bushwacked Posted April 3, 2018 Report Posted April 3, 2018 How would I go about getting the black plastic male piece out of the white female? Someone ran it over and snapped it clean off in the worst spot. Am I going to have to cut the section of pvc out and replace all of it? Sent from my iPhone using Tapatalk Quote
Tpt life Posted April 3, 2018 Report Posted April 3, 2018 Something like a chisel wide enough to friction fit if threaded. Drill it if glued. PVC takes time but is simple if you need to cut it out. Consider a deeper supply (turning the tee down) and use of a short length of funny pipe to the sprinkler head. It makes future service much easier. 2 Quote
bushwacked Posted April 4, 2018 Author Report Posted April 4, 2018 Thanks!! It’s just threaded. Not glued. I will try that out and hopefully get it out. Sent from my iPhone using Tapatalk Quote
Tom King Posted April 4, 2018 Report Posted April 4, 2018 If a chisel won't get a good enough bite, find a piece of scrap metal that's just a little larger than the inside diameter of the broken piece, heat it not quite red hot with a propane torch, and melt it into the broken part. Of course, it can't be too hot to deform the threads, but if you dab the hot iron in, and out, you can melt it enough to get a good enough bite to get some torque on the broken part once the metal cools. If you have to end up replacing the T, repair couplings that don't have the shoulder in the middle inside will let you slide it back and forth, but you have to be fast to stay ahead of the glue grabbing. Do one on one side, and then do the other side, if you use this method. You have about 3 seconds to do the sliding after the glue is applied. 1 Quote
pkinneb Posted April 4, 2018 Report Posted April 4, 2018 They actually make a tool for that its a couple bucks at Amazon/HD /Etc https://www.amazon.com/Orbit-Sprinkler-Plastic-Extractor-26076/dp/B000I1RQZ8/ref=sr_1_4?ie=UTF8&qid=1522804479&sr=8-4&keywords=sprinkler+head+removal+tool 1 Quote
Cheeset202 Posted April 4, 2018 Report Posted April 4, 2018 I believe it is just a riser that broke off, I have busted a few of them. Most of the time I can get them out with a pair of needle nose pliers or even just with my finger in a leather glove! 1 Quote
Brendon_t Posted April 4, 2018 Report Posted April 4, 2018 Looks like we're having the same night. Found this with the second shovel strike needing to drop a new 4x post a foot wider. I bought the tool at Ace hardware last time that happened here Came with two sizes. 1 Quote
wdwerker Posted April 4, 2018 Report Posted April 4, 2018 Never considered there was such a thing as a nipple extractor. Quote
bushwacked Posted April 4, 2018 Author Report Posted April 4, 2018 Ok I ordered that tool. For $5 it’s worth a shot. Looks like we're having the same night. Found this with the second shovel strike needing to drop a new 4x post a foot wider. I bought the tool at Ace hardware last time that happened here Came with two sizes.Damn! Ya rough day for sprinklers all around hahaSent from my iPhone using Tapatalk Quote
Chestnut Posted April 4, 2018 Report Posted April 4, 2018 Winter isn't over yet here and i have fears for my sprinkler system as well. Never had one before so obviously something is going to go wrong and it's not going to work this spring. Quote
pkinneb Posted April 4, 2018 Report Posted April 4, 2018 I've had a few break over the years the tool makes it a piece of cake just make sure you move enough dirt away so that when you pull the riser out you don't have dirt falling into the fitting making it difficult to get the new riser threaded on. Quote
Tom King Posted April 4, 2018 Report Posted April 4, 2018 Thanks for the tip on the nipple extractor. I've ordered one too. 1 Quote
Brendon_t Posted April 4, 2018 Report Posted April 4, 2018 2 hours ago, Tom King said: Thanks for the tip on the nipple extractor. I've ordered one too. If it was from one of those adult novelty webstores, you may be receiving a whole different piece of tooling than you are expecting.. 2 Quote
wdwerker Posted April 4, 2018 Report Posted April 4, 2018 Or medical supply... there is such a thing as an inverted nipple. Quote
Coop Posted April 5, 2018 Report Posted April 5, 2018 You can get a couple of different kinds of nipple/pipe extractors, even from the big box guys. I’ve found for steel pipe, the spiral is best, For pvc, there is a four sided, tapered extractor that will work. This is not uncommon. Quote
bushwacked Posted April 6, 2018 Author Report Posted April 6, 2018 Got my tool today. A lot smaller than the picture made it look haha. I will be trying it out tomorrow. Sent from my iPhone using Tapatalk Quote
Popular Post Tpt life Posted April 6, 2018 Popular Post Report Posted April 6, 2018 I feel a little silly. I forgot another good method. One other great way to remove a nipple is to cement a smaller pipe to the inside. PVC glue makes a chem weld that is solid in about a minute. Just FYI for anyone who has those materials on hand. 2 1 Quote
bushwacked Posted April 6, 2018 Author Report Posted April 6, 2018 Best $6 I’ve spent in awhile. 10 seconds and it was out. Glad I didn’t have to replace pipe or something crazy like that. Sent from my iPhone using Tapatalk 2 Quote
Tom King Posted April 6, 2018 Report Posted April 6, 2018 Hard to beat having the right tool for the job!! 2 Quote
pkinneb Posted April 7, 2018 Report Posted April 7, 2018 23 hours ago, bushwacked said: Best $6 I’ve spent in awhile. 10 seconds and it was out. Glad I didn’t have to replace pipe or something crazy like that. Glad it worked out, they make pretty quick work of it for sure. 1 Quote
