treeslayer Posted January 29, 2017 Report Posted January 29, 2017 9 hours ago, bushwacked said: Anyone that see's this and comments on it, tell them next time to find a Motel 6! best solution yet! Quote
wdwerker Posted January 29, 2017 Report Posted January 29, 2017 Colored caulk or Color Putty . 1 Quote
bushwacked Posted January 30, 2017 Author Report Posted January 30, 2017 For now can't do much about the mistake so I kept going. Got the face frame going and put wood filler in the nail holes so I can hopefully sand tonight if I get time or tomorrow. Quote
mat60 Posted January 30, 2017 Report Posted January 30, 2017 Cabinet is coming along good and dont let a mistake get to you. 1 Quote
Elroy Skimms Posted January 30, 2017 Report Posted January 30, 2017 On 1/29/2017 at 10:05 AM, wdwerker said: Colored caulk or Color Putty . If you are painting with latex (or something similarly flexible), caulk would be fine. However, if you are using a finish that will cure hard, applying that over a flexible filler like caulk will lead to cracking. Ask me how I know... Though as I re-read this, I see that his suggestion is for COLORED caulk, which implies it would go on AFTER the paint, which would work just fine. Squishy stuff on the outside, hardstuff on the inside. It's like a backwards blow pop. -E 1 Quote
bushwacked Posted January 30, 2017 Author Report Posted January 30, 2017 Ya I'm not sure on what type of paint yet. Thoughts on something that will stand up to all the moisture? Quote
Chet Posted January 30, 2017 Report Posted January 30, 2017 13 minutes ago, bushwacked said: Ya I'm not sure on what type of paint yet. Thoughts on something that will stand up to all the moisture? Exterior Trim paint...Maybe Looks good so far Drew. 2 Quote
bushwacked Posted January 30, 2017 Author Report Posted January 30, 2017 Thanks Chet! Looking around and it seems this is what most people use?? Supposedly will not leave lines or anything and self leveling haha. We shall see I guess. Quote
Chet Posted January 30, 2017 Report Posted January 30, 2017 19 minutes ago, bushwacked said: will not leave lines or anything and self leveling This is why you get trim and not regular wall paint. Quote
wdwerker Posted January 30, 2017 Report Posted January 30, 2017 Have you used today's version of Alkyd (oil base ) paint before ? Longer drying times and smell lingers. Just a heads up. 1 Quote
bushwacked Posted January 30, 2017 Author Report Posted January 30, 2017 Have you used today's version of Alkyd (oil base ) paint before ? Longer drying times and smell lingers. Just a heads up. Sure have not. Never used anything like it before. Any other recommendations Steve? Quote
wdwerker Posted January 30, 2017 Report Posted January 30, 2017 I use a water bourne finish. General makes some good ones ,clear and colored. Quote
bushwacked Posted January 30, 2017 Author Report Posted January 30, 2017 I use a water bourne finish. General makes some good ones ,clear and colored. They make a good bright white? I can't find it on their site Quote
wdwerker Posted January 31, 2017 Report Posted January 31, 2017 My supplier has Generals Polycrylic available custom tinted. Quote
Popular Post bushwacked Posted January 31, 2017 Author Popular Post Report Posted January 31, 2017 Maybe try this: Oh that's a cool trick there My supplier has Generals Polycrylic available custom tinted. Gotcha. So now ready to sand and prime hopefully in the next couple days. Not a nail hole will be seen. Not all the wood filler is nails. There were some holes on the poplar I filled too. I didn't go that crazy haha 4 Quote
bushwacked Posted February 1, 2017 Author Report Posted February 1, 2017 Got all the styles and rails cut. Need to finish fitting the panel tomorrow. And after watching a refresher on mortise and tenon .... I didn't do it right haha. All them I watched did it this way but they also had a true mortise haha. Going to remake the rails tomorrow and not cut off the edges of the tenon so it's flush. Gotta love learning but won't make that mistake again ... hopefully. Plus it's only poplar so I ruined like .25 in wood haha. 1 Quote
wdwerker Posted February 1, 2017 Report Posted February 1, 2017 Just cut a plug ! It's getting painted . 1 Quote
bushwacked Posted February 1, 2017 Author Report Posted February 1, 2017 10 hours ago, wdwerker said: Just cut a plug ! It's getting painted . agree ... but its cheap poplar and will take me 5 mins to cut some more. Also as you can see I need the practice too haha Quote
Popular Post bushwacked Posted February 3, 2017 Author Popular Post Report Posted February 3, 2017 Got the doors done tonight. Little by little it's coming together haha 4 Quote
Chet Posted February 3, 2017 Report Posted February 3, 2017 Thats some nice progress Drew. It is definitely getting there. Quote
bushwacked Posted February 3, 2017 Author Report Posted February 3, 2017 Thats some nice progress Drew. It is definitely getting there. Thanks Chet! And a quick one with the doors kinda lined up just to get an idea of what it's going to look like. Now I need to start looking at hinges and pulls. It's almost time for that. Any thoughts on hinges? Quote
wdwerker Posted February 3, 2017 Report Posted February 3, 2017 If you have a decent drill press euro concealed hinges might work well for you. Figure out how much the hinge edge of the door overlaps the face frame. Then measure the amount the face frame hangs in from the side. I would be glad to walk you through the set up to drill the 35mm cup holes. They make those hinges with the soft close feature built in to them. 1 Quote
Chet Posted February 3, 2017 Report Posted February 3, 2017 7 minutes ago, wdwerker said: I would be glad to walk you through the set up to drill the 35mm cup holes. This would make a great tutorial video Steve. 2 Quote
wdwerker Posted February 3, 2017 Report Posted February 3, 2017 Only if someone volunteers to shoot and edit it ! I've got over 25 years experience installing euro cup hinges but zero interest in learning video ! 1 Quote
