Coop Posted August 19, 2025 Report Posted August 19, 2025 That’s cool! Thanks for sharing. How long were you on the boat? Quote
Popular Post h3nry Posted August 19, 2025 Author Popular Post Report Posted August 19, 2025 On 8/18/2025 at 9:25 PM, Coop said: That’s cool! Thanks for sharing. How long were you on the boat? About three months, starting near Victoria and exploring the coast northwards ... BC has a lot of coast. 4 Quote
Popular Post h3nry Posted August 20, 2025 Author Popular Post Report Posted August 20, 2025 Back in the shop ... trying to remember where I left off. Started with something not to difficult. Added some flutings to the doors ... 6 Quote
Popular Post h3nry Posted August 20, 2025 Author Popular Post Report Posted August 20, 2025 Added the hinge mortices to the doors... Then while I'm waiting for the door veneer to flatten, I started cutting out the pieces for the top ... Fortunately I have a board wide enough for the centre where the hole for the sewing machine goes. When I bought the wood I got it at a 25% discount because the boards had some big cracks in them ... but since the boards were 10ft long, and I don't have any pieces much over 3ft on this, there was lots of useable wood between the cracks ... but it meant that I didn't have long enough section between cracks to make the whole top in one piece and then cut off the folding flaps, it's got to be made in 3 pieces from the start. 7 Quote
Mark J Posted August 21, 2025 Report Posted August 21, 2025 16 hours ago, h3nry said: I didn't have long enough section between cracks to make the whole top in one piece and then cut off the folding flaps, it's got to be made in 3 pieces from the start. But that will be on the "inside" where few people will see. Quote
h3nry Posted August 22, 2025 Author Report Posted August 22, 2025 On 8/21/2025 at 7:20 AM, Mark J said: But that will be on the "inside" where few people will see. True, and I've got the grain pretty well matched along ... the real thing will be making sure the join between the boards lines up between the top and the flaps. 2 Quote
Popular Post h3nry Posted August 22, 2025 Author Popular Post Report Posted August 22, 2025 The edges of the central hole need shooting straight and square, and then a rabbet added to hold the insert. Then the panels can be glued up. The top gets cut to length and made square, but the flaps are left long for now, just the joining edge squared. The panels then get a final flattening. And a finger hole in the insert ... 6 Quote
Ron Swanson Jr. Posted August 22, 2025 Report Posted August 22, 2025 This is a real pleasure to follow along with. Thank you for sharing it! 2 Quote
Popular Post h3nry Posted August 22, 2025 Author Popular Post Report Posted August 22, 2025 Made a test of the edge profiles for the top using a piece of scrap. The fold out flap has to have the mirror profile of the top. I didn't do a very good job attaching the hinges. It should have been obvious, but I also learned that the vertical section that the hinges mortice into had to be thicker than the hinge, not the same thickness ... but that's what practise pieces are for. 6 Quote
Popular Post gee-dub Posted August 23, 2025 Popular Post Report Posted August 23, 2025 On 8/22/2025 at 4:16 PM, h3nry said: ... but that's what practise pieces are for. Amen to that. This is why I will pick up junk furniture or wood that folks are tossing out. It gives me a supply of material I do not care about and will use willingly for prototyping or test fitting. Much better that testing on the material I have selected, color matched, or would have difficulty replacing. 4 Quote
Von Posted August 23, 2025 Report Posted August 23, 2025 On 8/23/2025 at 8:51 AM, gee-dub said: Amen to that. This is why I will pick up junk furniture or wood that folks are tossing out. It gives me a supply of material I do not care about and will use willingly for prototyping or test fitting. Much better that testing on the material I have selected, color matched, or would have difficulty replacing. I'm slowly learning the value of spare pieces as well. However, I tend to use whatever wood I'm using for my project because I often get into a "how should I finish this" dilemma and like to experiment with different finishes, which benefits from using the same wood as the project. 2 Quote
Mark J Posted August 23, 2025 Report Posted August 23, 2025 14 hours ago, h3nry said: The fold out flap has to have the mirror profile of the top. That's a great detail. 1 Quote
fcschoenthal Posted August 24, 2025 Report Posted August 24, 2025 On 8/23/2025 at 7:56 AM, Von said: I tend to use whatever wood I'm using for my project I do the same thing. You always need to buy more than is required anyway, why not use it. 1 Quote
Popular Post h3nry Posted August 25, 2025 Author Popular Post Report Posted August 25, 2025 Preparing the door panels for veneering ... They need to be veneered on both sides, although the back side doesn't need to be as aesthetic as the front ... Unfortunately I badly damaged the corner of one of the front faces. I tried to splice in a patch ... although the patch came out of the same sheet of veneer, about 3 inches below the repair, and along the same grain lines ... there's just too much figure, and it looks awful. Fortunately I do have another sheet of veneer ... so this is a do-over. It would be easy to tout this as one of the advantages of hide glue, in that with a judicious application of heat and water, and the old veneer can be peeled off with minimal damage, and no damage to the backside ... but it was probably my insistance on using such antiquated techniques that got me into this mess in the first place. now to try again ... 5 Quote
Ron Swanson Jr. Posted August 25, 2025 Report Posted August 25, 2025 @h3nry I appreciate your dilemma. But it just wouldn't be any fun without the two-steps-forward-one-step-back rhythm. :/ I'm sure you'll come shining through this! 1 Quote
Popular Post h3nry Posted August 26, 2025 Author Popular Post Report Posted August 26, 2025 Ok ... this time it turned out better. Now I have to fit these panels into the doors. 8 Quote
Popular Post h3nry Posted August 28, 2025 Author Popular Post Report Posted August 28, 2025 Since the inside of the doors will not be carved, I thought that the asymmetrical arches looked kind of odd ... so time to even them up a bit. first cut in the new edge and chop away as much waste as possible. Then pare it down to the line. and clean it up a bit. for re-establishing the groove, the mortice chisel seemed like the easiest tool. 5 Quote
Mark J Posted August 28, 2025 Report Posted August 28, 2025 10 hours ago, h3nry said: re-establishing the groove, That groove is for the floating panel? Quote
Popular Post h3nry Posted August 28, 2025 Author Popular Post Report Posted August 28, 2025 Yes, the panels go in the groove ... but first the panels need the arch shape cut in the top, and be planed down to size on the other three sides. And fitting into the frames ... 7 Quote
Ron Swanson Jr. Posted August 28, 2025 Report Posted August 28, 2025 That looks stunning, @h3nry! Quote
Mark J Posted August 29, 2025 Report Posted August 29, 2025 In the coping saw picture, how are you holding down the panel for sawing? Quote
Popular Post fcschoenthal Posted August 29, 2025 Popular Post Report Posted August 29, 2025 On 8/29/2025 at 8:19 AM, Mark J said: In the coping saw picture, how are you holding down the panel for sawing? Usually with a bench pin (or birds mouth), you hold down with one hand and saw with the other. This allows you to move the piece around like on a scrollsaw. The saw teeth are cutting on the down stroke, so it pretty much holds it tight. 3 Quote
Popular Post h3nry Posted August 31, 2025 Author Popular Post Report Posted August 31, 2025 On 8/29/2025 at 5:54 PM, fcschoenthal said: Usually with a bench pin (or birds mouth), you hold down with one hand and saw with the other. This allows you to move the piece around like on a scrollsaw. The saw teeth are cutting on the down stroke, so it pretty much holds it tight. Exactly ... left hand holds the piece down onto the birdsmouth ... right hand works the saw cutting on the downstroke. I use a fairly fine tooth blade, and err towards cutting into the wood of the birdsmouth, so that there is minimum risk of damaging the veneer on the underside. All I got done today was gluing up the door frames ... 4 Quote
