I'm just to lazy... I stopped cleaning my blades years ago... About the time they get that dirty they need to be sharpened anyway... I just send them to Forrest... However, this last shipment from their sharpening service included a sample of their purpose-made blade cleaner...  Perhaps they were sending me a hint...   :)
I use Home Depot orange degreaser and a toothbrush, works very fast. Picked up a teflon pizza pan from the dollar store, lay the blade down, spritz, wait a minute and scrub it clean. I'm done within 2 minutes. The downside is it will remove paint if you let it soak.
edit; @HHH, you might be surprised. They may seem dull but a good cleaning will make them cut like freshly sharpened blades.
==> @HHH, you might be surprised. They may seem dull but a good cleaning will make them cut like freshly sharpened blades.
Yea, I know better... But I'm such a lazy sod...  I tend to bin things like sharpening, blade cleaning, etc for the times when I've got a shop helper available...  I'll let my helper demo the Forrest product and let folks know how it works...  From sniffing the bottle, I can tell it's not caustic like oven cleaner, Xylene or other solvent-based pitch remover... Suspect it's something like Simple Green...
Gum buildup also causes excess heat, which is a good catalyst for breaking down carbide.....simply put, they dull faster if you don't clean them.
==> Gum buildup also causes excess heat, which is a good catalyst for breaking down carbide.....simply put, they dull faster if you don't clean them.
OK.. OK.. I give up... I'll clean some blades... Promise...
You know, I never said that I don't believe in cleaning blades or it's not a good idea... All I said is that I'm too darn lazy to do it myself... :)
There are lot's of things that I don't do that are a good idea and lot's of things that I do that are not a good idea... That second helping of turkey last night would be a good example :)
Anyone tried running them through the dishwasher? Seems like that would soften up most of the gunk, and you could brush the rest away after the rinse. Just need to take it out and dry it as soon as the cycle completes to avoid rust.
Decent circ saw blades are fairly inexpensive.  I don't see the value added in going out to buy a cleaner for a blade in this condition when the same trip could be made to just buy a new blade.
  • 3 weeks later...
==> Yea, I know better... But I'm such a lazy sod...
==> OK.. OK.. I give up... I'll clean some blades... Promise...
I really don't clean TS blades... When I have a helper in, he cleans the blades... :)
Decided to see if cleaning makes any real $$ difference -- yea, I know it makes a difference (qualitative), but wanted to find out how much (quantitative) of a difference it makes...
I'm a numbers guy (the latent Engineer in me)... So I decided to run an experiment... Now, it's a bit uncontrolled and n=1, but none the less, directional...
I usually send a blade for sharpening when I get the first signs of burning. Forrest cleans, repairs, sharpens, etc the blade and sends it back -- easy... Remember, I'm a lazy sod... :)
Since I had a fairly large project on-deck, decided it was time to experiment... I ripped stock as usual (4/4 Hard Maple). When I got to the point of slight burning, I cleaned the blade instead of sending it to Forrest... I then put the blade back in service and kept [loose] track of how many linear feet of ripping I could accomplish until burning re-appeared... OK, it's not that scientific, but it's something...  I got about 200lf more ripping done before burning re-appeared... Re-cleaned the blade and continued, but only got about 60lf... Time to send to Forrest... To see if it makes a $$ difference, I'd have to figure-out how many linear feet I get between sharpenings -- but that's an experiment for another day..
The long and short of if it: Yea, cleaning a blade does extend it's life (we knew that)... I got about 200-300lf additional from a given sharpening -- that's about 50 rips in rough stock -- so it's not insubstantial... Exactly how much of a $$ savings? Another experiment awaits...
I tried the traditional caustic Pitch&Gum remover and the proprietary Forrest product (see above). The traditional stuff worked better -- no question. However, you've got to use that stuff outdoors -- it's basically oven cleaner. While the Forrest stuff was non-caustic and you could use it indoors... The traditional product took five minutes, the Forrest product took about fifteen...
Anyway, for what it's worth...
==> Extreme Simple Green
I strongly suspect the Forrest proprietary cleaner is a simple green look-alike (EGBE-based), just pre-diluted and put in a pump-bottle. There's no contents on the bottle... Most of the 'newer' blade cleaners are going to be EGBE or ETA-based products... Getting bulk Simple Green is probably the cheapest way to go... However, it does take more time/effort to get the blade clean...
==> oven cleaner v carbide
The caustic soda-based cleaners are the 'traditional' approach... Base doesn't really react with the carbide, per say... But does react with the brazing -- over time... over a great deal of time (maybe if you soaked your blade for a few weeks)*... That being said, caustic-based products kill PTFE, paint, coatings, etc... So if you've got a fancy painted/coated blade (CMT, Tenryu, et al), the pretty paint job is going in the first couple of minutes... Newer oven cleaners are ETA-based (you can thank California for that) and should not impact the brazing, paint job or coatings... And, more importantly, maybe cheaper for the hobbyist who doesn't need to clean blades all that often, but does clean their oven every few months...
*Urban-myth, but a part is real... Really in-expensive blades have thin carbide and not much brazing... I could see Lye-based products impacting cheap blades... But if you've got a decent blade with thick carbide and plenty of surface area for brazing, no worries...
Purple power. Hell I'd use anything we have laying around, certainly wouldn't buy a purpose made cleaner. 9 times out of ten my blades are dull before they get cleaned, the draw backs of prefinished plywood. Ammonia based cleaners work well, letting the dog pee on it should work fine.
After trying I think every Internet favorite, I settled on the purpose-made CMT stuff...
I don't make cleaning a specific task.   Like sharpening, I worked "touch-ups" into the flow.  I keep a 5 gallon lid and toothbrush handy.  When my general use blade comes off, it goes on the lid, gets a light spritz of cleaner, and I go back to work.
When I'm done with the special blade, I zip the brush around the teeth that have been sitting on the cleaning lid, flip it over, give it another zip with the brush, wipe it with a paper towel, give it a light spritz of Dri or TopCote, Blade Saver, or whatever else is nearby, and put it back on the saw.   The special blade goes on the lid and gets the same treatment, but goes back into the blade file.  This method only adds a few seconds to blade changes, and I seem to change blades often enough that they stay clean enough.
I never need abrasive brushes or much more than a single pass of the toothbrush and paper towels to get the blade plenty clean.   I don't think the WhateverIsHandyCote spritz does much for the cut past a few cuts, but it protects exposed metal from rusting in my three-quarter's underground shop.  I've had spotlessly cleaned blades and bits develop rust on the shank or the arbor area due to the water in many cleaners and a damp location.  The handy kit also includes a cropped flux brush, prescription bottle with cap, and a microwave meal dish for router bits, which get the same treatment.
The process of "try 'em all" helped me discover washing soda, which is GREAT for de-stinking gross cycling and hockey clothing, when I forget to remove a load of damp towels from the washer, and in the self-clean cycle of my high-efficiency washing machine!
==> letting the dog pee on it should work fine.
Well, that's one method... Of course, if that fails, you could go into the match business... :)
The stuff Forrest sent me works OK, but slow... I don't think they actually sell the stuff -- It come in a squirt bottle sans directions/instructions/contents/safety or much else... Just marked, "Blade Cleaner"... I think it was sent to me as subtle commentary on my blade cleaning (or complete lack of)...
  • Who's Online   1 Member, 0 Anonymous, 51 Guests (See full list)
