Mark J Posted December 18, 2021 Report Share Posted December 18, 2021 I know they make plywood blades for the TS, but I don't have one. I do have crosscut, rip and combination blades. Which is the best second choice for plywood? I'm guessing the combination blade, but what does the herd say? Quote Link to comment Share on other sites More sharing options...
JohnG Posted December 18, 2021 Report Share Posted December 18, 2021 I’d go for the crosscut blade. The tricky thing about plywood is that it’s half cross and half rip. It’s the cross plies that cause problems, so a crosscut blade would do well. Quote Link to comment Share on other sites More sharing options...
Chestnut Posted December 18, 2021 Report Share Posted December 18, 2021 I use my cross cut blade. Combination gets me a lot more chip out. Quote Link to comment Share on other sites More sharing options...
gee-dub Posted December 18, 2021 Report Share Posted December 18, 2021 Given your set I would use the combo for most things and maybe the crosscut for 3/8" and under. Even my 50T made for ply is sometimes too many teeth for anything over 3/4". Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted December 18, 2021 Report Share Posted December 18, 2021 I agree with the above comments, but will offer an observation. I have a 60T Spyder 'Tarantula' blade from a home center. This is supposed to be a 'construction grade' cutter, but this thing makes AMAZINGLY clean cuts, across grain, through ply, and even glue-ready rips, although feed is slower for that. It is a little thinner than the premium blades, and may not have enough carbide to resharpen even once, I don't know. But the cut quality is pretty darn impressive, especially for a blade in the $50 range. Quote Link to comment Share on other sites More sharing options...
krtwood Posted December 18, 2021 Report Share Posted December 18, 2021 I leave my plywood blade on all the time unless I have to rip over 1" thick or need a flat bottom to the kerf. I don't bother with having a crosscut blade anymore, they do the same thing just the plywood blade does it better at the expense of maybe getting dull faster. 1 Quote Link to comment Share on other sites More sharing options...
BillyJack Posted December 19, 2021 Report Share Posted December 19, 2021 I'm not sure if Amana still does, but they use to have a breakdown of what different teeth do depending on what you want. Other site may offer this. Get educated on what is what and weigh it against what you need. Quote Link to comment Share on other sites More sharing options...
Dave H Posted December 20, 2021 Report Share Posted December 20, 2021 When I want a smooth no tear out cut I lower my blade so only about 1/8" is above the table saw I run the piece through the saw then raise the blade above the thickness of the piece I'm cutting and run it through and wah-lah no tear out ever. Yes it takes a little longer per cut but, so is changing blades I use a combo blade exclusively. 2 Quote Link to comment Share on other sites More sharing options...
