hot morning coffee,
I did drip coffee for years and even got into a french press.  Once my wife bought a keurig k2, the simple operation and convenience won me over pretty quickly. I throw a kcup in on my way to the head,  take a leak and by the time in back in the kitchen,  coffee is ready. I love it.
  • Replies 59
  • Views 10k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • good morning all, sitting here reading posts and drinking my morning coffee before I head off to work, Just wanted to tell ever one to have a nice day and enjoy.
  • Okay I am pretty sure non of you want to hear from me.  I am drinking coffee at the moment but now the bad.  I am in California, retired and the temps here have been in the 70's for about two week but
  • shaneymack
    shaneymack
    I roast my own coffee here at home. I buy 20lbs of green coffee beans at a time from a place in Toronto called green beanery. My go to bean for the last few years is ethiopian yirgacheffe. I definite
Posted Images
3 hours ago, Chestnut said:
I'm asking everyone. I've been trying new coffees, what limited i have in the area, and i keep coming back to the one. Doesn't all coffee have a generally unpleasant after taste?
It sure does. This is worse though. At least to me.
I used to grind my own beans, but now that I get up at 4:30 to go to work it's just easier to buy the preground ones and set the timer. I did grind them the night before for a couple of years but I just can't notice a difference in flavor.
That's also why I don't use a french press anymore. Tastes same to me.
It's worth noting that I do not like bitter drinks. I love sweetener in it and a ton of creamer. I am not a purist by any means, though for years I did follow the Alton Brown methodology with making my coffee. It was great, it just was too much work/time consuming for my current situation.
Just like breweries supposedly put the worst beer in cans and the best in kegs i bet the coffee companies put the worst beans in the k-cups and the best in whole bean packages?
I drink too much dang coffee for k-cups to make sense. I'd be drinking down $3 a day just in coffee.
21 minutes ago, Mike. said:
man that is like the pocket hole jig of coffee.
I just never got into coffee snobbery. I add equal and Hazlenut creamer to it anyway so its less coffee, more creamer.  Coffee connoisseurs clearly would never do it but that ain't me.
I am straight up Dark Roast with nothing added, I like it full strength.  One of the best beans I have found I get at Costco.  It San Francisco French Roast.  Simple and inexpensive.
your all killing me, simple rule, fresh ground beans, fresh roasted if possible, beans should not be dry looking but have a oil shine, water temp is critical 200deg, and the water it's self bad tasting water makes bad coffee, I have a 4 stage water filter system on my sink, good bottle water of filter water, I have several places local that will roast beans to my taste, also what kind of roast and type of bean can make all the difference, most package ground coffee has chicory to reduce the bitterness, cheap coffee is not always the best, neither is the most expensive found in your local food stores, if your going for a good all around coffee 8oclock whole bean, sounds weird but they are tried and true coffee bean been around for ages and makes a good cup, K cups, and flavor coffee well it's like making a table out of tiger maple and painting white, just covers up the good stuff,
I'm with you man. It's a caffeine delivery system and you gotta hide the taste with creamer.
I don't care for dark roast. Both flavor-wise and cause it has less caffeine.
I roast my own coffee here at home. I buy 20lbs of green coffee beans at a time from a place in Toronto called green beanery. My go to bean for the last few years is ethiopian yirgacheffe. I definitely do not roast to the point of having an oily bean. That is the sign of 1 of 2 things. 1- the bean was roasted way too long and the oils have come out of the bean or 2- the bean is pretty old. When roasting a bean that long you lose all the taste of origin and just end up with the typical burnt/bitter coffee flavour that most people are used to.
I have a jura espresso machine made in Switzerland which is bulletproof, love it! It is a superautomatic so clearly I'm not a coffee snob because a coffee snob would never use a superautomatic. The only coffee i drink is some derivitive of espresso. Most days i have 2 long americanos with a dab of 35% cream. If i have espresso it's black. When we have people over i normally end up making lattes or ccappuccinos.
My biggest concern with k cups is the waste.  I was tossing 6 per day, so I went back to a percolator.  Now I compost  rines and filters - no garbage.
How do you roast?
get my coffee from milwaukee, a small coffee shop called anodyne coffee roasters, atomic blend is my favorite, grind the beans myself and run them thru a pour over called a chemex. makes a great cup o joe with no bitterness. as a side note i also get my bacon from milwaukee, a very old shop called Usinigers. once you have their applewood smoked bacon it will spoil you to anything else
never got into roasting my own, I usually get an Italian roast, or french, my beans are a mixed of several types to produce the flavor I enjoy, don't ask I won't tell, kinda like asking a angler where is their secret hole is. I would say most on here get the standard grind and roast, found on the shelf, I may just try roasting my own some day when I get tired of my blend at the bean shop,
How do you roast?
With a behmor 1600. It's a pretty basic beginner roaster. I've probably roasted over 300lbs of coffee in it since ive had it with no issues. Once you roast your own beans there is no turning back. Imo the three biggest keys to amazing coffee more than the kind of coffee are:
1- Being freshly roasted. Preferably drinking 24-36 hrs after roasting to two weeks after roasting.
2- length of time it was roasted. I hate beans that have been roasted too long which is pretty much most beans available at the grocery stores. I normally start cooling just after second crack starts, depending on the bean of course
3- Grinding beans right before brewing.
Having the the roaster makes is easy to ensure the quality of my coffee and the first two criteria on my list are consistently met. Its not super difficult to learn the basics and figure it out as you go.
I encourage you to try roasting its lots of fun ! I never get sick of roasting.
that's a serious addiction you have there shane, i like it! if you're going to do something, do it right, shows in your woodworking also
I buy roasted yirgacheffe from a local roaster here in chicago.  it is a medium roast and usually i buy ot the week it is roasted.  great for espresso.  actually has a fruity flavor.  http://bowtruss.com/
Thats awesome Mike. I keep thinking of trying a blend with it but it's so good on it's own i haven't tried. Ive tried quite a few beans from the green beanery and this one is by far my favourite.
This whole thread makes me very glad that I've never had a single sip of coffee my whole life...  It all sounds way too complicated.
I hate coffee, always have preferred tea. I read the entire thread anyway, was hoping for some kind of revelation about how it would help me with woodworking :(
Man, coffee is one of life's small pleasures!  It's worth the effort to get it right.
I sure don't do anything as fancy as you guys do.
I only drink coffee from 6 AM until noon and then I switch to water.....  Until beer thirty which ends at about 9 PM.
On 3/5/2016 at 7:36 PM, shaneymack said:
How do you roast?
let me think, another hobby, let me pass that by my wife and see how that flies. I do so like being in my shop but no room to put a bed. lol
Just got back from Jamaica. The Blue Mountain coffee from there is great. I'm not a coffee junkie but the coffee from down there is way better than anything I've had from the super market.
it's all in the water, you can have the best coffee maker in the world, and the most expensive beans, but if your water has a bad taste your coffee will never taste good, most city waters have way too many chemicals, well water is fine but may hold too many minerals which can mess up any coffee maker as bad as city water, Filter water will take most of the bad stuff out. spring water makes some outstanding coffee, but like well water got to keep an eye on mineral build up, like any good beer, whiskey, or wine   it all falls back to the main ingredient water,
Sounds like a good job for a berkey!
I agree. I can taste it right away if someone made the coffee with city water full of their cocktail of chemicals.
You all are hating on city water so much it's hard for me to night fight back,
Chemicals in city water? To my knowledge the only chemicals that are added are fluoride (where applicable) and chloramine, the industry has been shifting away from chlorine. All other chemicals are present from where ever the treatment plant draws it's water from which oddly enough has tighter standards than bottled water in the US. Some bottled water is treated to a higher standard this is true but only in some cases. All the chemicals added during the treatment process are large molecules designed to latch onto smaller particles to make them larger and heavier to either settle out or become filtered out using gigantic activated carbon filters like the ones that you use at home except on a huge scale. Disinfection has also been shifting towards UV and ozone and away from high doses of chlorine or chloramine.
If you don't believe me go to the treatment plant and ask them they'd probably be more than helpful and i believe in the US are required to tell you what they are doing, if they aren't' the treatment plants i deal with have no intentions of hiding anything.
I'm not arguing about taste that's subjective, i can't really tell you want tastes good. Case and point i really enjoy ketchup and Oreos.
Right, and GMO's are going to save the world. i have pretty extreme views when it comes to health and the stuff i put in my body and especially my childrens. Let agree to disagree. You can go on enjoying your city water and I will enjoy my water. Lets talk about wood.....or coffee. :)
