Popular Post Mark J Posted September 3, 2025 Popular Post Report Posted September 3, 2025 I had to read it three times, but I understood the explanation. I think you have some clever solutions. I particularly liked the bit about taking the two pieces into the house for safekeeping . I'm curious why you used a hand drill for the Forstner instead of using the DP, since you used the DP in the next step? 3 Quote
Popular Post Chet Posted September 3, 2025 Author Popular Post Report Posted September 3, 2025 On 9/3/2025 at 6:39 AM, Mark J said: I'm curious why you used a hand drill for the Forstner instead of using the DP, since you used the DP in the next step? I took the top of the very bottom case and the bottom of the case right above it and did the two of those to completion. Then I took the next top and next bottom and completed those and so on. For me it felt like less potential for a mistake. And because of my chosen process I didn't want to keep changing the drill bits in the drill press. The counter sink process wasn't as critical as having the hole that the furniture bolt would go through being straight up and down. So the drill bit went in the drill press and the Forstner bit was relinquished to the hand drill. 4 Quote
Popular Post Chet Posted September 29, 2025 Author Popular Post Report Posted September 29, 2025 I have been working on this little by little, my shop has no AC so some sessions are short. I applied 3 coats of finish to all the inside portions of the cases and then started the glue ups. Glue ups are a bit of a stress point for me so not a lot of pictures. I only have two band clamps so that limits me to one case at a time. I started by placing the parts in the proper order, outside facing up. I apply blue tape to all the adjoining edges then carefully turn it over and apply the glue, because this is an end grain glue up I apply a thin coat and let it sit for a few minutes until it looks like it is skinning over then apply a second and a little heavier coat but you don't really need a bunch of squeeze out to get a good glue up. But the glue manufacturers would prefer that you do because then they can sell more glue. I put the back panel in to groove and then fold the sides and top over and put the band clamps on. While this was setting up I worked on my drawer parts. First up was putting a rabbet on the two out side edges of the drawer fronts. When I started this I was real happy I had taken the time to make an extra front for practice because cutting the rabbet threw me for a bit of a loop. I had set up my dado stack and was using the miter gauge to run them though the saw but when I did the last quarter of an inch or so would cut deeper. After making a couple attempts I realized that was happening because what I was cut wasn't flat, it was curved on the inside. So the support or the drawer front would diminish as you got closer to the back part of your cut going over the throat plate for the dado stack and it would actually drop down. So. I went to using my sled so it would be supported all the way through the cut. Then I milled and sanded the sides and backs for the drawers. To put the groove for the drawer bottoms normally you could just use a 1/4" bit in the router table and run your parts flat on the table but with the curved drawer fronts I used a 1/4" groove bit with a 1 5/8" bearing. This will give me a groove 1/4" X 1/4". I set the bit so it is up a 1/4" from the bottom of the drawer parts. After doing this to all the parts, I put a regular 1/4" up spiral bit in and cut a groove down the center on the outside of the drawer sides. This is so the drawers can ride on the drawer runners in the cases. I ran it through once and then flipped it end for end and ran it through a second time to make sure the groove is centered. Then I put a rabbet in the back end of the sides for the drawer backs. I also got the drawer bottoms al processed. Along with all this, every so often I would get another case glued up and in the clamps. After they were all done I sanded them all to 180 and ready to start finishing. 6 Quote
Mark J Posted September 30, 2025 Report Posted September 30, 2025 That's a good bit of work you've done since the last post. It's looking good. Are the drawer fronts holding their curve, or will they need some tweaking? 1 Quote
Mark J Posted September 30, 2025 Report Posted September 30, 2025 With the drawer runners, you've got the spline in the drawer box and centered on the box side. Then the drawer itself has a groove centered on the drawer side. How do you insure that the drawer will fit and slide easily in the box? Is this all down to careful measurement? Do you trial fit the drawer side in the box before gluing up the drawer? 2 Quote
Popular Post Chet Posted September 30, 2025 Author Popular Post Report Posted September 30, 2025 On 9/30/2025 at 6:23 AM, Mark J said: Are the drawer fronts holding their curve, or will they need some tweaking? Yes, they are holding up fine. The glue I used, Unibond One, drys with a hard line. If I had used just regular titebond there could be the possibility of creeping. On 9/30/2025 at 6:34 AM, Mark J said: With the drawer runners, you've got the spline in the drawer box and centered on the box side. Then the drawer itself has a groove centered on the drawer side. How do you insure that the drawer will fit and slide easily in the box? Is this all down to careful measurement? Do you trial fit the drawer side in the box before gluing up the drawer? I made a couple of spare sides. I cut the groove in one and then checked how it moved back and forth over the spline. The spline is 1/4" so the groove ended being 9/32". Once I was happy with the movement, I dry fit one drawer using blue tape and checked how it operated. Then I went ahead and cut all the grooves and did a dry fit on all the drawers. 7 Quote
Popular Post gee-dub Posted September 30, 2025 Popular Post Report Posted September 30, 2025 Nice. I am loving this design and your build. The beveled fronts on the mitered drawer boxes look great. 2 1 Quote
pkinneb Posted September 30, 2025 Report Posted September 30, 2025 Coming along great Chet!! Love your solution for the bottom groove in the curved front! 1 Quote
Popular Post Chet Posted October 6, 2025 Author Popular Post Report Posted October 6, 2025 I didn't really want any thing of the metallic nature for drawer pulls. I also wanted to be on the small side so as not to become a distraction from the rest of the piece. I went with Wenge for both the legs and the drawer pulls to add a little contrast to the project. I tried to come up with a design that I liked and could make without getting my digits in the way or ending up with less digits then when I started. I started with two scraps that were around 5"or 6" long. One was 1" square on the end and the other 7/8" 1 1/2" but that one was going to get ripped down to 7/8" X 1/2". First thing I did was put a 1/4" quarter round on two edges of each piece. On the one that is 1" square I hogged out a channel that left me with a "U" shape that was 3/16" on all three sides. Then at the band saw I made some slices that were 5/16" thick. I need 5 drawer pulls so I cut 7 pieces. At the drill press and with the help of a jig I drilled an 1/8" hole though the sides of the "U" shaped piece. This is for 1/8" dowel that will hold the two pieces together. I used the jig to keep the piece from pushing down under the pressure of the drill and ending up with the two holes out of alignment with each other. Then I ripped the other piece down to 1/2" and cut 7 pieces 1/2" thick at the band saw. At the drill press I drill an 1/8" hole on the side that was centered and 3/8" up from the bottom. In the back of the same piece I drill another 1/8" hole center, that was 3/8 down from the top. This is what it ended up looking like. 6 Quote
Coop Posted October 7, 2025 Report Posted October 7, 2025 Wish your shop had ac as I’m getting anxious! Looking great bud! Quote
Popular Post Chet Posted October 7, 2025 Author Popular Post Report Posted October 7, 2025 I spent the week doing the finish. Three coats of Arm R Seal on the tops and bottoms so it took most of the week. After that I attached the legs to the bottom case. Then I did the final assembly of the cases. After that I glued up the five drawers. Here is where we are. And I bet you thought I would never get this project finished considering I started in June. When assembling things I found a few items that need to be touched up. Also I need to wax the drawer runners. 12 1 Quote
Ron Swanson Jr. Posted October 7, 2025 Report Posted October 7, 2025 Wow!! That really came out nice!!! 1 Quote
Popular Post gee-dub Posted October 7, 2025 Popular Post Report Posted October 7, 2025 You knocked that one out of the park. The design is wonderful, the material is beautiful and the shop made pulls are the cherry on top. This was a fun journal. I really enjoyed tagging along. 2 1 Quote
Von Posted October 7, 2025 Report Posted October 7, 2025 Very nice. The pulls look great installed and I like the level of grain on the wood giving it some character. Quote
pkinneb Posted October 7, 2025 Report Posted October 7, 2025 That is too cool Chet!! Great job! Quote
Coop Posted October 8, 2025 Report Posted October 8, 2025 Great job Chet! That is really cool! 1 Quote
h3nry Posted October 8, 2025 Report Posted October 8, 2025 A beautifully built and unique piece . Great job ! 1 Quote
Mark J Posted October 8, 2025 Report Posted October 8, 2025 Lovely! It will attract a lot of (well deserved) attention. Where will you place it? 1 Quote
Ron Swanson Jr. Posted October 8, 2025 Report Posted October 8, 2025 On 10/7/2025 at 12:06 PM, Chet said: I spent the week doing the finish. Three coats of Arm R Seal on the tops and bottoms so it took most of the week. After that I attached the legs to the bottom case. Then I did the final assembly of the cases. After that I glued up the five drawers. Here is where we are. And I bet you thought I would never get this project finished considering I started in June. When assembling things I found a few items that need to be touched up. Also I need to wax the drawer runners. @Chet Second best thing in this journal is your No Soliciting sign!! 1 Quote
Popular Post gee-dub Posted October 8, 2025 Popular Post Report Posted October 8, 2025 On 10/8/2025 at 6:07 AM, Ron Swanson Jr. said: @Chet Second best thing in this journal is your No Soliciting sign!! Some of us are so alike it is scary. Darn, now I need to go straighten that doorbell plate 4 Quote
Chet Posted October 8, 2025 Author Report Posted October 8, 2025 On 10/8/2025 at 8:11 AM, gee-dub said: Darn, now I need to go straighten that doorbell plate Or angle the sign so they match. 2 Quote
