The turned legs are just the segment below the carcase, right? Not integral to the square corners? If so, I like the plan to use sepele. The slight difference in species will go unnoticed, since there is a natural break between to components.
That's right ... my lathe isn't big enough to mount the whole leg ... so I was just going to turn a ~7/8" tenon about 2" long on the round part and glue it into a drilled hole at the end of the square part, which I hope should be strong enough.
+1 on using sapele. Nobody is going to be looking at the feet anyway with the rest of it so beautifully ornate.
Just in case you haven't considered it, you have my cross-grain wood movement tingles going with that upper stretcher going into the side rails and the legs. I think it's OK, but on the cusp.
I don't think I need to worry ... the piece is less than 4" wide, and it's only cross-grain for the last 2" on the side rails.
I could have left it floating by the side rails, but dovetailing into the rails does add a little bit of rigidity.
Agreed. I overestimated the width from the photo. At <4" the movement should be negligible.
