Hey hope everyone is safe and finding ways to not be bored. Was hoping to get some opinions on my cabinet saw. When I bought my cabinet saw the electrical plug on it looks almost like it was the same as a dryer’s plug....since it worked I figured why change it, but now w the new shop layout I need a longer chord and am debating putting on a twist plug or something I am used to. Any input would be appreciate me as electrical is not my main wheelhouse. Plus I do not want to have to mess with again later ;). The motor details are in the below photo/ 3HP single phase
5 minutes ago, JohnG said:
You can get twist lock in 30a also. But if you already have the dryer plug and receptacle, why spend the extra money to change it?
He said he is moving the saw and needs a longer cord.
I assumed the picture of the plug and receptacle was in his shop. He says he needs the longer cord because of a new layout of his shop.
If he’s set on switching to twist lock, go for it. The only downside to twist lock other than cost is that you end up with a larger minimum clearance in front of the receptacle since they stick straight out instead of 90*, plus clearance for the wire bend, depending on gauge.
Just go to an electrical supply place, and buy whatever length of 12/3 type SO wire you need, and use the devices you have.  The supply house will be significantly cheaper than any of the box stores.  You can change the plugs later, if there is any need, but the setup you have is reliable.  There will probably be some other letters behind SO, with what the place has in stock, but those won't really matter for your use.  Most typical is SOOW.  Don't get type SJ.
The outer cover on SO wire is really tough.  You have to carve into it, like a surgeon, with a sharp utility knife being careful not to cut into the individual conductor insulation underneath the cover.    Bending the wire away from the cut not only helps, but is almost required.    Once you get the cover off, like you need to, the individual conductors can be stripped with most any kind of wire strippers.  With the top off of that male plug, hold the wire on top of where it needs to go, to judge where to strip the outside cover off, and how long to leave each conductor.  You won't have a lot of room inside there to stuff any extra.  Tighten the lugs a little tighter than you think you need to, using a straight blade screwdriver, even though both straight, and Phillips will fit the screw heads.
Buy an extra foot or two of wire.  If you don't buy enough to have some to throw away, you're guaranteed to come up short.
I made all of my cords as is suggested above with twist lock plugs/outlets purchased everything at HD. I never thought an electrical supply place would be cheaper but thanks for the heads up Tom!  As mentioned they do stick straight out and becuase you have to replace both the outlet and the plug it can get spendy but I like the fact that they aren't going to accidentally come unplugged.
I'll side with Tom about usin type SO cord, but in my opinion, only switch to a twist-lock connector if you expect to unplug it often. The "dryer" connector is a more reliable connection if it is to stay plugged in all the time. The weight of the cord pulls against a wall-mounted twist-lock, eventually creating poor connection, generating heat, and causing failure (sometimes fire!). I see it happen often with continuously-running equipment. An intermittent load, like a hobbyist's table saw, may take years to fail, but it will fail before the clothes dryer style plug does in the same conditions.
Having said all that, I unplug my saw EVERY time I stop cutting with it, and understand how difficult those dryer plugs can be. Even if you don't disconnect when you leave the shop, please do so when you stick your hands into the machine!
Ok I'm curious @Tom King Why do you not like SJ? Service Junior wire is rated for 300v. Looking at my machines all of the 240v machines came from the factory with SJT. Having said that SOOW is my cord of choice as it's durable and stays flexible and lays flat even in below zero weather. Generally the price difference is minimal. The only downside to it is overall size and weight is slightly larger and heavier.
I'm not a fan of anything with a T in it. T stands for thermoplastic and generally isn't as flexible as a non T wire. Non T wires are rubber insulated.
SJ is not nearly as robust as the SO cords. The wire insulation is a little heavier & the outer cable jacket is much tougher. Not a fan of the T cable at all.
  • Who's Online   3 Members, 0 Anonymous, 55 Guests (See full list)
    26,008
    Bob44
    Bob44
