On 8/31/2025 at 8:09 PM, h3nry said:
unfortunately it looks like the right door frame didn't come out of the clamps quite flat ... there's a bit of an ugly gap where the doors overlap.
I'm not quite sure how to fix this, or if it is indeed the door and not the case that isn't properly square  ... for the moment I'll get on with the top while I ponder this ...
First, wow - it looks amazing!
Sorry about the door frame. My respect for the art of the glue up is growing.
Very loose brainstorming: clamp the door flat and add some bracing, which will be under tension, to try and spring it flat?
I developed the habit of clamping frame parts to a known flat surface during glue up.  As you mention, if my carcass is a bit out of square I can still have problems.  The piece is coming along beautifully.  I too do "something else" when I need to percolate on a solution to an unexpected issue.  Sometimes the answer comes to me over coffee or in the shower the next day :D
On 9/1/2025 at 4:52 PM, h3nry said:
I have to start thinking soon about how the shelving on the inside of the doors is going to work.
It would be a shame to cover up the burl veneer with shelves, but I'm sure that it's more than a request.
That's very vexing, particularly as careful as you are.
Looking back at the picture in your Aug 31 post I'm wondering if it might be possible to shim out the door's hinge?  But then the top might not lay flat when opened?  Just thinking "outloud".
On 9/13/2025 at 8:04 PM, h3nry said:
first cut a strip to size ... I need 100 inches. Then plough a groove to make an inset area in the middle, and finally cut a lattice pattern for decoration.
Would you please say a little more on how you cut the lattice? I see what looks like a mortising chisel in the photo. I would be anxious about breaking the strip. TIA.
20 hours ago, h3nry said:
, I made a quick attempt to smooth them with a small flat file, but they're definitely not sanded to 220.
Maybe a job for a small triangular file or rifflers?
On 9/15/2025 at 10:48 AM, Ron Swanson Jr. said:
I'd be tempted to make a sanding block about 6" long and in the shape of those triangles, with paper on each face.
I don't think I'm going to do it ... but I will acknowledge this is a good idea.
  • Who's Online   4 Members, 0 Anonymous, 45 Guests (See full list)
    32k
    437.5k
    Bob44
    Bob44
