Tom King Posted November 8, 2018 Report Posted November 8, 2018 Recently, I put all new parts in the 18 year old 325,000 steering system of my truck. When I replaced the tie rods, I carefully measured the length of the old ones, and installed the new ones at that length. I kept the almost worn out tires on the truck, just in case. It was NQR, and I'm glad I waited to put new tires on. Not many places around here can align a dually, and no one could get to it for a while. Even if they could, it would require me to go wait, and end up killing half a day at best. I decided to do it myself, and I'm glad I did. Camber is easy. It's just the tilt of the wheel relative to plumb with the truck sitting level. To set caster, the standard procedure is to park the vehicle on expensive turntables, that let you turn the wheels in and out either 15, or 20 degrees, depending on which system you use, and then multiply, or divide the difference by some factor. I had never studied alignment before, and when I read up on the various methods, and gear needed to set caster, my first reaction was.......COME ON MAN!!!! It's just the fore, and aft tilt of the ball joints relative to each other. On this truck, the ball joints have long treaded rods sticking down in line with each other, and the top one has a grease jerk dead center on top. Since I was out in front of where all the woodworking tools are, I made a couple of U shaped pieces, with holes on the two parallel legs that were a tight slide fit on the ball joint bolts. Digital micrometer, number drill bits, and drill press made that part easy. I could have screwed a metal plate to the vertical leg, to stick the magnetic Wixey to, but didn't have one, so just tied it on. Another simple jig to the outside of the wheel, with another Wixey. If you go to an alignment place, with the fancy smoke and mirrors lift, and accessories, you never get one dead set to optimal, but within an acceptable range as stated on the fancy printout. With my rig, and two digital readouts, it took about five minutes to tap on the cams that move the top of the upper control arm into the perfect tenths of degrees in the recommended range. It makes it really easy being able to see both gauges. To adjust caster the upper ends of the control arm go in, and out separately, to throw the top ball joint forward, or backward. Move both together, in the required direction, to get camber where you want it, after you get caster right. Then check both, and tighten the bolts for the upper control arm to the frame. Camber is recommended at .1 degree, but I set the right one to zero, to try to see if I can get rid of the inner tire wear on the right front tire. Roads are pretty crowned around here. To set toe-in, I drove four stakes in the ground, and clamped some 2x4's to the stakes. Two lines were set, the same distance apart on the 2x4's, and measurements were taken off the axle ends, front and back, until the lines were not only parallel, but the same measurement from the front axle, as well as the rear axle. I didn't take time to think this through to start with, and most of the time was taken getting the lines set right on the 2x4's. Next time, I'll set the lines the same distance apart on the 2x4's, and clamp some short blocks on the stakes, so we can slide the 2x4 back and forth until they are set right. Also, I just eyeballed setting the stakes. Next time, I'll take more time to check diagonals, and set the stakes perfectly square, so I don't have to swing the tape measure to find the shortest measuring point. That will make getting the lines parallel easier. Once the lines are set, measurements can be taken off the front, and rear of the wheels. It's easier than you might think to get an accurate measurement. To adjust the toe, you make sure the steering wheel is centered, and the tie rods can be easily screwed in, or out, to get the toe right where you want it. Recommended says to have 1/16" toe in on each side, but this truck has always worn the inside of the tires out first, everything is new, and tight in the front end now, so I went with 1/32" toe in. It drives fantastically. Tomorrow, I'll go get the new tires put on. This took us a little over an hour today, including making the parts, and fiddling with the line setup. It should take well less than half that next time. Alignment for this truck costs $125 here, as well as me losing half a day. The 2x4 is not out of level in the picture. I just didn't do a good job of placing the stakes. I'll do better next time. It is at the level of the axles. Also, I didn't have any 10 boards close by, so clamped together some 8 footers. Line spacing for this truck needs to be 97-1/2", since the truck is 8 feet wide. Wear on those tires was to the inside, but knowing that I would be playing with it, and replacing all the steering parts, I had them twirled, and rebalanced. It's taken me a couple of weeks to get it done in spare time. Quote
wdwerker Posted November 9, 2018 Report Posted November 9, 2018 I understand the motivation and the approach but will it be worth it by the time it needs re-alignment? And how old will you be by then ? Crawling under a truck or mower doesn't seem worth the effort to me anymore. Quote
Tom King Posted November 9, 2018 Author Report Posted November 9, 2018 Little effort for me still. It hasn't needed an alignment since the last time the steering needed parts, maybe ten years ago, and it's getting less mileage these days that in its early years. There was no investment in equipment. I already had a couple of Wixey cubes. With a new one at 75k, I'll run this one for a while yet. My age does factor into that. It makes little sense for a 68 year old to put 75k in a work truck, not knowing how many more years I'll continue to work. Still beating making payments at this point though. I am looking for a lift to put in the mechanic shop, but I'll get the work done on the two tractors that need it before I put a lift in the way. The only mechanic I like around here doesn't work on diesel duallies, so I'm still my best choice. Quote
wtnhighlander Posted November 9, 2018 Report Posted November 9, 2018 Got any photos of the jigs you made to hold the Wixeys? Quote
Tom King Posted November 9, 2018 Author Report Posted November 9, 2018 I'll try to remember to take some when I go back over there. The caster jig is just a U shape with three strips of wood. I had bought some extra grease fittings, and was planning on making it to slide over the lower ball joint bolt, and screw down onto the top grease fitting, but when it came down to it today, I didn't want to take that much time. The Camber jig just hits the outer edges of the rim, top, and bottom, and has a cutout to skip over the hub. I had intended on making better ones, but at 4 o'clock today, when we had finished what we were working on for pay, I just wanted to get it done. The Wixey cubes were just zeroed on long 2x4's laying on the ground, before I used the 2x's for the Toe rig. I might not ever need them again, so really not good time spent to make better jigs. There is plenty of room to work inside the tire on a 1 ton. I laid a towel on the tire, and laid my chest on the tire, a sheet of 3/4" pink styrofoam on the ground to get to the tie rods, and have a good helper to hand me tools. Having someone who knows where all the tools are, and to hand them, is a Big help. I don't think we lose any time over pro mechanics. MIke also read, and managed the Wixey's while I had my head in the wheel well. 1 Quote
wdwerker Posted November 9, 2018 Report Posted November 9, 2018 Amen to quality help that knows where the tools are ! Lets you focus on the job at hand without the distraction of finding that elusive socket. Quote
Tom King Posted November 9, 2018 Author Report Posted November 9, 2018 After getting new tires on it this morning, coming back on I85, I ran it up to a speed I won't mention, but higher than I would normally have any idea of thinking about approaching, but just to see what it would do, it was dead smooth. There was no pull on the steering wheel. On the crown in the middle, or either lane crowned in opposite directions, I could not hold the steering wheel, and it would track straight for hundreds of yards. When I got home, even the little tips of rubber that stick out on a new tire showed no signs of wear, either on the inside, or outside corners of the new tires. I think it's probably better than it ever has been. 2 Quote
Chestnut Posted November 9, 2018 Report Posted November 9, 2018 If you didn't bust three digits you didn't' do it right . Quote
Tom King Posted November 9, 2018 Author Report Posted November 9, 2018 I didn't want to wind the old engine up quite that tight. Normal cruising, highway speed rpm is 1200 at about 60. I didn't want to come close to redlining it. I still want the engine to last another few hundred thousand miles too. It went fast enough for me to see how good my alignment was. 1 Quote
Tom King Posted December 21, 2018 Author Report Posted December 21, 2018 I didn't remember how long ago I did this, so I decided to look for this thread. Today, I thought about checking the front tires to see if there was any kind of noticeable wear to the inside, or outside edges. Not only is there no noticeable wear, but the little rubber tip thingies are still right on all edge corners of the tires. I'm sure I must have driven 1,500, or 2,000 miles since Nov. 8, and would have thought all those little things would have been long gone. When I did the first string alignment, as pictured here, for some reason we didn't get the steering wheel exactly centered, and I wasn't satisfied with that. I adjusted both tie rods twice to get it back to center, but didn't recheck with the strings. I did put a piece of blue tape on the front of the tie rods, with a pencil mark the same height off the floor in the shop, and turned both the same number of turns to get the steering wheel back to center. I think when I did the string toe-in adjustment, the truck had been in a big turn, and I straightened the steering wheel after stopping. Next time I do this, I'll come in straight to the stop. 1 Quote
Bankstick Posted December 21, 2018 Report Posted December 21, 2018 I gave up on my own work- too old and gimpy to crawl in and under the truck. My new SUV will be taken to the Ford dealer for service. I know that it will be expensive but the dealer includes a lifetime warranty on the vehicle, regardless of age or mileage. Good in all 50 states, too. Quote
Chestnut Posted December 21, 2018 Report Posted December 21, 2018 1 hour ago, Bankstick said: I gave up on my own work- too old and gimpy to crawl in and under the truck. My new SUV will be taken to the Ford dealer for service. I know that it will be expensive but the dealer includes a lifetime warranty on the vehicle, regardless of age or mileage. Good in all 50 states, too. I think those warrantys are smart. They generally come with the strings attached of doing all the scheduled maintenance. In the end i believe it motivates people to maintain their car better and they get a more reliable longer lasting vehicle as a result and the dealer never has to make warranty repairs. The nice part is some of the dealers that offer them around here don't require the dealer to do the work you just have to save the invoice/parts receipts. You can even do the work yourself. Quote
Bankstick Posted December 21, 2018 Report Posted December 21, 2018 I just need to prove by receipts, etc., that the work was done according to the warranty. Quote
JohnG Posted December 21, 2018 Report Posted December 21, 2018 It is illegal for car manufacturers/dealers to require that you have routine service performed at their dealerships (or any specific repair place) in order to keep your warranty valid. They can, however, require that you use certain authorized shops for warranty work that is to be done free of charge. They can refuse to cover a repair that is normally covered under warranty if a related repair was previously done at a non-authorized service center and they can argue that the failure was due to improper repairs done at that other service center. This sort of stuff is covered by the Magnuson-Moss Warranty Act if you are concerned about any of the specifics. Quote
Tom King Posted December 21, 2018 Author Report Posted December 21, 2018 I'm just far enough out in the country that time lost on carrying my truck somewhere would cost me more than the time it takes doing these simple jobs myself. We have a great mechanic a few miles away, that does the work on my Wife's car, but they aren't equipped to work on 1-ton duallies. Everything on a 1 ton is big, but easy to get to. We have a 24 x 40 poor building, that was here when we first got the place, and has a nice, smooth concrete floor. I use it for metal work, and mechanic work. We have a couple of tractors, and equipment for maintaining the Ponderosa, and if that building wasn't already here, I probably would have needed to build one by now. There is always something to do on tractors, and mowers. I don't believe I've ever had as good of an alignment job as this one, done with simple tools. This truck has always worn the inside of the right front tire, and by tweaking the caster, and camber, I believe I'm close to eliminating that. I now believe that the fancy alignment machines are a lot of smoke and mirrors. Quote
Tom King Posted April 5, 2019 Author Report Posted April 5, 2019 A little update. My right front tire finally started to show some wear on the outside edge. Recommended camber was -.1 degree, but that tire had always worn the inside edge, so I decided to try 0.0 camber. This time, I just stuck the Wixey to the edge of the wheel, after zeroing the cube on the floor in front of that tire. It still read 0.0. I marked where the locating pin was on both cams on that upper control arm, loosened the bolts, and tapped both cams in the same amount (so it wouldn't change the caster), until the Wixey cube read -.1 degrees. We'll see how this goes. I rotated the front tires so that problem right tire would have two good edges. I'm thinking maybe the original alignment was off, causing the inner tire wear, but I never thought about doing it myself back then. When I first did the alignment, I think I made the wrong assumption that the inner tire wear was from the highly cambered country roads. Quote
Chestnut Posted April 5, 2019 Report Posted April 5, 2019 Good to hear your method is working long term. I suppose it'd be too much work to have a plate that you bolt on in place of the tire to give you a bigger surface to reference? The inside edges are always the first to wear out on my car but that's how it's set up form the factory. Quote
Tom King Posted April 5, 2019 Author Report Posted April 5, 2019 I took one of the lug nuts off to give a large enough flat surface for the magnet to grab onto the flat center part of the 8 lug truck wheel when I first did it. They're dually wheels that are designed to fit together facing opposite directions on the back axle, and are also used on the front, so there are nice, large flat areas on these wheels anyway. This time, I didn't go to the trouble of taking a lug nut off, since I first checked just on the front edge of the wheel, and it read the same camber I had set it to before. You know how small the Wixey cubes are, so having a larger surface probably doesn't matter. Quote
Bankstick Posted April 5, 2019 Report Posted April 5, 2019 My warranty is valid as long as the work is verified by receipts. However, the Ford dealers would have access to the records on their computer. Anyone old enough to remember the old Checker cabs? Yellow Cab in NYC had some back in the 50s that had over 500K miles. Detailed records were kept (before computers) and when it was time for scheduled maintenance, the cab went into the shop and serviced. I read an advertisement in a trucking magazine of one brand that had a five year, 500K warranty. 100K is a lot of miles but not for an OTR truck. Spent all day Wednesday working on the riding mower. The overall design could have been better, IMHO. Quote
Chestnut Posted April 5, 2019 Report Posted April 5, 2019 I don't have a wixy cube i should probably get one i can see the benefit of them. I also am not familiar with duly wheels but now that you say that it makes sense. I ran across a YouTube video complaining that the accuracy of the wixy cube was only +- 0.2 degrees and would vary between 89.8 and 90.2 when set on the same surface.... My first though was "Is that 0.2 degrees going to make a difference in woodworking? Just saying that because the accuracy may effect your application of the device but if you have multiple separate readings that are the same i'd bet it's pretty close. Quote
Tom King Posted April 5, 2019 Author Report Posted April 5, 2019 Both my Wixey cubes, and any digital levels I have, all read the same thing, so they are probably close enough. All the readings, the way I set the alignment, and visible signs after four months, seem to make sense. I have no doubt than it's better than an alignment machine that only gets things in the right range. The last time I had an alignment done in a shop, I saw how accurate it could be by the way the technician clamped the things on the wheels (not). Quote
Tom King Posted April 5, 2019 Author Report Posted April 5, 2019 There are a number of things that can cause inside front wear, but if everything is set to spec, and the right front wears on the inside, it's probably the difference between the left, and right caster. Typically, they call for .5 degrees more caster on the right, than left, so the vehicle will hold straight on a cambered road, but this does put more wear on the inside right tire. Of course, road cambers vary, so it's always a compromise finding the exact setting for any road camber. The more caster a wheel has on it, the more it will lay over into any turn of the steering wheel. Just like a motorcycle with a lot of rake on the front forks, the more stable it becomes in a straight line at speed, but the harder it is to turn. I raised the caster up .2 degrees on my right front, to put it at .3 degrees difference from the left. I do have to hold a little left steering wheel on narrow, Virginia country roads, but not anywhere else. That could be the cause of my outer right wear, but I had changed two settings at once, so I'll have to see how it goes after setting the camber back. I'll put a little more caster on that side, if it continues to wear. Even if this 19 year old truck, with 340k on it was still under warranty, no one could tell that I had done any alignment work on it. Quote
