First real project, sapele cabinet to house Bearded Dragon, WoW themed
11 hours ago, wdwerker said:
I hope it can be partially disassembled to run wires and cut holes. I learned that any project that envolves installation of devices or technology demands pre planing and test fitting long before anything gets glued up. I learned that plumbers and electricians can destroy a cabinet so I read all the appliance install spec's and cut accurate holes .
Agreed, nothing but the inner box and the top has any glue and I won't be gluing it up until we are finished with the inner box so we have all of the wiring and lighting located and I can adjust as needed.
  • Replies 84
  • Views 21.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I paused for a few weeks to get ready for, go on and recover from vacation but I have been getting back into the shop now. I was able to get the top glued up and prepped, the ends just need to be trim
  • CandorLush
    CandorLush
    The lighting was not good at all so I will get better pics later but delivered and installed! @Brendon_t It is running hot for now but it really isn't too bad so he is switching the bulbs out for som
  • CandorLush
    CandorLush
    Two applications of timbermate mahogany and now it is time for the danish oil! I would have preferred to do the ARS but he and his wife felt the TM + DO + lacquer looked the best with the rest of
Posted Images
Well poop, thank goodness for Amazon and one day shipping. The down side of going from 6/4 to 8/4.
You're not running that board between the bit and the fence are you?
:o
1 minute ago, CandorLush said:
Haha, no, picture purpose only
Cool..  In that case, glad you have the new bit coming ;)
what would happen if he did? is it just the size of the board and the smaller bit or what?
It would become a torpedo across the shop!
Either from it getting a catch during a climb cut or getting caught between the bit and the fence, it would be getting stuck in my drywall or my liver
  • 3 weeks later...
So I cut the first 8/4 leg and, proportionally, it looked awful. Picked up some more 6/4 and have all 4 legs remade to the new height. I am starting to lay out the joinery on the new legs after designating each new leg to the corresponding old leg.
I have come far enough that I might end up cutting new cross-members and rails so I can end up finishing both cabinets....
1700325577017363824%253Faccount_id%253D1
I'm a bit confused. if you shaped them from 8/4 and didn't like it, why go buy all new material to build new legame, who not send them ungrounded the planer on their side,  bam.. 6/4 legs already shaped
It was definitely a consideration but the quality of the cut from the router bit was really poor so I didn't feel like I could salvage that piece. As for the rest of the stock I had, I was left with either having a ~3/8" thick board or throwing away a 1/2" of wood in the dust bin.
It just seemed easier and now I can use the 8/4 to make the second set of rails to end up with two finished cabinets.
  • 1 month later...
Sorry, forgot to post the last few updates! I got the new legs finished, the top is cut to approximate size (after I took the picture)and I built the bottom doors.20161201_203439.jpg
This was my first time using veneer, I used titebond 3 and lots of clamps because that's what I have on hand. The "wet" pic is with some odorless mineral spirits wiped on. 20161216_192534.jpg
Here are the lower doors in the test fit
Did some finish samples and dropped them off with my friends to pick which they want. Danish oil and shellac, danish oil and lacquer, arm r seal, and endurovar, left to right.
This is looking amazing ! What finish do you prefer out of four?
I like the ARS a lot but the Danish oil and lacquer looks good too. The Endurovar showed too much of the red from the timbermate but I was also wiping it on.
I really like how the light banding show in the ARS sample.
Made up a loose tenon jig for a 1/4" up spiral bit to get the top doors put together. So far they came out great, I cleaned them up, sanded with 150 and set them aside with the other two.
I was also able to cut mortise for and fit the hinges on the front legs with the long weekend. They are 2" antique pewter mortise hinges by Classic Brass.
I might actually finish this thing one day!
3 minutes ago, C Shaffer said:
Pic does not show here.
Better?
Question time!!! I need to figure out the shelf to fit in the lower section behind the veneered doors (the top will just have some notched cross members like a bed for the cage portion to slide on)
1) I have a piece of the ribbon stripe ply that is big enough but the grain is running front to back, not side to side
2) I have enough solid sapele to do the whole base with side to side grain. I would probably resaw it to 3/8"-1/2" and support underneath with secondary wood cleats
3) Since the shelf is only 6" off the floor, I could do a 6" strip of sapele along the front and a secondary wood for the rest, like a solid wood edge banding
4) Obligatory something else
  • 26,012 Total Members
  • JAR Newest Member ·
