On 3/28/2025 at 8:28 AM, Mark J said:
Sounds like you will need some heavy duty hinges to support the top open load.   But that's down the road a bit.
I'm going to be using piano hinges ... I hope they'll be up to the task.
Glad you showed the before and after routing the excess before finishing the carving. Really surprised at the difference it makes. I would probably take the shortcut of scrolling out the "fancy bits" and laminating them onto the panels. Routing out the waste really gives it a different look.
On 3/31/2025 at 6:20 AM, pkinneb said:
Looks awesome! So you do the routing freehand?
Yes, all freehand. I try to stay just outside the lines, and then pare down to the line with the carving gouges.
For a lot if the carving, the final edge will be slightly undercut to make it stand out more.
On 3/31/2025 at 9:13 AM, Chestnut said:
I'm more curious how you cut and cleaned up those odd curves so easily.
Cut on the bandsaw, then cleaned up with a rasp and file before scraping and sanding.
  • Thanks 1
I've got most of the carving done on the right hand door. It still needs a bit of cleaning up and sanding.
That’s absolutely beautiful. I’ve never heard of someone doing intricate carving like that freehand with a router. A previous picture looked like you had a small palm router in it. What kind of bit do you use for something like that?
  • 3 weeks later...
I ran into a similar cabinet dilemma a while back and ended up trying out ai furniture design to sketch up a model before cutting anything. It saved me from a bunch of mistakes, especially with tight tolerances for the drop-down sewing machine shelf. The cool part was being able to adjust clearances visually before committing to measurements. Made the whole process smoother.
  • 3 months later...
  • Who's Online   4 Members, 0 Anonymous, 45 Guests (See full list)
    32k
    437.5k
    Bob44
    Bob44
