Chestnut Posted November 29, 2018 Report Share Posted November 29, 2018 https://minneapolis.craigslist.org/dak/tls/d/engine-driven-saw-table/6749721726.html This thing looks interesting. No offense but it reminds me of something @collinb would enjoy seeing. 1 Link to comment Share on other sites More sharing options...
Tpt life Posted November 29, 2018 Report Share Posted November 29, 2018 Only surprise for me is the size of motor. That looks like a mill saw setup. The Amish around here sometimes run off of little fives. Link to comment Share on other sites More sharing options...
Minnesota Steve Posted November 29, 2018 Report Share Posted November 29, 2018 I think that's the front end off an old Farmall Cub powering that. Link to comment Share on other sites More sharing options...
Mark J Posted November 29, 2018 Report Share Posted November 29, 2018 Idk. You could put in the shop, but the dust collection would be a challenge. Link to comment Share on other sites More sharing options...
Bankstick Posted November 29, 2018 Report Share Posted November 29, 2018 Don't forget the CO emissions. I can hear it now, "What kind of gas mileage do you get with your table saw?" 2 Link to comment Share on other sites More sharing options...
wtnhighlander Posted November 30, 2018 Report Share Posted November 30, 2018 Looks like the sawmill from "Little House on the Prarie" tv series. Wood table, no fence. Upgraded from waterwheel to diesel. What could possibly go wrong with that? Link to comment Share on other sites More sharing options...
wdwerker Posted November 30, 2018 Report Share Posted November 30, 2018 It can't be Collin's tablesaw, there isn't any twine on it ! 2 Link to comment Share on other sites More sharing options...
Popular Post collinb Posted November 30, 2018 Popular Post Report Share Posted November 30, 2018 2 hours ago, wdwerker said: It can't be Collin's tablesaw, there isn't any twine on it ! *sigh* 3 Link to comment Share on other sites More sharing options...
wdwerker Posted November 30, 2018 Report Share Posted November 30, 2018 If we didn't like you we wouldn't pick on you ! Hopefully you can take it in the spirit intended ? Link to comment Share on other sites More sharing options...
Minnesota Steve Posted November 30, 2018 Report Share Posted November 30, 2018 On 11/29/2018 at 11:12 AM, Minnesota Steve said: I think that's the front end off an old Farmall Cub powering that. Yeah, that's definately a Cub... sometime from the 1940s, maybe 50s. If it was still a tractor I think it might be worth the $700 he's asking. Just not sure the engine alone is worth that. Link to comment Share on other sites More sharing options...
Brendon_t Posted December 1, 2018 Report Share Posted December 1, 2018 So the shaft for the blade is run off of a belt driven by a pulley on the crank?? That is Seriously Awesome! Link to comment Share on other sites More sharing options...
wdwerker Posted December 1, 2018 Report Share Posted December 1, 2018 If that saw kicks back the board will go through the barn door with ease. I read a book about a guy that was running a steam engine powered tablesaw. It kicked back and mortally wounded him when he was working by himself. He crawled to the basement and shut down the boiler to prevent an explosion before he expired. Link to comment Share on other sites More sharing options...
Tpt life Posted December 1, 2018 Report Share Posted December 1, 2018 I am not sure where the physics of kick back got misunderstood here. This saw should not run any faster than what we have in our shop. The motor will have HP and torque, but the stepping of pulleys would target a blade spinning at the same speed to not over heat. Link to comment Share on other sites More sharing options...
wtnhighlander Posted December 1, 2018 Report Share Posted December 1, 2018 Torque plays a critical part in kickback. I can hold a board well enough to stall the 1.5 hp motor on my contractor saw if it binds. I doubt anyone will do the same with that diesel engine, even though the blades are turning the same speed. Speed would matter more if the stock is not held down tightly, for sure. But consider the mass of the workpiece. A drive capable of 100 lb/ft of torque at 5000 rpm can accelerate a much greater mass than a drive producing only 10 lb/ft at 5000 rpm. The kickback my tablesaw can do with a 4/4 board could probably be duplicated on that saw with a 16/4 board of equal width and length. 1 Link to comment Share on other sites More sharing options...
Chestnut Posted December 1, 2018 Author Report Share Posted December 1, 2018 Lets assume that motor cracks out 50 ft-lbs and the blade is 12" and lets also assume we have a 12" 3 hp table saw. The 50 ft-lbs is a heck of a lot more force going into the projectile than the maybe 4 from a table saw. so 12" blade that puts the tip force at 100 lbs and 8 lbs respectively. the tip of the blade is essentially a lever 6" long from the center of the arbor. This is a generalization because obviously the power transfer through pullies is going to change stuff so i was assuming both motors being in 1:1 drive and running 3,600 rpm not realistic for the diesel. Link to comment Share on other sites More sharing options...
Tpt life Posted December 1, 2018 Report Share Posted December 1, 2018 Why does everyone keep saying diesel? Link to comment Share on other sites More sharing options...
Chestnut Posted December 1, 2018 Author Report Share Posted December 1, 2018 1 minute ago, Tpt life said: Why does everyone keep saying diesel? Oh your right sorry i'm used to todays small tractors that is a gasser isn't it. Link to comment Share on other sites More sharing options...
Tpt life Posted December 1, 2018 Report Share Posted December 1, 2018 My dad’s dad sold Farmall. There were fewer diesel models. I assumed the wires I see are distributer and plug wires. I stand by the physics. Once the piece moves it is accelerated by the spinning mass. I am obviously not comparing this to a job site saw. I don’t see more powerful kicks for 1.75 HP to 5 HP in commercial settings. I have a hard time thinking a belt driven 19 HP on old leather belts would make any difference at the same blade speed. Do I care on the high end? No! I only question using language that might lead someone to think a 1HP saw won’t imbed the kicked piece in a door. Any kick is dangerous. Check out the blade shown in the pics. Those are deep gullets. Really looks like a beam milling or cleaning setup. Link to comment Share on other sites More sharing options...
Chestnut Posted December 1, 2018 Author Report Share Posted December 1, 2018 Not really convinced you understand physics. 1 Link to comment Share on other sites More sharing options...
Bankstick Posted December 2, 2018 Report Share Posted December 2, 2018 Two things here- 1. I checked the calendar and didn't see that it was "Pick on collinb" month. 2. I lived in a farming community in central Kentucky. Cubs, in the late 70s and early 80s, were going for a lot more than $700. Saw one go for $1,200! My father and uncle had a Farmall H and M back in the early 50s. Brings back a lot of memories! Quote Not really convinced you understand physics. Like a MLB fastball and a slow pitch softball? Which one hurts more? The fastball, according to my grandson. Link to comment Share on other sites More sharing options...
wtnhighlander Posted December 2, 2018 Report Share Posted December 2, 2018 13 hours ago, Tpt life said: Why does everyone keep saying diesel? I could have sworn the ad said it was diesel. Where are my reading glasses? Link to comment Share on other sites More sharing options...
