Popular Post pkinneb Posted March 3, 2025 Popular Post Report Posted March 3, 2025 Your carving is awesome! 3 Quote
Popular Post h3nry Posted March 10, 2025 Author Popular Post Report Posted March 10, 2025 Turning the feet ... My turning skills are pretty basic, and so is my lathe. I'm kinda maxing out the bed length of my little lathe here ... Starting square and making it round ... Then roughing in the location of all the detail ... and refining it to the correct diameter using calipers: And then rounding off the details ... Turning the tenon down to size and fitting it into the legs. The tenon intersects one of the carcase mortices, so I'll need to chop off a corner of the round tenon ... but I'll do that when the legs are glued up. One down three more to go ... It's very clear at the moment that the feet are made of Sapele and not the Khaya ... hopefully with finish on that will be masked considerably. 6 Quote
curlyoak Posted March 10, 2025 Report Posted March 10, 2025 On 3/10/2025 at 12:07 AM, h3nry said: My turning skills are pretty basic The only thing basic is the tool. And you make very nice turnings with a basic tool. h3nry, you left basic skills behind you a long time ago. i enjoy the ride. Nice of you to bring it here! Thanks for sharing. 1 Quote
gee-dub Posted March 10, 2025 Report Posted March 10, 2025 Really enjoying this. Thanks for sharing the techniques and processes. Quote
Mark J Posted March 10, 2025 Report Posted March 10, 2025 9 hours ago, h3nry said: The tenon intersects one of the carcase mortices, so I'll need to chop off a corner of the round tenon I was musing on the idea of leaving the leg tenon round and using a drill (press) to remove a "quarter cylinder" from the intersecting carcass tenon. I was thinking the joints would be stronger. But now I'm not so sure. I am sure it would be a lot harder to do. 1 Quote
Popular Post h3nry Posted March 14, 2025 Author Popular Post Report Posted March 14, 2025 I'm using a Khaya crotch veneer for the panels ... Still using hide glue and hammer veneering technique. 7 Quote
wtnhighlander Posted March 14, 2025 Report Posted March 14, 2025 Can't wait to see that with finish on it! Coming along nicely there, @h3nry. Quote
Mark J Posted March 14, 2025 Report Posted March 14, 2025 Coming along quickly, too. When I look at a piece like this I think ot must have taken months and months. At least in the one picture the Khaya - Sepele transition in the "legs" does not stand out. 1 Quote
Popular Post h3nry Posted March 18, 2025 Author Popular Post Report Posted March 18, 2025 Before gluing up the carcase, I need to make the false drawer fronts on the right. I've already veneered the fronts, and need to add a cock beading. The beading is planed down to 1/8" thickness: Then a roundover applied to one edge and cut to size and mitered: Then glued onto the edges of the fronts. The two lower right "drawers" are purely cosmetic, and will be held in place with dowels. The cock beading has quite a large reveal because I want the drawer pulls to be recessed within the reveal so that they don't interfere with the cabinet doors closing. The upper two do actually have a bit of space behind that can be used for a small amount if storage. The fronts will fold down. I'm using concealed pin hinges. which are drilled in on the edge. A small slot also needs to be drilled on the back so that the pins can be removed for disassembly. There's not a lot of space behind them, but I'm sure I can find something to keep there. And the false drawers are ready ... the real drawers on the left will be constructed after the carcase is glued up. 7 Quote
wtnhighlander Posted March 18, 2025 Report Posted March 18, 2025 Love the recessed look of the drawer fronts! What sort of drilling device is that in photo #5? 1 Quote
Popular Post h3nry Posted March 18, 2025 Author Popular Post Report Posted March 18, 2025 On 3/18/2025 at 4:40 AM, wtnhighlander said: What sort of drilling device is that in photo #5? It's called an Archimedes Drill ... the handle slides up and down the twisted shaft to rotate the bit. I keep a small bit permanently in it for drilling pilot holes. iIt's quick and convenient and simple for small holes without having to mess about with the egg-beater. 5 Quote
Popular Post Beechwood Chip Posted March 18, 2025 Popular Post Report Posted March 18, 2025 On 3/18/2025 at 10:49 AM, h3nry said: It's called an Archimedes Drill My father called it a Yankee Screwdriver. It had drill and screwdriver bits. 3 Quote
curlyoak Posted March 18, 2025 Report Posted March 18, 2025 On 3/18/2025 at 11:24 AM, Beechwood Chip said: Yankee Screwdriver. I have one. It has not been used for decades. I'm going to try a small pilot bit.... Thanks 2 Quote
Popular Post h3nry Posted March 18, 2025 Author Popular Post Report Posted March 18, 2025 The one I have is designed for small drilling only, the collet holds 3/32 max and rotates too fast without a lot of torque ... great for drilliling small holes, but would be useless for driving screws. 3 Quote
Popular Post wtnhighlander Posted March 19, 2025 Popular Post Report Posted March 19, 2025 The "Yankee Screwdrivers" I've seen all had a pair of counter-rotating spiral grooves in the shaft. That drill, with its multiple flutes all spiraling the same direction, is new to me. Thanks for the info. 4 Quote
Popular Post h3nry Posted March 20, 2025 Author Popular Post Report Posted March 20, 2025 GLue up time ... a few sub assemblies could be glued up first ... And even then it was quite a tricky glue-up. 8 Quote
Tom King Posted March 20, 2025 Report Posted March 20, 2025 This is Real woodworking!! There are a bunch of those Archimedes drills on ebay. I just ordered an old German one. Quote
gee-dub Posted March 20, 2025 Report Posted March 20, 2025 Really satisfying to ride along. Thanks for taking the time. Quote
roughsawn Posted March 21, 2025 Report Posted March 21, 2025 I love the old school furniture making you do. The craftsmanship with hand tools is awesome. Thanks for keeping us in the loop. I really enjoy your posts. Quote
Popular Post h3nry Posted March 21, 2025 Author Popular Post Report Posted March 21, 2025 One last thing needs adding to the main case: a piece if moulding beneath the upper drawers... First mark out the profile on the end, and scribe the lines down the sides. Then plane away the big square rabbet in the corner. This Khaya has some of the worst interlocking grain I've ever met, so when taking coarse shavings with the rabbet plane it is very prone to tear-out. Adjusting the plane to take a much finer shaving for the last little bit helps smooth over the worst of it. This really bad tearout doesn't matter yet since it will be removed when the cove is cut. Then bevel the edge of the cove so that the hollowing plane has a nice flat surface to start on. Then finish the curves with the hollow and round plane ... and some final smoothing with sandpaper. Then it's time to get out the miter saw to cut the moulding to length. And glue it in place. As you can see, I've also fitted the lift mechanism into the cabinet. 8 Quote
Mark J Posted March 21, 2025 Report Posted March 21, 2025 @h3nry, I assume your molding planes are old style wooden body planes. Are they antiques, or modern remakes? If you make your own, how do you do that? How do you sharpen the curved blades? Quote
Popular Post h3nry Posted March 21, 2025 Author Popular Post Report Posted March 21, 2025 On 3/21/2025 at 7:04 AM, Mark J said: @h3nry, I assume your molding planes are old style wooden body planes. Are they antiques, or modern remakes? If you make your own, how do you do that? How do you sharpen the curved blades? They're wooden, but they're modern chinese ones ... like these: https://www.ebay.ca/itm/116382096824 Lee Valley used to sell them, but at a considerable markup to getting them direct from China. I would love some antique wooden ones, but getting hold of a good set will be either very expensive, or time consuming hunting down missing sizes (and probably still end up expensive). The convex blades can be sharpened on flat stones freehand. Just like sharpening a curved gouge. You have to rotate the blade as you move it across the stone to make sure that the whole edge gets honed. The concave blades are harder ... I have a couple of fine grit slip-stones, which are ok for keeping an edge honed, but would be a real pain if I had to do any real grinding on a badly damaged or blunt blade. 6 Quote
Popular Post h3nry Posted March 24, 2025 Author Popular Post Report Posted March 24, 2025 Time to make the drawers ... Cutting dovetails... tails, pins, grooves and plywood bases: Add the cock beading as before ... check that they all fit ... Now I have to start work on the doors and top. 6 Quote
Popular Post fcschoenthal Posted March 24, 2025 Popular Post Report Posted March 24, 2025 On 3/18/2025 at 9:49 AM, h3nry said: It's called an Archimedes Drill ... the handle slides up and down the twisted shaft to rotate the bit. I keep a small bit permanently in it for drilling pilot holes. it's quick and convenient and simple for small holes without having to mess about with the egg-beater. I don't have an Archimedes drill, guess I'm going to have to look for one. Different than the "Yankee" that others produced. I've collected some at estate sales, etc, but rarely use them. Some screwdrivers from Stanley, Miller Falls & North Bros. A really nice Stanley drill My "egg beaters". 6 Quote
